Black Diamond M2D CE_OS_5.2.20275(Build_20275.1.3.3)
swampy395
Black Diamond M2D CE_OS_5.2.20275(Build_20275.1.3.3)V3
This is based on my other rom it's fast,stable and very smooth,
Fixed battery status problem added USB_HDD back in Added Opal CommManager 2.7.1.8 with new graphics Added Bluetooth on/off Theres a Calendar shortcut on today screen, So I set the button1 calendar to this it's a quick way to switch BT on/off if you use bt headphones ECT.
Included in down load is the ExtROM and instructions it's been stripped to the bone just a couple of basic apps You DON'T need Opera Explorer for this just down load and follow instruction in "read_me_first.txt" and Enjoy M2D on BA
that's IT
M2D is based on explode CABs Edited a bit by me
No long winded blerb Try IT
If you do follow instruction then you will have a phone setup with contacts and MMS + provider settings ready to use
ExtROM
CAB: \Storage Card\ExtROM\01_HTC_Enchasements.CAB
CAB: \Storage Card\ExtROM\02_AudioManager_2.0_1819.1228.CAB
CAB: \Storage Card\ExtROM\03_HTCAlbum_2.0_1818.3032.CAB
CAB: \Storage Card\ExtROM\04_GoogleMaps.CAB
CAB: \Storage Card\ExtROM\05_HTC_Task_Manager_2.1_34837.5.CAB
CAB: \Storage Card\ExtROM\06_JBED_20080704_5.1.CAB
CAB: \Storage Card\ExtROM\07_Windows_Live_10.6.42.1900.CAB
CAB: \Storage Card\ExtROM\08_M2D_PIE_FIX.CAB
CAB: \Storage Card\ExtROM\09_ArcsoftMMS_5.0.70.24.CAB
CAB: \Storage Card\ExtROM\10_Manila2D_1.00_1819.2926-xplodeSY5.CAB
Before you load Your own apps I recomend you uncheck TouchFLO Plugin in "settings'Today'Items" Also set taskmanager to end programs by tapping "x" this will keep memory free
Please Would someone translate the intructions from the download to viet this will help with the íntallation Thanks in Advance swampy395
Thanks to Habubi and to Dvha79_ddt for there ROMs
Regards
SWAMPY395
V3 My Midas TouCH'ed Black Diamond
I found and used image files from these 2 Themes and re trimmed my Diamond Skins with gold
latest Versions of M2D in Extrom
A BIG THANKS to the XDA_TEAM Manilla2D Fantastic work guys
Thanks to S2W for his gold Theme here http://forum.xda-developers.com/showthread.php?t=425974&page=165
Thanks to JCKOTZE for his Theme here http://forum.xda-developers.com/showpost.php?p=2743216&postcount=2340
Included is M2DC customizer see here http://forum.xda-developers.com/showthread.php?t=427392
Download Touch"n"Gold ROM V3
http://www.4shared.com/file/68339430/3462797e/BA_M2D_CE_OS_5220275__Build_20275133_V3.html
Download M2D ROM V2
http://www.4shared.com/file/67344220/9ff640a9/BA_M2D_CE_OS_5220275__Build_20275133_V2.html
tampham
Hay quá cuối cùng đã có M2D cho BA, có bác nào sài cái này rồi không vậy, thế nào báo cho anh em thử chứ
TaQuangDuc
:)) did you see this thread, Mr. Hà =))?
I do not have BA to try this ROM, so anyone who did try this? Please comment smth abt it
Dvha79_ddt
Hê cậu này toàn lấy đồ trong ROM của mình cho vô mà chả nói 1 lời cảm ơn thậm chí là lấy toàn bộ mà không chỉnh sửa tẹo nào,trước hay post bên xda giờ nhảy qua post bên mình haa haa.
Đức ơi bản này cài Manila bằng file cab ngoài mà :)
thanget
Cái bản rom này dùng ko sướng bằng bản rom V14 - Black by Dvha79_ddt
ROM WM6.1 CE OS 5.2.19971 (Build 19971.1.2.6 PV DVH)
Dùng bản này máy chạy chậm cực kỳ hix :(
Và nói trước với mọi người ko hiểu sao bản này rất ăn pin, pin e 100% cài xong toàn bộ chạy được tầm 20 phút thì chỉ còn 71% ăn hơn cả bản V14 của anh Dvha79_ddt mà nhân tiện e cũng hỏi luôn sao bản V14 ăn bin hơn bản V13 vậy a Dvha bản V13 e dùng gần được 2 ngày vì nghe gọi liên tục còn bản V14 thi` chỉ được 1 ngày là hết pin rồi anh ah
Ah em vừa test thêm được là khi vào program bị delay tầm 3-4s, bật camera delay 3s, sử dụng WTaskbar thì phải cũng rất chậm phải delay 2s mới chạy được.
Thôi e lại quay về với bản V14 :D
TaQuangDuc
:D bạn này có tý "Tây tây"
em thì nghĩ là chạy được, và còn có thể tích hợp vào ROM anh chẳng bảo là có file cab là có thể cho vào ROM, nhưng chắc chắn là cực kỳ nặng, vì bản thân BA không phải là touch đa điểm, vì thế nên không thể đú đởn theo cái nhà anh Touch xịn được.
Mania 2D chỉ là xem cho nó thỏa mãn là đã dùng thôi bác nhỉ, rồi tất tần tật lại quay về với ROM cũ, ít soft tích hợp càng clean càng tốt (ít ra là cũng dùng BA rồi nên mới liều mình phán thế :D)
:p
PS: bạn gì bên trên, đồ họa đẹp mà, lại thêm nhiều ứng dụng chạy nền, nên pin nó hao là phải rồi (kiểu vista ăn nhiều pin hơn XP, XP ăn nhiều pin hơn windows 98 :D)
habubi
Có lẽ là do bạn cài thêm cả Extrom vào nên mới bị như thế.
Mình đã cài và đang test bản rom này (ko cài extrom vào). Mình thấy chạy nhanh, mượt.
Mỗi tội giống bản V5 của mình quá.
thanget
Không phải đâu a ơi e cài extrom này sang bản V14 của a Dvha chạy ầm ầm, lướt vèo veò, mà pin cũng như bt ko tốn lắm a ah. E chỉ bỏ bớt mấy cái window live với mấy thứ linh tinh thôi anh ơi. Còn e cài thử trên rom này cực kỳ chậm anh ah, chả hiểu sao luôn
swampy395
English PLEASE
Hi guys hope you are enjoying this I only speak english If someone could translate the basic comments for me please I tryed the web translators "not so good"
AnhPheCT
Bản Rom Black Diamond M2D for Exec: diapad có thêm nút TalK đẹp và tiên lợi hơn Bản Rom Touch Flo Manilla 2D của Atom thường. Chúc mừng Atom Exec!!! Bản này Pro quá!!
tampham
Sao bạn này nói nghe mâu thuẩn vậy, cài vào "chạy ầm ầm, lướt vèo vèo" rồi sau đó "cực kỳ chậm" là sao hả bạn:-/
saokywa
that's IT
ExtROM
Regards
SWAMPY395
Download M2D ROM
http://www.4shared.com/file/66682975/889f8758/BA_M2D_CE_OS_5220275__Build_20275133_.html
mirro link to mediafire plz, thanks pro.
TaQuangDuc
they said that: this ROM to slow, some people get hang while opening an application, the battery come to end so quick, but the design so nice and they love this theme. Can you make other ROM lighter with this interface?
Many thanks
sorry my terrible English.
PS: these all happen after install the ExtROM
ah, I forgot an important comment, Dvha79_ddt said that: You used to use his ROM, ROM interface to build your own ROM but you never talk abt him or say thank to him. :D
hnyuk49
I think this rom is fast without the Malina2D. Will try it for some more days with some more apps installed and tell ya later. thank you.
kaka_86
dạo này mấy ông tây vô diễn đàn nhiều gê ta...không biết chất lượng thế nào nên chưa UP vội.Mấy anh UP trước cho kết quả đi nào.
Em cài IFONZ 1.04 vào Rom anh HABUBI đang chạy giống iphone nên đang sướng.hehe:D
habubi
Có thể là do sự tương thích của các soft trong Extrom này với bản rom V14 của anh Hà cao hơn so với chính bản rom này chăng.
