Hướng Dẫn Nâng Cấp Firmware cho các máy Nokia
dongdieu
Ai biết máy n76 sao up fw bằng NSU thì down đc fw rồi mà lúc cập nhật vào máy thì màn hình đt cứ nhấp nháy khoảng 1p xong nó lại bảo mất kết nối với phone cắm đi cắm lại cũng ko đc cáp cắm rất chắc cũng ko đụng đến ai biết gíup dùm.
Kojiro
Chắc do cáp tiếp xúc kém rồi bạn à, hay là up bằng jaf đi :)
dongdieu
vậy up nó hiện thế này là sao
Searching for phone...Detected P-KEY: 9000CAED
Init usb communication...
Found
MCU SW version: V 06wk41v34
28-06-07
RM-135
(c) Nokia
HW version: 0560
PCI version:
RFIC version:  17141714
DSP version: dsprap_pb06w41v35
APE SW Core version: 20.0.041
APE Variant version: 20.0.04120.0.041_16.02
APE Test version: rm135_ENO_x_2007wk07v0.040
Retu version: 15
Tahvo version: 22
APE HW version: 256
APE ADSP SW version: 256
APE BT version: HCI Version 8 (rev. 0). LMP Version 32 (rev. 4127). Manufacturer 13064.
Production serial number: CBG978780
Product code: 0543079
Module code:
Basic production code: 0542587
Flash code:
Order number:
Product specific data:
Long production SN: 0
ATO:
Default SN type:
IMEI plain: 353954012385580
IMEI spare to net: 3A 35 59 04 21 83 55 08
IMEI SV to net: 33 35 59 04 21 83 55 18 F4
LOCK STATUS:
CONFIG KEY: 2440700000000000
Provider: AT&T;U.S.A. (3650)
Key Code count: 0, FBUS Code count: 0
Block 1:
Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Loading INI list...
Reading product code...
Product Code: 0543079
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-135\
Checking path: \Products\RM-135\
Scanning ini files...
FILES SET FOR FLASHING:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-135\RM135_31.0.014_prd.C00
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-135\RM135_31.0.014_prd_0401.V04
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-135\RM135_31.0.014_027_000_U01_uda.fpsx
APE Variant file: NONE
Languages in ppm: English,German,Russian,Estonian,Latvian,Lithuanian
Done!
Kojiro
là sao mới down 3 file fw mới có tv về nhưng cài kiểu gì vậy
Bạn hỏi cho có đầu có đuôi, bạn nghĩ sao khi bọn mình thì cố giúp bạn còn bạn thì quá tiết kiệm từ ngữ. Hỏi như bạn chắc lâu lắm mới có người trả lời :|
dongdieu
Đúng đó chả thấy ai trả lời cả mình down tất cả file từ navifirm rồi up thì jaf nó bảo khởi động lại nhưng ko còn trong flash nữa còn máy thì đơ 1 lúc rồi khởi động lại.Hơn nữa 3 file đã nạp vào 3 mục rôi mà up chăng dc
habaolinh
Bạn down nhưng file gì về? Bạn chọn file như thế nào? Ít ra thì cũng phải post cái log lên đây thì người khác mới chỉ ra đc cho bạn chứ.
dongdieu
Mình update bằng NSU cứ đến đoạn 14p này thì ko up được nữa mà máy không die.Đến đoạn này cứ nghe tinh tinh gì gì ở loa ấy up mãi ko được.
habaolinh
nếu ở HN thì mang qua mình up cho.
dongdieu
Ở hà nội thì nói làm gì ở vùng này chả có thằng thợ nào update đc fw cả phải tự làm thôi.Đã thử up bằng NSU,JAF,cả qua gprs nhưng chả cái nào được nản wá trong khi đó up cho thằng khác có n73 thì đc.:-(
habaolinh
Bó tay với bạn, mình vừa chạy con N76 hôm qua = JAF xong, đã thử cả update lẫn downgrade đều ok hết.
Toan_bk
sao máy tính của mình ko cài đc nokia sofwere update vậy anh?Nó báo lỗi "this operating system is not support"
Máy tính mình đang xài win 7
Kojiro
Dùng win7 là tiêu rồi, mình cũng mới test thấy ko được, bạn thử tải NSU qua PC Suit thử xem được ko :-?
Mjnhvu
cho em hỏi dây cáp usb của n72 có dùng cho n70me được ko ạ?
em dùng n70me v5.0638.3.0.1
18-09-06
RM 84
code 539276
em muốn update lên ver mới nhẩt có cần phải thay đổi code ko.em muốn hiện thị tiếng việt có dấu thì phả dùng code nào.?
và cho e hỏi pm nào đẻ updateFW offline ak.và c6 thể hướng dẫn cụ thể cho e ko ?thanh pro nhiều
