Đã có bản ROM 6.1 mới hoàn thiện hơn cho Flame (Updated 1 on ROM WM6.1 20226.1.0.2-by nikhilraut1985). Các Bác vào đây nghiên cứu, Download và thử nhé.
http://www.xdaflameusers.com/viewtopic.php?id=1071
Brief discription of this updated ROM
Windows Mobile 6.1 porfessional CE OS 5.2.20226
NET COMPACT FRAMEWORK -- 3.5(ADDED IN THIS UPDATE)
WORKING WINDOWS LIVE MESSENGER V10.6.0034.0800(ADDED IN THIS UPDATE)
Remote Desktop Mobile(added in this update)
OneNote Mobile(added in this update)
Microsoft Calculator(added in this update)
O2 APPLICATIONS
FM radio v2.0
o2 camera v2.3
o2 cplprop
o2 self diagnostics
Removed from this ROM Archsoft MMS
ABOUT PERFORMANCE
Imporved performane as compared to previous ROM Available for FLAME
Overall battery life improved
SB problem not seen till now
Bluetooh headset working it gets automically connects after waking up from sleep tested
The problem when entering start menu--settings reduced to some extend for the first time after boot have to click
on all the three tab's in settings then after that shows a normal behaviour
*I think this problem is because the language files used are of lower build than the sys files are if some one gets
English SYS files build 20226.1.0.2 might solve this little bug.
Compared the registry with other ROM and did come changes
VSBenchmark results *note without any tweaks and no overclocking
Download ROM
http://www.mediafire.com/?ll1te9lhyt7
