Features:
* Major bugs in v3.8 solved [NEW]
* No more stretching on Desktop for Wide screen [NEW]
* Cut/Copy/Paste bug fixed [NEW]
* Left pane also works [NEW]
* Browsing can be multi tasked [NEW]
* Floating Windows can be moved by dragging
* Shows all from Bootup to Log Off screens
* Auto rotates screen using G-Sensor (if available)
* Shows Windows XP icons for almost every type of file
* Minimum Requirements: Screen Resolution 320x240 / 400x240 (Low readability)
* Recommended screen resolution: 640x480 / 800x480 pixels
* Can be run on a lo-fi Pocket PC smoothly
* English ROM recommended
* Compatible with Windows Mobile 5.0 and later
mới cài 3.7 hôm qua, hic chiến tiếp thôi
mình vẫn chưa thấy khác biệt nhiều so với bản 3.5 nhỉ ?
Có khả năng bản 4. sẽ khác biệt!
* Experience the look and feel of Windows XP on your Windows Mobile Pocket PC
* Browse your Pocket PC with Windows Explorer type interface
* Create shortcuts and arrange them on shortcuts
* Real like login and logoff screen
* Almost every dialog is a floating window
* Provides all common file operations
* Auto rotates screen orientation using G-sensor (if supported)
* Runs smoothly even on almost any low powered hardware
* Access menu bars like the way you do in Windows
* Left pane shows common tasks and details
* Displays time and battery status in the system tray
* Multiple windows can be opened and minimized at the same time
* Right Click anywhere on the screen to access additional options
* Runs on almost any screen resolution (larger than 640x480 is recommended)
* Shows Windows XP type icons
* Icons can be dragged and re arranged on the desktop in classic mode
* Runs on all English ROM based Pocket PCs
Thanks! Nhưng bản 4.0... The requested document was not found on this server.
Đây:
http://download552.mediafire.com/22...yaqmy/xp-modification-for-pocket-pcs-v3.9.rar
V4 is Not Found
Web Server at teamfluxion.com
Link die rồi!
cho mình hỏi con HTC Kaiser của mình có xài đc cái này không?
bác cài bản mấy? thử cài lại bằng bản 3.8 xem.Có cài được cho Hp data messenger ko ạ? em cài xong lúc chạy nó báo lỗi A problem has occurrend with XPModification for pocket pcs.exe là sao ạ.Đại ca giúp em với.
Cài bản mới nhất đi. HD1 chạy tốt nhưng nói thật chả có gì nghịch đâu bạn ạ.không biết có chạy ngon trên BLACKSTONE không nhỉ? ai cài rồi cho xin ý kiến nên cài bản nào zới.
thanks,
mình cài bản mới nhât rồi, chạy thì chỉ nghe tiếng khởi động, rồi hiện lên màn hình đầu rồi bị lỗi không vào được luôn, không biết có xung khắc với thằng sb moblie shell k? bị lỗi nên remove luôn rồiCài bản mới nhất đi. HD1 chạy tốt nhưng nói thật chả có gì nghịch đâu bạn ạ.
Thôi cài làm gì bạn... Không có gì đâu ngoài cái giao diện XP, mang đi khoe cũng ối người ngạc nhiên đó...)mình cài bản mới nhât rồi, chạy thì chỉ nghe tiếng khởi động, rồi hiện lên màn hình đầu rồi bị lỗi không vào được luôn, không biết có xung khắc với thằng sb moblie shell k? bị lỗi nên remove luôn rồi
thanks bác dũng, em ghi nhận ý kiến của bác. có dịp vào sài gòn ghé em uống li nước nhé.Thôi cài làm gì bạn... Không có gì đâu ngoài cái giao diện XP, mang đi khoe cũng ối người ngạc nhiên đó...)
