ASUS P535 - ROM WM6.1 PDAVIET (Build 20753.1.4.0)
tomsoft
That's right. You cannot choose more files with stylus because this rom have touch function. It make you cannot choose several files. And this build is beta, I think it will be fixed in the next build. Thanks for your illustrative pictures. :))
Thank you for your explain. I will enjoy for next build. :D
alanlee
Bạn khacduy1978 xem lại thử, build 20721 cũng thường xuyên activesync always on đó, build 20478 thì ngon lành, cón bản này mình chưa thử.
Cài activesync kill và sử dụng cả chức năng liên quan trong QuickMenu cũng không ăn thua, làm thủ công thì khắc phục ngon lành :D
khacduy1978
Mình nghĩ activesync allways on là bình thường vì khi thực hiện activesync với PC thì activesync sẽ chạy từ lúc đó. Các bản trước bạn không thấy có lẽ là do bạn không để ý hay chưa activesync với PC. Mặc dù các bản rom của mình có tích hợp trong rom activesync killer nhưng cũng không thấy tác dụng. Thân.
what about activesync always on?
I think "Activesync allways on" is normal because when you do activesync with PC, it run from that time. Regard.
P/s: How about newer camera driver? can you send it to me?
BASSBOI
Hello, can somebod explain me a diference between 64 MB ROM support and 128 MB ROM support?
Can i upgrade my device (i have 64MB of memory) with ROM thaht support 128 MB ??
gxg
P/s: How about newer camera driver? can you send it to me?[/QUOTE]
no man... even after 1 day without using an computer, activesync is always started... I can close it 10 times / hour.. after 30 min in my pocket ỏ on the desk activesync is on and running.
and about the camera driver this is the latest one 0.33... quicker and nicer than previous 0.22.
http://www.pdaviet.net/attachment.php?attachmentid=93894&stc=1&d=1222377759
@ BASSBOI - 64 suports only clasic stoc devices. 128 you can only find as "cutomied" ỏ "tunned" devices. Made by other individuals than the factory.
zogger
Hi,
how can i install new camera driver on my device without changing rom?
thanks in advance
zogger
new camera driver
cool, ok i managed it by copying the new file in windows directory.
cam seems to work quicker now.
thanks
ps: perhaps i should try your rom, actually i am using WM 6.1 OS 5.2.19213 (Build 19213.1.0.4 DIVman). Are there a lot of improvments?
juliorocha
hi, i'm portuguese. Please see/correct de network setting... maybe for standard ROM!
Where is my country, and my operator? :-??
Great job. Congratulations! =D>
brk
Hi,
Yes, activesync was running all the time in in build 20748.
In this build the problem continues. I was not able to determine the cause for this. It occurs even when I don't connect the pda to the PC.
blazkom
What FW is now the best for use on asus p535, this or that that or the other.
How is 128MB ram or that the work on each 535
Thanks
Sorry for bad English.
