langthang262
Bản này chạy rất tốt, mình dùng mấy ngày nay rồi mà chưa gặp lỗi gì.
Pin tốt, nhiều tùy biến chỉnh sửa để vọc, giao diện lạ.
Tác giả mới ra bản cập nhật mới, mình giới thiệu để mọi người dùng thử:
Links gốc bên XDA:
http://forum.xda-developers.com/showthread.php?t=918899
Welcome to the HyperDroidGBX (Gingerbread Xtreme Edition):
The FIRST Open-Source Custom ROM Designed and Optimized just for the HD2!
Links download:
http://bit.ly/HDGBXv9gksEp4
ROM Information
Clean, Minimalistic, Dark, Fast UI
LCD Density at 167 by default (easily changeable using Root Explorer; I use and highly recommend 167)
Based on Redux Gingerbread for Desire built by ihlades (Huge Props to this guy!!!)
Lucid Theme by Sonnysekhon (mixed version by pongster)
Apps2sdExt support (install detects ext partition (if available) and installs apk's on sd-ext) (Oxygen ROM apps2sd+ mod by AdamG)
Dalvik2SD script modded by pongster (works automagically if an Ext partition is detected)
Auto Zipalign script (ensures your apps use RAM efficiently)
Fastest Customizable Launcher (ADWLauncher)
Clean, Readable Font (Zegoe Regular Font)
Some Apps from Minimalist by david1171 and DarkGinger by darky
Boot Animation by Dysgenic
Advanced Phone Features by Nushio
Shows "H" when connected to a HSDPA network
So much more... (check the changelog)
Patched files:
Improved 720p Playback (CM7 Stagefright libs)
patched libsqlite (faster IO and less Disk Usage) by ownhere
GPS Fix from gauner1986 and Diem
Various Fixes by ihlades & pongster
Unique Phone Features of Phone by Nushio:
Vibrate on Answer
Vibrate every 45 secs
Vibrate on Hangup
Vibrate on Call Waiting [UNTESTED]
Keep Screen Awake
Always use proximity
Always back to call log
Missed call LED notify [UNTESTED]
Show nick/organization
Turn over silence [UNTESTED]
Left-hand mode
Blacklist
What works:
3G / Data
Audio
Bluetooth
GPS is working (No 60mA battery drain issue.) (Props to Gauner1986 & Diem)
Network Location
Wi-Fi
Phone
Camera
Camcorder
USB Tethering (Please test as I don't use this)
USB Mass Storage
LED Charging Lights (Thanks to iamgpc)
LED Notification Lights (Thanks to iamgpc & tytung)
Auto Backlight (Thanks to iamgpc)
WiFi Tethering/Hotspot (thanks to tytung and charansingh)
Apps Not rendering Full Screen:
167 LCD Density makes some apps not render correctly so you need to uncheck "Compatibility Mode" in the included Spare Parts App
What doesn't work: (looking into it)
BT in standby is 60mah
Not all apps are compatible with Gingerbread yet
Hướng dẫn:
Boot into MAGLDR (Power On and HOLD the Power Button till MAGLDR options are shown)
Boot into AD SD or AD Recovery to enter CWM Recovery Mode
If coming from another ROM, do a Nandroid Backup (just to be sure)
Wipe data
Wipe cache
Wipe Dalvik Cache
Go to mounts and storage and mount sdcard
Copy the ZIP you downloaded to your sdcard and unmount
Select install zip from sdcard
Find the HyperDroidGingerbread.zip and install
Reboot and remove Phone from USB
After initial setup, reboot to get everything settled
Enjoy the Clean, Fast, Minimalist Gingerbread HyperDroid Goodness!
Để dùng bản này mọi người có thể chỉnh flash.cfg với thông số như sau:
misc ya 1M
recovery rrecov|ro|nospr filesize recovery-raw.img
boot yboot|ro 5M
system ya 95M
cache ya 5M
userdata ya|asize|hr allsize
Ngoài ra, để dùng tiếng Việt, mọi người lên Maket download bản Multiling keyboard nhé.
Bản vietnamese IME không tương thích với 167 LCD Density.
Links gốc bên XDA:
![CAP201101182257.jpg](http://dl.dropbox.com/u/1246235/HD2/Android/HyperDroid/Gingerbread/CAP201101182257.jpg)
![CAP201102161001.jpg](http://dl.dropbox.com/u/1246235/HD2/Android/HyperDroid/Gingerbread/CAP201102161001.jpg)
Links download:
ROM Information
Patched files:
Vibrate on Answer
Vibrate on Hangup
Keep Screen Awake
Left-hand mode
Blacklist
What works:
3G / Data
Audio
Bluetooth
Network Location
Wi-Fi
Phone
Camera
Camcorder
USB Mass Storage
Hướng dẫn:
Wipe data
Wipe cache
Wipe Dalvik Cache
misc ya 1M
boot yboot|ro 5M
system ya 95M
cache ya 5M
![5532330002_5ae5041f11.jpg](http://farm6.static.flickr.com/5019/5532330002_5ae5041f11.jpg)
