AnhPheCT
Theme CHT v2.0 full Tab final - chạy tuốt đẹp rồi mà bác ơi có bỏ cả cái standard skin của oepra vào kèm được không :-?
Bạn cứ cài thoải mái, ko có gì phải sợ cả, được hay ko thì HR sau đấy thôi. Good luck.
đâu em cài rồi - cho nó đồng bộ cái cht full của bác - ý em sao bác hok bỏ lun vô cái cab của bác cho gọn ý mà
#v2.0.0 (changes since public beta) - 12/11/2010
-[new] sms and email notification shortcuts will jump to CHT widgets
-[new] option to disable non-edit mode popup menu (CHTEditor->Widget settings)
-[new] option to make toggle switch turn on bluetooth in discoverable mode (CHTEditor->Miscellaneous)
-[new] option for original flip clock animation (CHTEditor->Miscellaneous)
-[new/fixed] updated chtstate v1.08g
-[change] tab and state links are no longer part of the base CHT cab - available as addons
-[fixed] phone hardkey not working
-[fixed] tab change bug when only a single home widget page is set
-[fixed] left/right swipe stops working
-[fixed] various quick/free links assignment and move bugs
-[fixed] independent quick links bugs (invisible link presses)
-[fixed] quick links layout bug when setting a lower max row count
-[fixed] quick links disappearing text
-[fixed] sms and email mark read on timeout will only be set if the widget is currently on the screen
-[fixed] sms and email swipe not active on the lockscreen
-[fixed] missed calls notification icon not updating correctly
-[fixed] bugs with "don't repeat multiday appointment" option
-[fixed] WM6.5.x detection method
-[fixed] sms/email popup menu exiting
-[fixed] wallpaper previous/next/random links with very wide walls
-[fixed] widget might disappear after being unpinned
-[fixed] pinning widgets close to or over the edge of the screen
-[fixed] free links size on lockscreen
-[fixed] appointment/tasks list hides independent quick links grid when it should not
-[fixed] add a link page in landscape
-[fixed] wide wallpapers move up after live change
-[dev] custom operator text and foreground layer changes are live (no need for manila restart)
-[dev] updated the setup.dll for addon widgets to add as small install safeguard
-[dev] separated appointment/tasks list and popup menu graphics
-[dev] addon links framework added
em đang dùng 2.0 beta, giờ cài bản 20. final vào nó không hiện các icon báo % pin, nhiệt độ pin và lượng điện tiêu thụ.... không lẽ thằng này trở về như 1.8Co0kie's Home Tab 2.0 final
và CHTEditor v2.0 final
về đồng hồ analog breting_DN: bác anhphe hướng dẫn cho cách chỉnh để việc đổi màu trên đồng hồ theo đúng giờ thực tế (hiện nay cài vào đồng hồ hiển thị 8h-->20h là ban ngày; 20h-->8h hôm sau là ban đêm), muốn chỉnh lại theo giờ thực tế việt nam bác ạ!
Bác làm ơn chỉ giúp vấn đề này với, cách lấy các icon đó với, chứ bản 2.0 final không có cái này hơi bất tiện. Nếu được bác làm file cab để thêm các thành phần báo pin, ram, nhiệt độ .. như bản beta để cài trên final đi bácVới phiên bản 2.0 Final thì các Icon %Pin, Nhiệt độ, Thẻ nhớ... và Slider ko bao gồm trong CHT.2.0, Bạn phải cài Skin hoặc gải nén lấy từ CHT 2.0 beta....!
sử dụng cho tất cả các rom, khi cài thêm các addon như rss, analog, weather đều bị báo lỗi manila.exe khi tắt HTCsense, khi vào lại HTC sense các addon vẫn hoạt động bình thường. mặc dù vẫn dùng được nhưng vẫn cảm thay bất tiện ! Bách AnhPhe hướng dẫn cho cách khắc phục với !
Dó là lẻ đương nhiên muốn cài Skin cho HTC Sensen, khuyến cáo nên tắt HTC Sense xong mới cài, ko thì các chương trình đang chạy bạn ko thể nào cài đè lên được sẻ phát sinh... Bạn nên tuân thủ đúng qui tắt này....!
Cho e hỏi chút, RSS của CHT 2.0 là cái gì, mà sao em kiếm hoài ko thấy mục này vậy
Bạn vào Start/Settings/Today(hay Home), ở tab Items bạn bỏ dấu tích trước HTC Sense là được...Em chưa rành về vụ này lắm, bác hướng dẫn cách tắt HTC sense với. Tìm hoài mà ko ra chổ để tắt.
Mình thấy CHT2 Beta có phần Tab Link và State Link rất tiện, nhưng qua bản final thì 2 tiện ích này mất đi. Mình thấy mới có phần state link dc đưa lên, Mod hay ai có phần tab link ko, cho mình xin với . Thích bản Final lắm nhưng ko có TAB LINK đành xài bản beta đỡ vậy dù bản beta nhiều lúc nó cứ báo lỗi
Chọn thời gian 12h nhé!AnhPhe cho mình hỏi, làm sao để hiển thị AM PM trong cái ô nhỏ của một số đồng hồ Analog nhỉ
