Model : Nokia 5800,5530,5230,5233,5235,5228
Supported RM's : RM-356, RM-504, RM-588, RM-593, RM-625
Base Firmware : C6 v20
Languages Present : English Only
Thanks to Red X for the image.
Screenshots
Performance Upgrades:
- Highly Increased Application/Gaming frame rates
- Phone FPS set as 30. CPU time set as 100%
- Increased Response Rate (Now touchscreen will be more responsive)
- Music Player response highly increased (Instantly pauses/plays on clicking the buttons)
- Reduced effects complexity which should result in a speed increase
- Increased Heap Size further to boost up performance
- Lags in Menu, messaging and Other Large Applications removed
- Polished the UI for heavy usage
- Phone will never slow down and the RAM won't be decreasing (RAM Caching modded)
- 80MB+ on C:\ (Phone memory)
- Free RAM after startup : 64MB
- Average RAM: 60MB free
- Smoother Kinetic Scrolling
- Music Player is now a lot more faster!
- Real Hack! (No need to use installserver.rmp patch anymore)
- CPU mod optimized to get complete stability and a great battery life!
General Modifications :
- All C6 lights problem fixed. (Mod by mara)
- Camera will not eat RAM after closing it.
- Default Browser user agent changed to the one of N97 mini. So OVI store and some other sites will recognise your phone as Nokia N97 mini
- Display lights timeout and automatic keyguard time set to 30 seconds.
- Default bluetooth name: Nokia Photon^C6
- FOTA reserved space romoved to get more space in C:\ (Phone Memory)
- USB now will name as Nokia Photon^C6
- Voice recording during call fixed
- RAM Cache in C:\ for better performance
- Blazing Fast Screen Rotation
- CPU load decreased (Get a very fast phone)
- Enabled lock/unlock vibration
- Disabled My Nokia Service
- Zero start up of background applications
- Auto optimization of RAM cache for keeping up your phone faster even after heavy usage
- Blank UDA supplied to get highest possible free space on C:\
- Lags in Menu removed. The Kinetic Scrolling is optimized (It is no very fast not very slow)
- Display rotation is ON by default
- Breathing light is OFF by default
- Digital clock set as default. N8 Clock fonts used so the digital clock now looks like the N8 clock
- Display light turns OFF and Phone gets locked in 30 seconds
- Default Fonts Used
- Operator Logo ON/OFF settings available in homescreen settings
- Delivery Reports ON by default in Messaging
- Theme effects are OFF by default
- Removed "Check for Updates" in Device Updates
- "Summary after call" and "speed dialing" ON by default
- "In call timer" ON by default
- Profile "General" renamed to "Photon"
- Homescreen landscape enabled. Dialer landscape disabled
- Lags in Messaging apps removed
HOMESCREEN:
- Widgetized Nokia C6 Homescreen
- Full widgets support
- Added 3 new shortcut bars
- N97/N97 mini widgets can now be installed
- 3 Additional shortcuts bar. Total : 5
GRAPHICAL PERSONALISATIONS:
- Photon Splashscreen and Shutdownscreen.
- My Own Menu Mod.
- Startup animation removed for faster startup. (Check the booting speed yourself)
- Bootscreen Volume set to : 10
- Custom Boot/Shutdown animation locations -
E:\Boot\
Startup.mp3
Startup2.mp3
Shutdown.mp3
- Theme effects : Mixed with Rotation and Swipe effects.
INSTALLATION FEATURES:
- Java permission is set to default
- Real Hack (added modded installserver.exe)
- SwiPolicy changed which enable to install almost apps without RomPatcher patch (Works 99%)
- Secure Widget Preinstall (OVI Store Installer) will not run on first startup but will install at one click from menu icon
LIGHTS BEHAVIOUR:
- All C6 lights bugs are fixed. (Mod by mara)
- Green Charging light disabled.
BROWSER:
- Added "View Images" in options>Display Settings
- Download manager will be started on browser start-up to resume
- Browser now can be rotated in landscape even sensor off, by going to options while browsing
- Browser will prompt to continue download if there was a power failure
- Browser Cache moved to E:\ and increased to 50MB
FILE MANAGER:
- Nokia default file browser can send sisx, sis, jar and any protected items via bluetooth, mms and uploads
- Nokia default file browser will show system folders in E:\
MULTIMEDIA:
- Camera will not leave in background after close it (SAVES RAM)
- Voice recorder set to High quality
- Voice recorder records upto 12 hours
- Gallery will not mix up pictures and videos
- Camera Image improved
- Gallery searching improved
- Share Online removed in Photo Apps Homescreen
- OVI Music removed in Music Homescreen
- Video Capture frame rate increased
- Music Player will read E:\Music\
- Music player refresh faster
MENU:
- Using 3x4 Menu modded by ME
- All Lags in Menu removed
- Applications Hidden : Conversations, OVI Sync
- "Show Open Apps" Removed
- Optimized to run very fast and smooth (Tweaked KS in Menu)
MESSAGING:
- Messages sent by you will be saved up to 500 messages
- Delivery reports ON by default
- Messaging application no longer lags when containing large number of messages.
THEMES:
- Photon Black (Default) (Nokia Theme Black by LA)
- Photon White (Nokia Theme White by LA)
- Photon Red (RoB Default Icons IND190)
- Photon Blue (Petrol Blue)
- Photon Green (Hijau Default Icons IND190)
- Photon Steel (Modded Steel Dark by Giulio7g)
APPLICATIONS UPDATED/ADDED:
- Maps 3.06
- New Music Player wih lyrics support.
- ROMPatcher+ 3.03 (Removed Startup Note)
- Nokia File Browser
- KillMe
- Autoinstaller
Added in Autoinstaller directory :
- Notifications Widget
- Best ScreenSnap v3.0
- BTSwitch
- RAM Blow 1.0
- Opera Mini 5.1
APPLICATIONS REMOVED:
- About app
- Ovi Music
- My Nokia
- Phone Switch
- Voice Commands
- Notes
- Online Support
- Share Online
- Here and Now
- OVI Contacts
- Chat
- Search
- Help
- Image Print
dịch
Thực hiện nâng cấp:
- Tăng cường ứng dụng cao / tốc độ khung hình chơi game
- FPS Điện thoại thiết lập như là 30. CPU thời gian thiết lập như là 100%
- Tăng ứng suất (Trả màn hình cảm ứng sẽ được đáp ứng nhiều hơn)
- Music Player phản ứng tăng cao (ngay lập tức tạm dừng / phát trên nhấn vào các nút)
- Giảm hiệu ứng phức tạp mà nên kết quả là tốc độ gia tăng
- Tăng Kích thước Heap hơn nữa để thúc đẩy hiệu suất
- Thua trong Menu, tin nhắn và các ứng dụng lớn khác gỡ bỏ
- Bóng giao diện người dùng cho việc sử dụng nặng
- Điện thoại sẽ không bao giờ làm chậm và bộ nhớ RAM sẽ không được giảm (RAM Caching Modded)
- 80MB + vào C: \ (Điện thoại bộ nhớ)
- Miễn phí RAM sau khi khởi động: 64MB
- Trung bình RAM: 60MB miễn phí
- Dịu cuộn Kinetic
- Music Player là bây giờ nhiều hơn nhanh hơn!
- Real Hack! (Không cần phải sử dụng bản vá installserver.rmp nữa)
- CPU mod tối ưu hóa để có được sự ổn định hoàn toàn và pin một cuộc sống tuyệt vời!
Tổng Sửa đổi:
- Tất cả đèn C6 vấn đề cố định. (Mod của ma)
- Camera không ăn RAM sau khi đóng nó.
- Default Browser người sử dụng tác nhân thay đổi thành một trong N97 mini. Vì vậy, OVI lưu trữ và một số trang web khác sẽ nhận ra điện thoại như Nokia N97 mini
- Hiển thị thời gian chờ đèn và tự động thiết lập để bảo vệ phím thời gian 30 giây.
- Default bluetooth hiệu: Nokia Photon ^ C6
- FOTA romoved dành không gian để có được nhiều khoảng trống trong C: \ (Phone Memory)
- USB bây giờ sẽ đặt tên là Nokia C6 ^ Photon
- Ghi âm giọng nói trong suốt cuộc gọi cố định
- RAM Cache trong C: \ cho hiệu suất tốt hơn
- Blazing nhanh màn hình xoay
- CPU giảm (được một điện thoại rất nhanh)
- Bật khóa / mở khóa rung
- Tắt dịch vụ My Nokia
- Zero bắt đầu lên của các ứng dụng nền
- Tự động tối ưu hóa bộ nhớ cache RAM để giữ điện thoại của bạn nhanh hơn ngay cả sau khi sử dụng nhiều
- Blank UDA cung cấp để có được cao nhất có thể không gian trống trên C: \
- Thua trong Menu loại bỏ. Các cuộn Kinetic được tối ưu hóa (không có gì là rất nhanh không phải là rất chậm)
- Màn hình xoay về mặc định
- Thở ánh sáng là tắt theo mặc định
- Đồng hồ kỹ thuật số thiết lập như mặc định. Đồng hồ N8 phông chữ được sử dụng để đồng hồ kỹ thuật số bây giờ trông giống như đồng hồ N8
- Hiển thị ánh sáng lần lượt OFF và điện thoại bị khóa trong 30 giây
- Phông chữ mặc định sử dụng
- Operator Logo ON / OFF cài đặt sẵn trong cài đặt màn hình
- Giao hàng báo cáo về mặc định trong Nhắn tin
- Chủ đề hiệu ứng được OFF theo mặc định
- Gỡ bỏ "Check for Updates" trong thông tin cập nhật thiết bị
- "Chi tiết cuộc gọi" và "quay số tốc độ" Về mặc định
- "Trong cuộc gọi hẹn giờ" Về mặc định
- Hồ sơ "General" đổi tên thành "Photon"
- Màn hình chính cho phép cảnh quan. Dialer cảnh tàn tật
- Thua trong các ứng dụng tin nhắn bỏ
Màn hình chính:
- Widgetized Nokia C6 Màn hình chính
- Hỗ trợ đầy đủ các vật dụng
- Thêm 3 quầy bar shortcut mới
- N97/N97 vật dụng nhỏ có thể được cài đặt
- 3 bổ sung phím tắt thanh. Tổng cộng: 5
Đồ họa PERSONALISATIONS:
- Photon splashscreen và Shutdownscreen.
- Menu Mod riêng của tôi.
- Startup hoạt hình loại bỏ để khởi động nhanh hơn. (Kiểm tra tốc độ khởi động cho mình)
- Khối lượng đặt màn hình khởi động: 10
- Custom khởi động / tắt các vị trí hoạt hình -
E: \ khởi động \
Startup.mp3
Startup2.mp3
Shutdown.mp3
- Chủ đề tác: hỗn hợp với các hiệu ứng xoay và Swipe.
ĐẶT tính năng:
- Cho phép Java được thiết lập để mặc định
- Real Hack (thêm installserver.exe Modded)
- SwiPolicy thay đổi cho phép cài đặt hầu hết các ứng dụng mà không cần RomPatcher vá (Làm việc 99%)
- Secure Widget cài đặt sẵn (OVI Store cài đặt) sẽ không chạy khi khởi động đầu tiên nhưng sẽ cài đặt tại một nhấp chuột từ biểu tượng menu
ĐÈN Tính tình:
- Tất cả C6 đèn lỗi là cố định. (Mod của ma)
- Green sạc ánh sáng vô hiệu hoá.
DUYỆT:
- Nhập "Xem ảnh" trong các tùy chọn> Display Settings
- Tải về quản lý sẽ được bắt đầu trên trình duyệt khởi động trở lại
- Trình duyệt có thể được luân chuyển trong cảnh quan ngay cả cảm biến đi, bằng cách vào tùy chọn trong khi trình duyệt
- Trình duyệt sẽ nhắc để tiếp tục tải về nếu có một mất điện
- Trình duyệt Cache chuyển đến E: \ và tăng lên đến 50MB
FILE MANAGER:
- Nokia trình duyệt mặc định tập tin có thể gửi sisx, sis, jar và bất kỳ mục bảo vệ thông qua Bluetooth, MMS và tải lên
- Nokia trình duyệt mặc định tập tin sẽ hiển thị các thư mục hệ thống trong E: \
MULTIMEDIA:
- Camera sẽ không để lại trong nền sau khi đóng nó (tiết kiệm RAM)
- Máy ghi âm thiết lập chất lượng cao
- Máy ghi âm ghi tối đa 12 giờ
- Thư viện sẽ không trộn lên hình ảnh và video
- Máy ảnh được cải thiện
- Bộ sưu tập tìm kiếm nâng cao
- Chia sẻ trực tuyến loại bỏ trong ảnh Apps Màn hình chính
- OVI Music bỏ trong Âm nhạc Màn hình chính
- Video Capture tốc độ khung hình tăng
- Music Player sẽ đọc E: \ Music \
- Máy nghe nhạc làm mới nhanh hơn
MENU:
- Sử dụng Menu 3x4 Modded của ME
- Tất cả thua trong Menu loại bỏ
- Các ứng dụng ẩn: Hội thoại, OVI Sync
- "Hiển thị Apps Open" gỡ bỏ
- Tối ưu hóa để chạy rất nhanh và trơn tru (Chỉnh KS trong Menu)
TIN NHẮN:
- Thông điệp được gửi bởi bạn sẽ được lưu lên đến 500 tin nhắn
- Báo cáo giao hàng về mặc định
- Nhắn tin ứng dụng không còn bị chậm khi có số lượng lớn thư.
ĐỀ TÀI:
- Photon Black (Default) (Nokia Theme đen của LA)
- Photon White (Nokia Theme trắng bởi LA)
- Photon Red (Rob Default biểu tượng IND190)
- Photon Blue (xăng Blue)
- Photon Green (Hijau Default biểu tượng IND190)
- Photon thép (thép Modded Dark bởi Giulio7g)
ỨNG DỤNG TIN / gia tăng:
- Bản đồ 3,06
- New Music Player hỗ trợ lời bài hát wih.
- ROMPatcher + 3,03 (gỡ bỏ Startup Lưu ý)
- KillMe
- Autoinstaller
Đăng trong thư mục Autoinstaller:
- Thông báo Widget
- ScreenSnap nhất v3.0
- BTSwitch
- RAM 1,0 Blow
- Opera Mini 5,1
ỨNG DỤNG REMOVED:
- Giới thiệu về ứng dụng
- Ovi Music
- My Nokia
- Điện thoại Switch
- Các lệnh bằng giọng nói
- Ghi chú
- Hỗ trợ trực tuyến
- Ở đây và Bây giờ
- OVI Contacts
- Chat
- Tìm kiếm
- Trợ giúp
- Hình ảnh In
có sẵn ngôn ngữ tiếng việt,âm lịch......
RM-588:http://www.multiupload.com/UK8PSU6LDY
RM-625:http://www.multiupload.com/6BMPJ3U1ER
RM-356:http://www.multiupload.com/T0MQVBGCNJ có sẵn ngôn ngữ tiếng việt,âm lịch......
RM-504:http://www.multiupload.com/SVXBD5I9PT
các bạn kết hợp với bản phối hợp của C6 ở diễn đàn hay ở PNHT nha
bản core của 5800 và 5530 http://forum.pnht.pl/showthread.php?1262-Firmware-C6-00-V20.0.042-on-5800-amp-5530-by-Binh24!
bản core của 523x:http://pnht.org/?p=446
Screenshots
![masterpreview.png](http://img46.imageshack.us/img46/3595/masterpreview.png)
![Photon%5EC6.jpg](http://lh3.ggpht.com/_mcEfLr7qw58/TQ234PL1w9I/AAAAAAAACOY/qtZyaYSmkK4/s512/Photon%5EC6.jpg)
![PhotonC6000025.jpg](http://lh6.ggpht.com/_mcEfLr7qw58/TQuQBchZqjI/AAAAAAAACNM/9avQkFC594E/s512/PhotonC6000025.jpg)
![PhotonC6000030.jpg](http://lh4.ggpht.com/_mcEfLr7qw58/TQuQq4qNlbI/AAAAAAAACNc/fe2lkLrg7DM/PhotonC6000030.jpg)
HOMESCREEN:
- My Own Menu Mod.
E:\Boot\
Startup.mp3
Startup2.mp3
Shutdown.mp3
LIGHTS BEHAVIOUR:
BROWSER:
FILE MANAGER:
MULTIMEDIA:
MENU:
MESSAGING:
THEMES:
- Maps 3.06
- KillMe
- Autoinstaller
- BTSwitch
- RAM Blow 1.0
- Opera Mini 5.1
- About app
- Ovi Music
- My Nokia
- Phone Switch
- Voice Commands
- Notes
- Online Support
- Share Online
- Here and Now
- OVI Contacts
- Chat
- Search
- Help
- Image Print
dịch
Thực hiện nâng cấp:
- Dịu cuộn Kinetic
Tổng Sửa đổi:
Màn hình chính:
E: \ khởi động \
Startup.mp3
Startup2.mp3
Shutdown.mp3
ĐẶT tính năng:
ĐÈN Tính tình:
DUYỆT:
FILE MANAGER:
MULTIMEDIA:
MENU:
TIN NHẮN:
ĐỀ TÀI:
- Bản đồ 3,06
- KillMe
- Autoinstaller
- Thông báo Widget
- BTSwitch
- RAM 1,0 Blow
- Opera Mini 5,1
ỨNG DỤNG REMOVED:
- Ovi Music
- My Nokia
- Điện thoại Switch
- Ghi chú
- Hỗ trợ trực tuyến
- Ở đây và Bây giờ
- OVI Contacts
- Chat
- Tìm kiếm
- Trợ giúp
- Hình ảnh In
