BLACKSTONE - PDAVIET ROM WM6.5 (Core 23502) by T2M
sternas
My report
-NO Video Call (GO-NO-GO)
-Sync Problem (GO-NO-GO)
-3M Camera
-Very large start icons
-Stability problems (3 Soft Reset in 30 minutes)
+Best WM6.5.x theme (amarullz Green Black)
Thanks ....
TranMinhMan
My report
-3M Camera
Thanks ....
Tks for your feedback, sternas!=D>
I will check these, may be some OEMs from Leo and Rodium not fix with Blackstone. I will try my best in next Rom!:D
Sonblack
Hi;
Vẻy go od rom but I have to tủn back, because thre í bug. When I connect úb cable and select u sb disk, nothing happens...
Exactly! This is simply problem! I think he will fix it in next rom. :D Here you are:
[HKEY_LOCAL_MACHINE\Drivers\BuiltIn\SDHC]
"Flags"=dword:00000000
"DMAChannel"=dword:00000000
"DMAIrq"=dword:00000024
"DMA_IST_Priority"=dword:00000096
"SDIOIrq"=dword:0000001E
"SDIO_IST_Priority"=dword:00000097
"PollingTimeout"=dword:00000100
"CardDetect_Thread_Priority"=dword:00000098
"CardDetectGPIO"="F"
"CardDetectMask"=dword:00000020
"CardDetectFlag"=dword:00000000
"CardDetectControlMask"=dword:FFFFF3FF
"CardDetectControlFlag"=dword:00000000
"CardDetectPullupMask"=dword:FFFFFFDF
"CardDetectPullupFlag"=dword:00000020
"CardReadWriteGPIO"="H"
"CardReadWriteMask"=dword:00000100
"CardReadWriteFlag"=dword:00000100
"CardReadWriteControlMask"=dword:FFCFFFFF
"CardReadWriteControlFlag"=dword:00000000
"CardReadWritePullupMask"=dword:FFFFFFBF
"CardReadWritePullupFlag"=dword:00000040
"HandleBusyFinishOnCommand38"=dword:00000001
"DmaTransferTimeoutFactor"=dword:00000008
"DmaTransferTimeoutConstant"=dword:00003000
"IsCardInserted"=dword:00000001
"IClass"="{8DD679CE-8AB4-43c8-A14A-EA4963FAA715}"
"Prefix"="SDH"
"Dll"="sdhc.dll"
"Order"=dword:00000021
"RecoveryMoviNAND"=dword:00000000
Please add to registry in PPC and soft reset. You can copy above registry to file and use tool in rom to add them.
BatKid
Nhớ kg lầm là anh Mẫn hứa để dành bản này cho ngày SN mà ??? >"< vậy 8/11 tới đây anh show bản nào cho em nào Blackstone hay Polaris ???
Không hiểu sao cứ vào topic rom nào của anh Mẫn cũng có cảm giác đi lạc sang XDA ^^ , lúc nào cũng phải mở goole tran lên , hix hix
agan_yq
It's so strange for me, I don't have any problem. I have test this Rom in one week, before uploading on forum.
If I turn off the HTC Sense, the mesage would work as you show. It semed the htc mesage was loaded diferent, really strange.
agan_yq
another more stange problem, the weather 'snow' in hơme screen would cause the device to freezed(snow in my location today, and I tried serval times of reset to my phone, not work), I had to change the city show in home screen to another city today.:-?
tfe2000
"Prefix"="SDH"
"Dll"="sdhc.dll"
Thank you vẻy much for yor quick reponse. I will try it.
rockychan2988
Em xin có chút nhận xét là bản này anh làm hơi ít nút back , nhiều khi khá bất tiện để quay lại trang trước
Lâu lâu lại có lỗi nhỏ như ko vào được Start hoặc 1 vài soft như Vietmap R12
Màn hình lock screen khi mở màn hình lên phải chờ vài giây mới slide unlock được
Chỉ là chút nhận xét chủ quan của em , ko có ý gì khác , bản ROM này em thấy chạy tốt
TranMinhMan
Cứ mạnh dạ̣n lên chứ bạ̣n, chúng ta góp ý theo hướng xây dựng để tốt hơn mà!:D Cảm ơn những nhận xét của bạn!=D>
Những điều bạn nói có phần đúng đấy, ít nút back nhưng đó đều là các ctr được chiết xuất từ Rom Ship mới nhất cho Touch HD2 (HTC Leo) đấy, có lẽ bạn dùng chưa quen. Vài soft chưa tương thích là do các Core này vẫn là core Beta theo cấu trúc mới, nó vẫn trong giai đoạn phát triển nên còn vài vấn đề. Nhưng theo mình thì nó đáng để chúng ta trải nghiệm đó chứ!!!:p:D
rockychan2988
Đúng có nhiều cái đang để trải nghiệm , em rất thích các soft kèm theo bản ROM này , thanks anh , mạn phép hỏi bản ROM kế tiếp khi nào anh sẽ release vậy :D
