LEO - PDAVIET ROM WM6.5.x Manila 2.5.2018 [10/01/2011]
TranMinhMan
PDAVIET ROM WM 6.5.x CE OS 5.2.29007 Build 29007.5.3.9
By TranMinhMan
*** Only for HTC LEO ***
Máy bạn phải được HSPL trước khi up Rom này xem thêm tại đây
Your Leo must be HSPL before uploading this Rom, view more here
Đặc biệt cảm ơn - Special thanks to:
Man PhamQuang
SMod Sonblack
Hình ảnh ROM - ROM Images:
Thông tin bản ROM - ROM Informations:
- CE OS 5.2.29007 Build 29007.5.3.9.
- Dựa trên nền Rom Ship HD2 T-Mobile 3.14.531.1, dùng cho cả HTC Leo thường và HTC Leo T-Mobile.
- Base on the Ship Rom HD2 T- Mobile 3.14.531.1, use for both HTC Leo and HTC Leo T-Mobile.
- Android supported
- Pagepool 20Mb
- Manila 2.5.20181424.0
- NetCF 3.5.9198.0 original from SYS
- Office Mobile 2010 v14.0000.29007
- Co0kie's Home Tab v2.0.0 - Final Released by Co0kieMonster
- CHTEditor v2.0.0.0 - Final Released by CHTE Team
- Autoinstall by SVIP Tom_codon
- Advanced Configuration Tool v3.3.0.0 by Julien Schapman
- ClearTemp v1.3.1 by Vicott Wong
- dotFred Task Manager
- ExtendedFileExplorerExt v03
- htcAddicts cleanRAM v2.5 by ronenpg
- Google Map ver 4.1.1
- m6silver Color & Metal Taskbar Skin by Mr. Makk
- NoData by Modaco
- Opera Mobile 10 Final
- PIM Backup v2.8.0.0 by FdcSoft
- PocketNotepad v4.0.10 by Tilanosoft
- PocketRAR v3.93
- PocketScreen v1.3 by JJM. Roseboom
- Slide2Shutdown v1.1 by Cythrelo
- Synchro Time v0.95 by Dennis Grachov
- Turbo 3D by Chainfire
- Zooomer by Bernd.M.Walter (config MultiTouch)
- WMP12 WVGA skin by BOGYSOFT
- Some small games
[PASS]TranMinhMan[/PASS]
Các phiên bản cũ - Last versions
TranMinhMan
Các phiên bản cũ - Last versions:
* LEO - PDAVIET ROM WM6.5.x (Core 23152) Manila 2.5.2018 *
- Base Rom Ship HD2 T-Mobile 3.14.531.1
- Pagepool 20Mb
- No Cookie Hometab
- Icon default
* LEO - PDAVIET ROM WM6.5.x (Core 23151) Manila 2.5.2018 *
- Pagepool 20Mb
- No Cookie Hometab
- Icon default
* LEO - PDAVIET ROM WM6.5.x (Core 23150) Manila 2.5.2018 *
- Pagepool 20Mb
- Manila 2.5.20181424.0 with Calls History tab
- Icon default
* LEO - PDAVIET ROM WM6.5.x (Core 23699) Manila 2.5.2018 *
- Pagepool 20Mb
- Icon Glass Dinik
* LEO - PDAVIET ROM WM6.5.x (Core 28244) Manila 2.5.2018 *
- Base Rom Ship HD2 T-Mobile 3.14.531.1 & LEO(S) 3.14.405.2
- Pagepool 20Mb
- Manila 2.5.20181527.0
- Icon Glass Dinik
TranMinhMan
Giao diện nên để các bạn tùy chỉnh theo ý thích!:D
Mình đã chỉnh tất cả những thứ cơ bản nhất tuy mặc định nhưng đẹp và tiện dụng, nhẹ!
Bản này mình đã test và fix bug 2 tuần nay rồi mới đưa lên. Đây lả bản đầu tay cho Leo, ae chém nhẹ tay nhé!:p
tuanbeck132
Bác có thể xin em xin file cài hoặc chỉ em cách cài cái đồng hồ to ngoài màn hình Lock o ạ? Hi.... E xl đã quấy rầy !
khanhduy301
Đang chờ để test. :D
Mà bỏ cái ảnh .gif đi bác, nhìn nhức mắt quá. ScreenShot cứ làm ảnh .jpg là OK nhất.
MrBeOaRT
cả rom dinik hết rồi. mỗi cái slide anh để default làm gì ..... cook nốt cho nó trọn vẹn anh ơi
TranMinhMan
Đổi luôn cái Slide thì phải đổi luôn cái Clock và Lock Screen thì mới đồng bộ bên ngoài. Nhưng bên trong còn các button, option, tab, keyboard, dialpad... vẫn là mặc định của Ship. Đồng ý là Dinik cũng đã cho ra các giao diện fix cho những thứ này, nhưng Base Rom khi build phải dựa trên Rom Ship, khi bạn đổi Base Rom mới cho mạnh hơn, nghĩa là các ctr cũng là ver mới chắc chắn ko ít thì nhiều sẽ phát sinh bug nếu muốn dùng gói giao diện cũ. Ngoài ra, nó sẽ lấy nhiều tài nguyên hơn (vì file hình đẹp mà) nếu bạn muốn thay đổi tất cả các giao diện đó. Nói vậy chứ chẳng bao giờ có thể đồng bộ tất cả giao diện, vì bên cạnh giao diện HTC còn giao diện mặc định của WM.
Theo mình thì mỗi người mỗi ý bạn àh, nên chỉ đạt được tương đối thôi. Nếu sa đà vào giao diện thì phải trả giá free ram và chạy đa nhiệm, ngoài ra còn việc chạy song song của Android nữa (VD vậy!)
Vì vậy mình chỉ thay bộ Icons, Taskbar, mod lại Theme WM6.5.x cho đồng bộ, mà những cái này theo mình là những cái xấu nhất cần đổi!:D
TranMinhMan
Bản rom này chạy Android có tuyệt không bác...
Android thì mình đang test bạn àh. Nhưng mình sẽ cố gắng cho ra 1 bản nhẹ hơn và có dualboot như Avd Mod Ancola để hỗ trợ chạy Android tốt hơn!:D
Hihi, chúc bản rom đẹp và mượt, chờ ngày quay về HD2 room\-/
Tks a! Vậy đổi IP4 với e đi, e bù chầu nhậu hén!:))
VUNHATVAN
Sao mình up xong, khởi động nó báo lỗi HTC LOG. khởi động lại nó lại vào cài đặt lần đầu
TranMinhMan
Sao mình up xong, khởi động nó báo lỗi HTCclock. khởi động lại nó lại vào cài đặt lần đầu
Hình như bạn có để file cab trong thư mục Autoinstall của thẻ nhớ! Nên để những file cab nhẹ, đơn giản (trong quá trình cài ko hỏi option) thì tốt hơn cho quá trình loading lần đầu! Sau khi xong nên SR để máy chạy tốt hơn.
