Kojiro
MobilHex 0.9.8 by fann95
Trình Việt hóa bản cập nhật. A e có máy nghiên cứu nha.
![12362876170.jpg](http://img135.imageshack.us/img135/8458/12362876170.jpg)
Update multi-hex-rsc editor for 9 os.
In this version:
Fixed errors of the previous version.
Added:
Much improved (I think complete) algorithm for finding the string and identification of its encoding.
Added full Unicode compress-decompress, that allows you to edit, and see
strings in the rsc files (not only) in the all language.
Supported characters:
Latin-1
Latin Extended A
Cyrillic
Arabic
Devanagari
Hiragana
Katakana
Fullwidth ASCII
Added support for any encoding installed in the smartphone (you can add and modify their working set).
Improved Search Hex editor. Nove looking for all encodings at once, and when the something find ,hex editor automatically switches to the appropriate encoding.
Added scroll through wherever possible.
In the calculator added converter DIGIT> HEX and vice versa.
If you use more fonts,the fontS zoom to put 100 percent!
