Bạn vào trang htcdev rồi thực hiện lại từ đầu nhé. Unlock Bootloader thì không cần quan tâm đến xuất xứ của máy đâu bạn nhé.
đây rùi bạn ôi nó báo trên htc dev nè
Bootloader Instructions
Before beginning Step 1 of the Unlock Bootloader process, your device requires an RUU to be installed.
Required Resources
Please make sure all items are installed and up to date.
Google Android SDK zip:
http://developer.android.com/sdk/index.html
Java Runtime Environment:
http://java.com
HTC Sync (Windows Only):
http://www.htc.com/www/help/
HTC has identified a known issue that may be experienced by some users with a Sprint EVO 3D that shipped with version 2.08.651.2, even if it was updated to a newer software version via FOTA. When attempting to unlock, a blank screen appears on the device after step 12 in the instructions and the process does not complete. As a workaround for users who experience this issue, we suggest you upgrade the ROM to 2.17.651.5 first via OTA then download and install the RUU from the table below to fix the issue before attempting the unlock process. This issue will also be fixed in the ICS update scheduled for EVO 3D.
BEFORE beginning the Unlock Bootloader process your product requires that you update the ROM to the version listed in the table below first, then download the RUU next to it to enable the unlocking capability.
NOTE: If you do not find your ROM version in the table below, and your ROM version is newer, then your device does not require the RUU. Please bypass these steps and continue to the next page.
To install the RUU, simply follow these instructions:
On your phone, enable USB debugging. (From the Home screen, MENU > Settings > Applications > Development > Check USB debugging)
Connect your phone to the computer using the USB cable that came with your phone. Wait a moment for your computer to identify your phone, this may take a few minutes.
If your computer cannot find your phone, you may need to install HTC Sync. You can download HTC Sync here.
After your computer has found your phone, double click on the RUU to start the process.
Follow the on screen instructions to finish flashing the RUU on your phone.
NOTE: If you encounter an error while flashing your phone, it’s possible that the connection to your phone was interrupted. Simply exit the program, disconnect your phone and start over.
Fully exit the RUU to ensure there is no conflict of multiple instances of the program running.
Disconnect the USB cable from both the phone and the computer.
After a few moments, reconnect the USB to the computer and phone. See above if your phone or computer cannot find each other.
Run the RUU.
Disclaimer: You may not be able to get further FOTA updates once the RUU was applied to your device.
EVO 3D (Sprint)
Carrier ROM Model #
Sprint 2.17.651.5 PG8610000 Download
Proceed to Step 1
và đây là bản dịch
Hướng dẫn nạp khởi động
Trước khi bắt đầu Bước 1 của quá trình Mở khóa Bootloader , máy của bạn cần một RUU được cài đặt.
Tài nguyên được yêu cầu
Hãy chắc chắn rằng tất cả các mặt hàng được cài đặt và cập nhật .
Google Android SDK zip :
Java Runtime Environment :
http://java.com
HTC Sync ( Chỉ Windows) :
HTC đã xác định một vấn đề được biết rằng có thể được kinh nghiệm của một số người dùng với một Sprint EVO 3D xuất xưởng với phiên bản 2.08.651.2 , ngay cả khi nó đã được cập nhật lên phiên bản phần mềm mới qua FOTA . Khi cố gắng để mở khóa , một màn hình trắng xuất hiện trên các thiết bị sau khi bước 12 trong các hướng dẫn và quy trình không hoàn thành . Như một cách giải quyết cho những người dùng kinh nghiệm vấn đề này , chúng tôi đề nghị bạn nâng cấp ROM 2.17.651.5 đầu tiên để thông qua OTA sau đó tải về và cài đặt các RUU từ bảng dưới đây để khắc phục vấn đề này trước khi thử các quá trình unlock . Vấn đề này cũng sẽ được cố định trong bản cập nhật ICS lên kế hoạch cho EVO 3D .
