CFW Vietnamese-04 (CFW Belle V2) for X6 /5530 /523x /5800 by ThanhTungHT (02/11/2011)
b0ngma01
Sau khi chạy = JAF thì bị lỗi tới đoạn Local mode là đứng im đó luôn, tắt không được mà phải tháo PIN ra khởi động lên thì được nhưng có cảm giác có lỗi gì đó. Bác nào biết giúp em với ạ. Em dùng Nokia X6 - RM559. Và đây là Log JAF
JAF version 1.98.62
Detected PKEY: 90009B6C
Card life counter: 99.99%
USB Cable Driver version: 7.1.48.0
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Checking path: C:\Program Files (x86)\Nokia\Phoenix\Products\RM-559\
Checking path: \Products\RM-559\
Scanning ini files...
MCU Flash file: C:\Program Files (x86)\Nokia\Phoenix\Products\RM-559\RM-559_40.0.002_prd.core.C00
PPM Flash file: C:\Program Files (x86)\Nokia\Phoenix\Products\RM-559\RM-559_40.0.002_prd.rofs2.V20
CNT Flash file: C:\Program Files (x86)\Nokia\Phoenix\Products\RM-559\RM-559_40.0.002_C01_prd.rofs3.fpsx
APE Variant file: C:\Program Files (x86)\Nokia\Phoenix\Products\RM-559\RM-559_32.0.002_001_000_U001.uda.fpsx
Backing up CRT...
Detected P-KEY: 90009B6C
Init usb communication...
Failed to backup CRT...
PRESS POWER ON NOW!
Searching for phone...Found
Sending RAW loader...
Using |Õúÿ012.005
Elf2flash 09.11.000
CMT RAW loader...
Patching RAW boot step1...
Patching RAW boot step2...
Patching RAW boot step3...
Sending RAW Loader...
....................Loader Sent!
Stage 2 starting................PUBKEYS already sent...
..........Phone prepared OK!
Waiting for the phone to boot...
Status byte: 8000
Selecting CMT flash...
Result: 0000
Phone is in flash mode...
CMT blocks: 673, APE blocks: 0
Erasing cmt...
Processing C:\Program Files (x86)\Nokia\Phoenix\Products\RM-559\RM-559_40.0.002_prd.core.C00...
Erasing cmt zone 00040000 - 00082FFF ... Erase result: 0000
Erasing cmt zone 00083400 - 003FFFFF ... Erase result: 0000
Erasing cmt zone 00400000 - 007FFFFF ... Erase result: 0000
Erasing cmt zone 00800000 - 00D5FFFF ... Erase result: 0000
Erasing cmt zone 00D60000 - 0B71FFFF ... Erase result: 0000
Partition result: 0014
Processing C:\Program Files (x86)\Nokia\Phoenix\Products\RM-559\RM-559_40.0.002_prd.rofs2.V20...
Erasing cmt zone 02EC0000 - 0B61FFFF ... Erase result: 0000
Processing C:\Program Files (x86)\Nokia\Phoenix\Products\RM-559\RM-559_32.0.002_001_000_U001.uda.fpsx...
Erasing cmt zone 0B720000 - 1EF7FFFF ... Erase result: 0000
Send CMT CFG...
Writing cmt...
Sending CMT HASH for ADA
Sending CMT HASH for KEYS
Sending CMT HASH for PRIMAPP
Sending CMT HASH for RAP3NAND
Sending CMT HASH for PASUBTOC
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending...
cmt->PAPUB keys already sent...
Sending CMT HASH for SOS*UPDAPP
Sending CMT HASH for SOS*ENO
Sending CMT HASH for SOS*DSP0
Sending CMT HASH for SOS*ISASW
Sending CMT HASH for SOS+CORE
Sending CMT HASH for SOS+ROFS1
Sending CMT HASH for SOS+ROFS2
Write result 27: 1701
Rebooting...
Finishing CMT session...
Restarting CMT...
Pooling phone...
MCUSW: (null)
APESW: (null)
VariantSW: (null)
Prodcode:
Setting test mode...
Failed! Aborting!
Done!
coc3k
đó là fw gốc chứ có phải cfw đâu mà ra bản mới.nếu bạn mún thì có thể tải về mà dùng mà
thì ý của mình là a tùng sớm ra bản cfw cho fw gốc mới này cho ae xài với
winbi2009
Bác Tùng Ơi!
Firmware bị lỗi không vào được Ovi Store rồi đã cài bản mới của Ovi nhưng không vào được.
Mong bác Fix giúp.
Thank
vcoin1000
Cái này mình gặp rồi.Bạn khỏi đông lại máy vi tính.Sau đó JAF lại là ok
master09
bạn nào fix hộ mình cái thanh mediabar này với, mình làm kiểu gì cung không đc. có 5 shcut thì cái hình ảnh lại không vào đc ấn nó không nhúc nhích, 4 cái kia thì vào đc. chính xác thì nó bị sai UID nhưng mình thay đúng UID thì nó lại vào đc, nhưng icon thì không hiển thị mất hết 5 icon trên mediabar vẫn ấn vào bình thường, giúp mình với. http://www.mediafire.com/?gdpt67vu15jjasg 5
tranconghd89
bạn thử cái này http://www.mediafire.com/?n6t7s8tpwhpkyvh
coc3k
cho mình hỏi tý giờ mình đã update cho 5233 lên phiên bản mới rồi giờ mình có thể đổi tên lại và jaf lại bản này đc không
NTiolanDatluu
bạn download RM-625 V51.1.002 New Core by Binh24 rồi down file ROFS2 đổi thành: RM-625_50.1.001_prd.rofs2 > RM-625_51.1.002_prd.rofs2
Thanh Tùng ơi!
Nếu dùng Core RM-625 V51.1.002 New Core by Binh24 thì ROFS2 FILE 5233 RM-625 "CFW Vietnamese-04" phải đổi lại tên gì mới JAF được anh Tùng.
P/S: Good luck JAF :D
