nguyenhung15692
:-? các bác cho e hỏi mấy bản cfw với mấy bản photon có gì khác nhau
flash duoc r flash lại bị như z nek
JAF version 1.98.62
Detected PKEY: 9000AAC9
Card life counter: 99.99%
USB Cable Driver version: 7.1.48.0
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-559\
Checking path: \Products\RM-559\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-559\RM-559_40.0.002_prd.core.C00
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-559\RM-559_40.0.002_prd.rofs2.V20
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-559\RM-559_40.0.002_C01_prd.rofs3.fpsx
APE Variant file: C:\Program Files\Nokia\Phoenix\Products\RM-559\RM-559_32.0.002_001_000_U001.uda.fpsx
Languages in ppm: English,Vietnamese,Tagalog,Chinese Simpl,Chinese Trad
Detected P-KEY: 9000AAC9
Init usb communication...
PRESS POWER ON NOW!
Searching for phone...Found
Sending RAW loader...
Using |Õúÿ012.005
Elf2flash 09.11.000
CMT RAW loader...
Patching RAW boot step1...
Patching RAW boot step2...
Patching RAW boot step3...
Sending RAW Loader...
....................Loader Sent!
Stage 2 starting................PUBKEYS already sent...
..........Phone prepared OK!
Waiting for the phone to boot...
Status byte: 8000
Selecting CMT flash...
Result: 0000
Phone is in flash mode...
CMT blocks: 671, APE blocks: 0
Erasing cmt...
Processing C:\Program Files\Nokia\Phoenix\Products\RM-559\RM-559_40.0.002_prd.core.C00...
Erasing cmt zone 00040000 - 00082FFF ... Erase result: 0000
Erasing cmt zone 00083400 - 003FFFFF ... Erase result: 0000
Erasing cmt zone 00400000 - 007FFFFF ... Erase result: 0000
Erasing cmt zone 00800000 - 00D5FFFF ... Erase result: 0000
Erasing cmt zone 00D60000 - 0B71FFFF ... Erase result: 0000
Partition result: 0014
Processing C:\Program Files\Nokia\Phoenix\Products\RM-559\RM-559_40.0.002_prd.rofs2.V20...
Erasing cmt zone 02EC0000 - 0B61FFFF ... Erase result: 0000
Send CMT CFG...
Writing cmt...
Sending CMT HASH for ADA
Sending CMT HASH for KEYS
Sending CMT HASH for PRIMAPP
Sending CMT HASH for RAP3NAND
Sending CMT HASH for PASUBTOC
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending...
cmt->PAPUB keys already sent...
Sending CMT HASH for SOS*UPDAPP
Sending CMT HASH for SOS*ENO
Sending CMT HASH for SOS*DSP0
Sending CMT HASH for SOS*ISASW
Sending CMT HASH for SOS+CORE
Sending CMT HASH for SOS+ROFS1
Sending CMT HASH for SOS+ROFS2
Write result 27: 1701
Rebooting...
Finishing CMT session...
Restarting CMT...
Pooling phone...
MCUSW: (null)
APESW: (null)
VariantSW: (null)
Prodcode:
Setting test mode...
Failed! Aborting!
Done!
k mở máy duoc nua roi...minh dùng x6 file tap to unlock
yahoo:nh0x_nghj_nh0x_can_p3_pen_nh0x
đổi lại roi nhung vẫn như z (APE Variant file: C:\Program Files\Nokia\Phoenix\Products\RM-559\RM-559_32.0.002[/SIZE][/SIZE]_001_000_U001.uda.fpsx
đổi lại thành 40.0.002 rồi flash lại thử xem
bạn hay dùng tới chứ người khác có hay dùng tới không?mà cái này có thể cài vào mà?Bản 05 sửa lỗi bluetooth với anh tùng ơi, mà anh nên chèn thêm killme cái này cũng hay dùng tới
mình cũng mới vùa jaf bản tap to unlock cho x6 v40 chìu nay.nhưng ok.ko có j xảy ra.bạn ko cần đồi tên file .uda.fpsx đâu.jaf lại mà ko đc thì tháo pin ra,chờ tới lúc bật nút nguồn thì cho pin vào(nhanh tay lên nhé).k mở máy duoc nua roi...minh dùng x6 file tap to unlock
Chuẩn, mình cũng chằng bao giờ dùng cái killme ấy, app ở bản 04 ko thừa ko thiếu, bản 05 bạn Tùng chỉ cần fix các lỗi ở bản trc là okbạn hay dùng tới chứ người khác có hay dùng tới không?mà cái này có thể cài vào mà?
Thử bấm 12345 xem sao bạnsa0 nhấn *#7370# nó đòi mã pin, sa0 đây ta ?
bạn cho mình xin cái mod đó được hok?
Quote thông minh vậy bạn?bạn cho mình xin cái mod đó được hok?
hix! bên daily cho releases bạn ơi! phải 1000 thanks ngta mới share! ae sang đó thanks đi để ngta share rồi đem về mod lại! link cho mình ghi nguồn đó!bạn cho mình xin cái mod đó được hok?
[BELLE MODIFICATION PACK, s60v5!!!1!1!11] UNIQUE, Ultimate Navi Bar by Caciones
http://forum.dailymobile.se/index.php?topic=59143
