[ROM] Samsung Omnia Pro B7610 Megalite ROMs
I think it's time to post it here
Samsung Omnia Pro B7610 MEGAlite ROMs
English only
http://i187.photobucket.com/albums/x248/fire_z/20100313_010703_0002_111g.jpg
http://i187.photobucket.com/albums/x248/fire_z/20100313_010737_0003_111g.jpg
http://i187.photobucket.com/albums/x248/fire_z/20100313_011850_0004_111g.jpg
Here is a line of custom lite ROMs (originally posted in Modaco.com).
Almost all Samsung Apps (and some WM) are removed, though you can install them back with ready made cabs.
MEGAlite ROM 6.5.5 Build 23547
RECOMMENDED
- Based on PDA XXIL2
- 320Mb Free Storage and 92 Free Ram
- Removed almost all Samsung Apps
- Auto closes applications when available memory is below18Mb (even without Auto Close patch)
- for more info see original thread here http://www.modaco.com/content/b7610-...-free-storage/
MEGAlite ROM 6.5.5 Build Build 23545
- 280Mb Free Storage and 92 Free Ram
- for more info see original thread here http://www.modaco.com/content/b7610-...m-6-5-5-xxil2/
MEGAlite ROM 6.5 Build 21XXX
-Based on PDA XXIL2, Official WM build
-200Mb Free Storage AND 96 Free Ram
- With Samsung Widget Plus and Pro UI
- for more info see original thread here http://www.modaco.com/content/b7610-...alite-rom-6-5/
INSTRUCTIONS FOR FLASHING (PLEASE READ):
http://www.megaupload.com/?d=GX8P3SR7
1. Download. Unpack. Flash with Octans Mini
2. Download 23547 Rom fix
http://www.4shared.com/file/24306760..._reg_only.html
Install Rom fix, wait for a few minutes and then soft reset
What to do after:
1. Install .Net Framework 3.5
2. Samsung Apps installation Cabs are available below
http://www.megaupload.com/?d=NNW27DRH
1. Download, Extract and Flash with Octans Mini
2. Download Rom 23545 fix
http://www.4shared.com/file/23977095..._655-2354.html
What to do after:
3. Install Samsung SDK 2.2 (Caution: May cause device wake up problems)
http://www.4shared.com/file/23558287...alite_ROM.html
2. Download Rom 6.5 fix
http://www.4shared.com/file/23621215..._Fix__Twe.html
What to do after:
3. Install Samsung SDK 2.2 for Auto Rotate to work (Caution: May cause device wake up problems)
OTHER DOWNLOADS
SAMSUNG APPLICATIONS
Updated Samsung Apps Includes Camera, FM radio, Settings, GPS, Wifi and Bluetooth Settings, Smart reader, Photo Frame, Touch Player, Album, Clock etc.
Download it here:
1st Set
http://www.4shared.com/file/243917896/febb..._MEGAlite_.html
2nd Set
http://www.4shared.com/file/243989689/904e..._for_23547.html
Chainfire Auto Close fix http://www.4shared.com/file/240211912/4e89...sePatch-11.html
If you want the WM 6.5 slide back install this, wait for some seconds, and soft reset http://www.4shared.com/file/242378474/57e3...5_Lock_Scr.html
Office Mobile:
http://www.4shared.com/file/236113841/eebd...ice_Mobile.html
Samsung SDK 2.2 (may 'cause wake up problems)
http://www.4shared.com/file/236884057/a71e...dist_2_2_0.html
ISSUES AND FIXES
About some OEM/3rd party applications not working
Just Install .NET framework 3.5
About getting errors in applications links eg. missing wifi/bluetooth settings, band selection, WM settings, etc.
Be sure to install the appropriate fix for each invidual ROM, and install appropriate Samsung Applications too.
About the Samsung X-button
Samsung X button (close apps) will not work on WM 6.5.3 and 6.5.5 for the reason that the x-button is not located in the upper right corner of the screen in these builds (it's now in the lower right corner).
To enable 6.5.3-5 x-button to terminate programs again, use this app found here http://forum.xda-developers.com/showthread.php?t=583002
It will not only let you close programs but you will also have other options to set (for start menu and x button)
About Screen Tap Vibrations
Well it works... just set it in Samsung Settings or in WM Settings/sound and notifications/vibrations, check screen taps
Though vibrate will not work on screen keyboard and bottom bar...
But don't worry you can use Touch Response download it here http://forum.xda-developers.com/showthread.php?t=450256
Install and set the vibration duration for taps... remember to set device ID to 11
About GPS not finding any sattelites.
Change GPS COM port to 6
About application (some) screen positioning problem
I don't know I solution yet. Maybe you can help me
About "Why don't you incorporate fixes in your ROM before cooking?"
Because I'm just a newbie in cooking
About device not waking up
Uninstall Samsung SDK 2.2
Xin các cao thủ hãy xem xem có thể ra 01 bản hướng dẫn up ROM cho B7610 được ko? (Xin lỗi mình hơi dốt Anh ngữ)
English only
RECOMMENDED
What to do after:
What to do after:
What to do after:
OTHER DOWNLOADS
Download it here:
1st Set
2nd Set
Office Mobile:
ISSUES AND FIXES
