crazyboy_t2
My friend and I have not got that problem. You can try to hard reset your device. Tell me that you get that problem again. Regard.
The first thing I do after flashing is a hard reset...
This never happened before the 199 and 202 builds...with the recent 195 this does NOT happen...
This happens even before I install my other software...
Maybe some of the software you include is not compatible with these two builds and causes this issue?! A 100% clean version would clear any doubt about this...
Anyway thanks for you time...I really appreciate your work!!!
