manhnguyenvn
Thấy dạo này không có ai post CFW cho X6 cả, mình post bản đang dùng cho ai thích.
Bản này Cook lại dựa trên bản Nokia X6 - Photon C6-03 - The Fastest Firmware - Final Released!
http://forum.smartphonegeeks.in/index.php?topic=7.0
Vài hình ảnh
Một số chỉnh sửa
- Thêm tiếng Việt (mặc định)
- Thêm âm lịch
- Thêm music timer vào trình nghe nhạc
- Bản đồ Ovi Map 3.06
- Hiệu ứng bong bóng
- Tap to unLock
- Mod 4G
- Âm thanh, hình ảnh khi khởi động E:/Boot/Startup.mp3 Startup.gif
- Thư mục bảo mật E:/MNG
Cảm nhận chủ quan
- Ram khi ổn định, mở hiệu ứng... 42MB
- Nhanh, nhẹ nhàng
- Chưa phát hiện ra bug nào cả
Binh24 C6 Ported Core Files
Rofs2
Vài hình ảnh
[PASS][HIDE]=====================
Performance Upgrades:
- Highly Increased Application/Gaming frame rates
- Increased Response Rate (Now touchscreen will be more responsive)
- CPU frames render was increased.This will result in a smooth phone experience.
- Graphical Complexity reduced. Performance Booster without any side effects.
- Music Player response highly increased (Instantly pauses/plays on clicking the buttons)
- Reduced effects complexity which should result in a speed increase
- Increased Heap Size further to boost up performance
- Lags in Menu, messaging and Other Large Applications removed
- Polished the UI for heavy usage
- Phone will never slow down and the RAM won't be decreasing (RAM Caching modded)
- 80MB+ on C:\ (Phone memory)
- Free RAM after startup : 64.5MB in 5800, 70.8 MB in 5233 (Maximum)
- Average RAM: 60-65 MB free
- Smooth Kinetic Scrolling
- Music Player is now a lot more faster!
- Real Hack! (No need to use installserver.rmp patch anymore)
- CPU mod optimized to get complete stability and a great battery life!
General Modifications :
- "Restart" Option instead of "Lock Screen and Keys" in Power Menu by CODeRUS.
- Full N8 IconPack is used. (With 0 bugs) Now icons change according to the theme applied.
- N8 Swipe to Unlock theme and N8 dialer added.
- PC/OVI Suite will recognise your phone as Nokia C6-00. However every website including OVI Store will recognise your phone as Nokia N97 mini
- All C6 lights problem fixed. (Mod by mara)
- Camera will not eat RAM after closing it.
- Default Browser user agent changed to the one of N97 mini. So OVI store and some other sites will recognise your phone as Nokia N97 mini
- C5-03 Keyboard Layout added.
- Female Voice (Ellen) added in Message Reader app.
- Camera Sound will be disabled if you use Capture Tone 3.
- "Nokia Tune" from N8 added.
- Display lights timeout and automatic keyguard time set to 30 seconds.
- Default bluetooth name: Nokia Photon C6-03
- FOTA reserved space romoved to get more space in C:\ (Phone Memory)
- USB now will name as Nokia Photon
- Voice recording during call fixed. Your phone won't crash if you record and call someone at the same time.
- RAM Cache in C:\ for better performance
- Blazing Fast Screen Rotation
- CPU load decreased (Get a very fast phone)
- Enabled lock/unlock vibration
- Disabled My Nokia Service
- Zero start up of background applications
- Auto optimization of RAM cache for keeping up your phone faster even after heavy usage
- Default Web Browser bookmarks are edited.
- Blank UDA supplied to get highest possible free space on C:\
- Lags in Menu removed. The Kinetic Scrolling is optimized (It is no very fast not very slow)
- Display rotation is ON by default
- Breathing light is OFF by default
- Digital clock set as default. N8 Clock fonts used so the digital clock now looks like the N8 clock
- Display light turns OFF and Phone gets locked in 30 seconds
- Default Fonts Used
- Operator Logo ON/OFF settings available in homescreen settings
- Delivery Reports ON by default in Messaging
- Theme effects are OFF by default
- Removed "Check for Updates" in Device Updates
- "Summary after call" and "speed dialing" ON by default
- "In call timer" ON by default
- Profile "General" renamed to "Photon"
- Homescreen landscape enabled. Dialer landscape disabled
- Lags in Messaging apps removed[/HIDE]
[/PASS]
[/PASS]
Một số chỉnh sửa
- Thêm âm lịch
- Tap to unLock
- Mod 4G
Cảm nhận chủ quan
- Nhanh, nhẹ nhàng
Rofs2
