CFW Vietnamese-05 (Nhanh-Mượt) for X6 /5530 /523x /5800 by ThanhTungHT (18/02/2012)
rastar
Banned
Mới flash FW này hôm qua, hôm nay flash lại thì bị lỗi này 8-|
JAF version 1.98.66 beta5
Detected PKEY: 9000AAC9
USB Cable Driver version: 7.1.69.0
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-625\
Checking path: \Products\RM-625\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-625\RM-625_51.1.002_prd.core.C00
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-625\RM-625_51.1.002_prd.rofs2.V20
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-625\RM-625_51.1.002_C01_prd.rofs3.fpsx
APE Variant file: C:\Program Files\Nokia\Phoenix\Products\RM-625\RM625_51.1.002_000_001_U001.uda.fpsx
Backing up CRT...
Detected P-KEY: 9000AAC9
Init usb communication...
Failed to backup CRT...
PRESS POWER ON NOW!
Searching for phone...Found
Sending RAW loader...
Using NÍ»‰012.005
Elf2flash 09.11.000
CMT RAW loader...
Patching RAW boot step1...
Patching RAW boot step3...
Sending RAW Loader...
....................Loader Sent!
Stage 2 starting............PUBKEYS already sent...
........Phone prepared OK!
Waiting for the phone to boot...
Status byte: 8000
Selecting CMT flash...
Result: 0000
Phone is in flash mode...
CMT blocks: 610, APE blocks: 0
Erasing cmt...
Processing C:\Program Files\Nokia\Phoenix\Products\RM-625\RM-625_51.1.002_prd.core.C00...
Erasing cmt zone 00040000 - 00082FFF ... Erase result: 0000
Erasing cmt zone 00083400 - 003FFFFF ... Erase result: 0000
Erasing cmt zone 00400000 - 007FFFFF ... Erase result: 0000
Erasing cmt zone 00800000 - 00D5FFFF ... Erase result: 0000
Erasing cmt zone 00D60000 - 09E5FFFF ... Erase result: 0000
Partition result: 0014
Processing C:\Program Files\Nokia\Phoenix\Products\RM-625\RM-625_51.1.002_prd.rofs2.V20...
Erasing cmt zone 02E80000 - 09D5FFFF ... Erase result: 0000
Send CMT CFG...
Writing cmt...
Sending CMT HASH for ADA
Sending CMT HASH for KEYS
Sending CMT HASH for PRIMAPP
Sending CMT HASH for RAP3NAND
Sending CMT HASH for PASUBTOC
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending...
Sending CMT HASH for SOS*UPDAPP
Sending CMT HASH for SOS*ENO
Sending CMT HASH for SOS*DSP0
Sending CMT HASH for SOS*ISASW
Sending CMT HASH for SOS+CORE
Sending CMT HASH for SOS+ROFS1
Sending CMT HASH for SOS+ROFS2
Write result 27: 1701
Rebooting...
Finishing CMT session...
Restarting CMT...
Pooling phone...
MCUSW: (null)
APESW: (null)
VariantSW: (null)
Prodcode:
Setting test mode...
Failed! Aborting!
Done!
Không biết có phải tại CFW cũ là v51 bằng với V51 này nên nó không cho flash không nữa :ar!
nhattoan25
Em dùng 5233 em muốn flash thì em tải CORE 5233 RM-625 V51.1.002 by Binh24 và ROFS2 FILE 5233 RM-625 "CFW Vietnamese-05"
+ Lịnk Swype to unlock
+ Lịnk Anna Tap to unlock
Phải không anh Tùng:D, ai biết hướng dẫn em luôn nha
tu_vjp_pr0
Sao mình flash bản này xong bây h máy kô tự khóa phím cũng như tắt đèn màn hình nữa mà phải làm thủ công ?
Radium
bạn tải core và link swype hoặc tap to unlock về rồi flash
hotboy_sl9x
Giúp đỡ mình với. Kô biết mình chỉnh sửa file nào mà như thế này các bạn:
Writing cmt...
Processing C:\Program Files\Nokia\Phoenix\Products\RM-588\RM-588_51.0.002_prd.core.C00...
cmt->PAPUB keys already sent...
Processing C:\Program Files\Nokia\Phoenix\Products\RM-588\RM-588_51.0.002_prd.rofs2.V20...
Processing C:\Program Files\Nokia\Phoenix\Products\RM-588\RM-588_51.0.002_000_001_U001.uda.fpsx...
Rebooting...
Restarting CMT...
Pooling phone...
MCUSW: (null)
APESW: (null)
VariantSW: (null)
Prodcode:
Failed! Aborting!
Done!
Cảm ơn nhiều!
mình cũng bị giống bạn không hiểu tại sao nữa. nhưnng bạn tháo pin ra khởi động lại là dùng được, chắc không sao đâu
squallmtv
Mình cũng dùng cái đó. Vẫn bình thường. Lúc chạy bạn có cho nó nằm trong ổ C k?
Mình làm được rồi , có lẽ do mình lưu Nokia Firmware Editor trong folder mà folder này có bỏ dấu tiếng việt nên bị lỗi như thế , cám ơn tất cả các bác , chúc vui vẻ :D=D>
coc3k
E tìm bản CFW C6 Final của a ấy,Rồi tìm kiếm với từ Cam trong Rofs2,rồi Copy toàn bộ ném sang bản này nhé ! Ko cần tách .txt/
e tìm google rồi mà không thấy bản c6 của a a tùng a còn cái link không cho e cái link đi. thank a
sonYH
cho e hỏi code may e là 0589730 , e down core ở #1 về thấy code là 0585714 nếu cứ flash thì liệu có sao ko hả bác
coc3k
ai có mod fix lỗi ỡ camera là khi vào cài đặt chọn chế độ chụp cảnh sau đó chọn người dùng xách định thì đt sẽ báo lỗi là xãy ra lỗi ngoài ý muốn khỡi động lại đt cho mình với thank trước
barracuda
core của binh24 bị lỗi nên như thế,cứ dùng đi ko sao đâu
Khoaaaa
Bản này ổn thật,hiệu suất dùng wa time dài ko hề thay đổi,và chưa hề lòi lỗi nào ảnh hưởng nhu cầu của mình,mỗi tội ram hơi bất ổn,pin với mình thì vầy là wá tốt,anh tùng sớm up bản non unlock nha,dc thì cho nó biến thể xíu,như là cho thêm vài cái nhạc chuông lạ,effects khác xí,kiếm cái themes nền sáng nào nhẹ cho vào room luôn,v5 già rồi,mà cứ đen xì woài củng hơi chán,hì
firerock07
mấy cái file nhạc chuông để chỗ nào vậy bác khi đổi nhạc chuông nó ko tìm ra. Em ko muốn để chung với mấy cái bài hát của mình.
nuluku
bị lỗi menu hả bồ, menu ngang chỉ có nửa icon.
flash 3 lần lần nào cũng bị vậy
