[19-03-2010] PDAVIET - I8000 WM6.5 ROM (23549.5.5.0) - SB12
Sonblack
PDAVIET WM6.5 ROM - I8000
CE OS 5.2.23549 Build 23549.5.5.0 PV
Lời cám ơn - Many thanks:
Admin Kawaguchi (so much for his tools)
Manager PhamQuang (so much)
SM BatKid (so much)
Adv Mod TranMinhMan (so much)
Adv Mod NhatToai (so much)
SVip Tom_codon (so much)
Member huyentrangallery (from Samsung, support I8000 for cooking)
Member Lancez (from United States) for everything
Thông tin ROM - ROM Information:
Basic ROM: PDA_I8000HZUJC1_HW_40
Language: Only WWE
Pagepool: 8MB
Version: I8000.23549.JC1.SB12
The ROM is still "the same as previous version" with some small changes. :D
Hình minh hoạ - Illustrative Images:
Chức năng chính - Main functions:
- Core 5.2.23549 Build 23549.5.5.0
- .NET Compact Framework Version 3.5.9198.00
- Windows Media Player 10.3 Build 23549
- Office Mobile 2010 (Word Mobile, Excel Mobile, PowerPoint Mobile, OneNote Mobile, SharePoint Mobile)
- MSN Money
- MSN Weather
- Marketplace
- FlashLight
- SRS WOW HD for OMNIA II
- Soft Reset (Written by Sonblack)
- VnKeyb v2.2.0 by ntd (Skin from hanoiwap, included Set Keyb in English - Thanks Super Mod Tmap)
- Opera Mobile 10 Final (Touch Phone)
- Không hiển thị Popup của Mortscrip - No display Mortscript popup
(Thanks Admin Kawaguchi)
- Java_JblendPackage_2_1_2_1_20090429_2_1_R6 from Topaz II
- AdobePDF_2_5_1_0_404840_03
- Check New ROM
by
Admin Kawaguchi (you can check new rom version with link directly from your device in Settings - Personal)
- ArkSwitch v1.1.2 (www.arkstronic.com)
- Change Samsung Keypad from XXJB1 and remove Samsung Panel.
- Các ứng dụng cần có của PPC như: PIM Backup (v2.8), Synchro Time (v0.95), CleanRAM (v1.9.9), Advanced Configuration Tools (v3.3), ClearTemp (v1.3), Total Commander (v2.52 beta 2)... với các version mới nhất
Basic applications for PPC such as
PIM Backup (v2.8), Synchro Time (v0.95), CleanRAM (v1.9.9), Advanced Configuration Tools (v3.3), ClearTemp (v1.3), Total Commander (v2.52 beta 2)... with their newest versions.
- Loại bỏ nhiều ứng dụng không cần thiết mà tôi không thích! :D
Asphalt4 (Game), Crayon Physics (Game), Dice (Game), Face Book, Podcast, QIK, RSS Reader, Cube, MainMenu, OnlineWidget, Samsung Today, Video Editor, Digital Frame, Smart Search, Unit Converter, Video Editor, Application Store, Communities (Share Pix), Connected Home, Midomi, Task Switcher, SPlugin Favorites, Google Maps, Smart Memo, Smart Reader, Smart Sync, Task Switcher, Youtube, My Files, Adobe Reader, Opera Mobile, Java,...
Removed more unnecessary utilities which I don't like! (see above list)
Ai không thích icon nhỏ của Start Menu có thể làm như sau để xoá toàn bộ Registry dưới đây và Reset
Anybody don't like small icons of Start Menu can do as follows in order to delete all following Registry and Reset
[HKEY_LOCAL_MACHINE\Security\Shell\StartMenu]
"CustomGridForm"="StartMenu_Sonblack"
Link đã có sẵn - The links are available now
DOWNLOAD I8000 HZUJC1 ROM 23549
PART 1
PART 2
Password for uncompress: Sonblack
Chúc vui!
Enjoy it!
Sonblack
redzone
Cant wait to try it out!!
Keep up the good work Sonblack!
If I could make one suggestion for next rom could you please enable manual rotation in registry so i can set it to a button. like this
registry hk_local machine – system – gdi – rotation; in key HideOrientationUi change 1 to 0
Thanks!
Google translation
Giữ thành Sonblack làm việc tốt!
Nếu tôi có thể làm cho một trong những gợi ý cho rom kế tiếp, bạn có thể xin vui lòng cho phép xoay hướng dẫn sử dụng trong registry vì vậy tôi có thể đặt nó vào một nút. như thế này
đăng ký hk_local máy - hệ thống - GDI - xoay; trong HideOrientationUi thay đổi phím 1-0
Cảm ơn!
Sonblack
Ok, thank you so much!
:D I can use English with you, no problem! You don't need to translate for me!
I understand what you said!
secanny
\-/Lại có ROM mới nữa, hehe bản cook chắc tuyệt hơn bản full nhiều.\-/ Thanks!
mihai959
good roms tnks for sharing with us w8-ing for sb13 with lock fix
just flashed 23549 lôking nơ for any new things and fixes
o16v
SonBlack!!!!
Thanx for this fantastic job!!!!sb12 is excellent.Very fast as sb11!Wm7 is so excellent!!!
Your ROM's are the most stable and customer friendly (wm7 titanium...:)))
Lancez
just flashed and working flawlessly. we really do appreciate ur consistent effort to improve every single ROM. thank you! =D>
plguzman
Sonblack, greetings from Venezuela. Great ROM, first time I use one of your ROMs.
One question, there's no layout for VnKeyb in spanish?
Cheers!
secanny
\-/ Bản này trên cả tuyệt vời - very good good !!!!!!\-/​
Đã tét mọi thứ OK. Đang tìm lỗi post lên mà chưa thấy. :))
Sonblack
Cheers!
Yes! There's only VnKeyb layout in English and Vietnamese. This is a program which is written by ntd (a Vietnamese member) and hanoiwap (other member) revised the skin for suitable with VnKeyb! It's only use to type Vietnamese and English in my ROM.
bouboule
Very good ROM
I try it since yesterday and it seems to be ok
Very fast ROM
The touch is very good
The only problems that i found :
- Impossible to use Fring (connect to wifi but don't find Wifi-Network)
- Igo8 freeze a lot
This problems were already in the SB11 ROM
