chanhkho1908
[video=youtube;bugUfRLBLk0]http://www.youtube.com/watch?v=bugUfRLBLk0&feature=player_embedded[/video]
NEW FEATURES:
Automatic key rotation (alphanumeric QWERTY).
Based on the latest versions of firmware 5230 (v21), 5530 (v32), 5800 (V52), X6 (v30).
Ovi maps and supporting integrated 6.3 to download maps from the Field.
Rotate the slide release.
New integrated Reset option in the options by pressing the Power Button.
Integrated Nokia app notifications, so you can see all activity on your phone in a single widget.
Message Reader in Spanish.
All Nokia N8 icons now change if you change the subject.
Media bar icons change when you change the subject.
Fixed error “Camera in use” when taking a photo.
Music Player v15.2 integrated with lyrics display.
If you close an application releasing RAM memory is cleared again.
Solved the problems when installing QuickOffice.
New Sounds in Nokia’s exclusive C7 Interface.
Features
interactive or Desktop with Widgets.
or Languages: English and Spanish Latino 5230 5530 and 5800, (Spanish Spain) RM-559 and the 5800 version.
or You can install anything you want without signing applications, or perform any process, no more expired license!.
or integrated mail client with support for all your Hotmail, Gmail, Ovi, etc.
Unlock and unblock or horizontal Swipe added.
New type of power or much more modern and fitted with the new menu, the original source is huge !!!!!!!!.
Menu 4×4 or reorganized and custom folders.
Added 3 new widgets and shortcuts so you can get full screen access.
or 79 MB free internal memory and 58 MB free RAM.
o Clock Widget is now removable so you can remove it and have a Full Swipe.
Removed the poster or display all open applications on the drop down menus.
or Java applications and bring all permits WRT enabled to avoid so many unnecessary requests.
You can send any file or protected by Bluetooth, no more restrictions.
Added new codecs or audio for better sound stereo.
or sound much stronger than the original firmware.
Added conversations or SMS.
o In the Ovi mobile is identified as a Nokia N97 so have many more programs compatible.
or improved without delay effects.
Added Facebook equipment or tactile browser bookmarks.
Gallery or reconfigured to not read images in system folders.
Image or Dark S60 start with the sound a bit low not to disturb.
or delete some applications start to have more free resources.
Cache Browser or increased and moved to E
Test đi anh em
CFW SYMBIAN^3 v6 Nokia 5230
http://www.multiupload.com/A7PLKUE11A
http://www.multiupload.com/501MGD1TGK
http://www.multiupload.com/0T7RWEITT4
http://www.multiupload.com/JCDUNJV4NE
http://www.multiupload.com/NV36KSJKKI
Bản này bị xóa mất OVI store, ai muốn dùng thì sau khi flash cài file này luôn nhé
[=========> Bổ sung bài viết <=========] 7 minutes:
Ai mod thêm tiếng việt hộ anh em cái đi
Cài thêm OVI sau khi flash nhé
http://www.mediafire.com/?52vgog9zyc611ya
