[CLEAN ROM] XDA ATOM/ATOM PURE - PDAVIET ROM WM6.1 (Core 20764)
Sonblack
PDAVIET ROM WM6.1
CE OS 5.2.20764 Build 20764.1.4.3 PV
=== Only for XDA ATOM / ATOM PURE ===
Lời cám ơn - Thanks:
Super Mod PhamQuang
Super Mod BatKid
Admin Kawaguchi
Adv. Mod Dvha79_ddt
Mod Lamson, TranMinhMan, Hoangdat_vista
Trial Mod PhamNhatThanh, khacduy1978, nhattoai
VIP Medkid, nhocbanme
Thông tin - ROM Information:
- CE OS 5.2.20764 Build 20764.1.4.3 PV
- Pagepool: 6M
- Rom date: December 8, 2008
- ROM Version: 20081208D6WWE
- Well supported A2DP (modules from my ROM 19212) now (Thanks to nikworld07 and
BatKid again)
- Transcriber included.
- Remove all help files.
- XIP & SYS from xbeta.cn (It said they're from original ROM of BlackStone but I'm not sure)
Hình minh hoạ - Illustrative Images:
Chức năng chính - Main functions:
- JBlend Java v3.3.5 Build 20081015.1.1 (Jade)
- Comm Manager v2.7.2.8
- ArcsoftMMS v5.0.31.63 (Elfin)
- Enlarge Start Menu (Moderate from Elfin)
- Enlarge TitleBar (Elfin)
- HTC Sim Manager for Pocket PC v6.58
- .NET Compact Framework 3.5.7283.0
- Windows Media Player 10.3 Build 20764
- Office Mobile 6.1
- Office Note
- SIPChange (automatically run)
- Advanced Configuration Tool v3.3 by Schap
- ClearTemp v1.1 by Vicott Wong
- PIM Backup v2.8.0.0 by FdcSoft
- Pocket Screen v1.3 by JJM. Roseboom
- Synchro Time v0.95 by Dennis Grachov
- WM5torage v1.8 by V. Bozhko
- WKTask v1.2.0.0 (open/close applications fastly)
- Network Wizard for PocketPC v1.0 (Build 29982.1.0.1.7) (support Mobifone, Vinaphone, Viettel for setting GPRS configuration)
Hướng dẫn - Guides: Vui lòng đọc kỹ - Please read carefully
Chỉ cần tải file .exe chứa ROM, chạy file .exe trên PC và làm theo các bước chương trình yêu cầu cho đến khi hoàn tất. PPC của bạn sẽ tự hard reset khi mọi thứ hoàn thành.
The only thing you have to do is download the .exe file including ROM and perform a double click on it (off course, on PC), then follow the guide step by step that the program requires until it finishes. At the end, your Atom will automatically perform a hard reset.
Link đã có sẵn - The link is available now
Link nằm trong file đính kèm ở cuối bài - Link put under attached file at the end of this post
UP ROM VỚI TÙY CHỌN "OS+ExtendedROM".
FLASH THE ROM WITH OPTION "
OS+ExtendedROM".
Note - Lưu ý:
Để tải ROM, các thành viên sử dụng Username và Password chung là PDAVIET
To download the ROM, use both Username and Password PDAVIET
Chúc vui!
Enjoy it!
Sonblack
asazami
hehe lai sap có room mới, lần này rom clean luôn, mong chờ có link down quá hehe. mở hàng cho bác Sơn :D
Atomo2
Anh em nào trước giờ luôn cần clean ROM thì đã được chìu chuộng rồi nhé. (Hình như đây là bản Clean đầu tiên Bro SONBLACK tạo cho AE phai ko nhỉ?) Đa dạng sản phẩm cho người dùng nhé.Thanx
umpol2008
Can you make this ROM support Thai Lang? I saw Thai support in "CE OS 5.2.20273 Build 20273.1.3.3 Khoa_Ha" so i would like to see it in your new ROM. Thank you very for sharing the world.=D>
KiD2034
Chỉ cần Rom của Anh Sơn cho dù Clean hay Dirty em đều ủng hộ :D
Anh Sơn ơi KeyBoard của bản cũ anh đem bán rùi , anh mua lại chưa dạ??? :p
pure
theo mình nghĩ đã bản clean rùi thì không nên tích hợp những thứ này vào chi cả!:-?
tuananhg
Những cái đó mình thấy quan trọng sao bạn lại nói bỏ , được voi đòi tiên chỉ khổ anh Sơn Black thôi
Nếu muốn thì bạn hãy tự học cách Build Rom để vừa với ý của mình:))
Sonblack
Nói thẳng cách dùng PPC quan trọng hơn những điều tưởng như rất quan trọng. Pó chiếu... Các bạn hiểu Clean như thế nào? Clean là trống trơn, sạch sẽ hả? WKTask mà còn đòi bỏ luôn thì hết chỗ chê rồi =))
pure
Tại sao không? Ta vẩn có thể dùng tốt các phần mên khác tự thêm vào mà chẳng hạn như tôi ví dụ là x-botton của htc hay wisbaradvanced chẳng hạn.! THẬT LÀ ...
pure
Đây là ý kiến chủ quan của mình để thảo luận thôi chứ không phải muốn cãi nhau về cách builrom nha!X-(
Sonblack
Có lẽ bạn chưa hiểu hết vấn đề, Atom không phải HTC nên không support hoàn toàn HTC Task Manager. Với tất cả các thiết bị của HTC tôi đồng ý, với Atom thì không! Với các version từ 2.0 trở lên Atom, chạy ì ạch thôi. Cả cái soft bạn kể thêm. Thật là gì... thì là quyền của bạn, tôi chỉ share chứ không phải là bắt buộc phải làm cho mọi người. Nếu không muốn, tôi cũng chẳng cần share và cũng chẳng cần mất thời gian vào mấy cái rom này làm gì vì rằng BQT diễn đàn cũng đâu bắt tôi phải làm. Chẳng qua tôi thích cải tiến cho con Atom của riêng mình thêm sinh động rồi post lên cho mọi người dùng chơi.
Chào mọi người.
pure
Mình đã nói rồi.! Đây là ý kiến mình cũng không bắt ép ai cả mà mình chỉ nhận xét thấy vậy nên đưa ra cùng nhau thảo luân. Có j đáng để cười nhau đâu! THẬT LÀ... không đáng!
Sonblack
Thật là... đáng. Vì bạn nói không đúng về ứng dụng và cách dùng của nó cũng như sự tương thích của thiết bị.
KiD2034
Póc tem cái nha cả nhà , Vọc Rom thôi bà kon có gì mai post chúc cả nhà ngủ ngon :D
pure
Đã ma mới thì hơi hỏi ngu ngơ tí làm j mà cười dữ vậy! vậy làm sao mà dám nêu lên ý kiến chứ.! Thiệt Tình không biết nói j luôn!
Sonblack
Bạn à, diễn đàn mà, mọi người cũng vừa nói vừa đùa, bạn cứ đọc hết các topic đi, ma mới hay ma cũ cười nhau cũng là chuyện thường thôi mà. Chứ có ai bắt bạn phải im lặng đâu.
Hay bạn có thể qua đọc trang đầu xem, mem KiD2034 cười Sonblack đó, mình có nói gì đâu. Nói cho bạn hiểu rõ vấn đề thôi kia mà vì bạn là "ma mới" :D
đúng là thanh viên mới có những câu hỏi "độc đáo". mình cũng vậy thôi. nên hỏi bác son cười đã lun :D
đừng có yêu cầu bác son bỏ cái này hay bỏ cái kia mà hãy mò mẫm build cho riêng mình thì tốt hơn :))
bác son còn phải kiếm cơm nữa chứ đâu có phải suốt ngày build theo yêu cầu thì.... :| :((
cảm ơn bác son về bản Clean này
chúc bác luôn mạnh khỏe ! :)
pure
Vậy tối nay dùng thử bản này xem sao rùi thanks sonblack sau nhé. Vì bản trước bạn làm nó lỗi về cái abum nên hổng thấy thoải mái tí nào cả!:p
Sonblack
Hãy khoan vội gọi là lỗi nhé =)) Cười chọc quê phát nữa nè. Bạn phải hiểu lỗi ROM là cái gì đã nhé? Cái này thì tự tìm hiểu đi, trong diễn đàn nhiều lắm. Không đọc mà hỏi lung tung cũng bị chọc tức đó. :))
