[ROM ICS 4.0.3][JAN.9]InsertCoin 4.1.0 Ice Cream Sandwich 4.0.3 XE / NON XE
ntt2006
Ice Cream Sandwich 4.0.3 with Sense 3.5
InsertCoin 4.2.0 Ice Cream Sandwich 4.0.3 XE / NON XE
Nguồn XDA
THÔNG TIN BẢN ROM
- Base: 3.12.401.102 CL234376 test-keys
- IceCreamSandwich 4.0.3
- Deodexed - Init.d support
- Rooted - Improved SQLIte
- Improved GPU configuration
- GPU Acceleration ON
- Ad-free
- APKs optimized to speed up and reduced memory footprint
- Removed HTC Sniffing Tools
- Tons of tweaks and optimizations
CHANGELOG
4.3.2
[h=3]- Added beats option to standard rom – thx mudhi => only one version of rom from now on (yes you can use both firmwares for this[/h] [h=3]- Added option for Stock % batteyr – thanks Istarth[/h] [h=3]- Added option to choose on install stock or OC kernel[/h] [h=3]- added JIT[/h] [h=3]- added InsertCoin Wallpaper – thanks tinky1[/h] [h=3]- added option to remove HTC Location on install[/h] [h=3]- added option to remove HTC Stocks on install[/h] [h=3]- added option to remove HTC Watch on install[/h] [h=3]- added option to remove HTC Book Reader on install[/h] [h=3]Addons: http://www.mediafire.com/?9g9wyi556vedn[/h] [h=3]To benefit from the interactive install you need 4ext Touch Recovery Beta7/8. If you have other recovery the install script will use the default values which is “NO”[/h]
4.2.0
- rebuild from scratch to fix random reboots
- 2 versions. XE and Standard.
- both versions have stock kernel !
4.1.1
- one build to rule `em all. Mixed XE and NONXE but no dice app yet
- reverted to stock 1.2 ghz kernel to fix reboots some users were reporting if you really want you can get the 1.5 Ghz kernel from addons
- Interactive instalation routine
– stolen from mike
– tested on 4ext recovery touch
- another batch of speed improvement
- all apps updated to latest versions
- included TMO Customization in Install routine
– select YES when Install Asks you.
- included Orange UK Signal BOOST
– select YES when install asks you
- fixed Shutdown Animation.
- fixed slow sdcard Proof
4.1.0
- fixed GSM ! (unknown basebad / no gsm signal)
Bản Rom này update từ v4.0.9 do đó yêu cầu cài đặt v4.0.9 trước và không wipe. Áp dụng cho XE and NON-XE
DOWNLOAD V4.3.2
DOWNLOAD V4.2.0
Các bạn cần download firmwave phù hợp với máy của bạn : Sen thường + 4G và XE
Rom v4.2.0 (Full Rom - Full Wipe)
Các bạn cần down đúng bản Rom cho máy mình Sen thường + 4G và XE
DOWNLOAD
Lưu ý
Để up được bản Rom này bạn cần cài đặt firmware để phù hợp với Rom
InsertCoin 4.1.1 IceCreamSandwich 4.0.3 Sense 3.5 - Full rom! Although not mandatory full wipe is recommended
(Đề nghị Full Wipe)
LinhKu
Bản này ngon lành chưa anh,hôm truớc up bản 4.0.8 vẫn lỗi reboot
dienluc510
Bản này mình đã thử , mặc dù tác giả nói đã ROOT nhưng khi cài titanium backup thì vẫn báo là ROOT bị lỗi, có bạn nào như vậy ko?
ntt2006
Mình up bản v4.1.0 và cài titanium backup bình thường mà bạn.
LinhKu
sao em up bản này nó lại không nhận sim vậy,lạ quá ~X(
em dùng XE và dow bản ở trên,giờ thử dow nốt bản ở dưới xem được không
LinhKu
em đã test cả 2 bản và đều không nhận sim,anh có bị vậy không :O
ntt2006
Bản v4.0.9 sau khi up sẽ không nhận similar,em phải up tiếp v4.1.0 để update fix lổi này,sóng sánh vô tư.
ntt2006
Update v4.1.1 (đây là full Rom cần full wipe).
- Fix lổi khi cài app
- Chuyển về stock kernel 1.2ghz, bạn nào thích 1.5ghz thì up kernel từ addon.
- Cải thiện tốc độ sd card.
- Một số thay đổi khác
LinhKu
đã có bản cập nhật rồi,nhanh quá,lại phải test thôi hê hê\-/
AK47_CCCP
Các bác cho mình hỏi:
- khi cài bản này+firmware. thi Hboot lên la 1.20.... thế muốn quay trở lại để cài Ad 2.3.5 (hboot có cần thiết fai hạ xuống thành 1.18 không?nếu cần hạ xuống thì làm thế nào?)
thexteen
Không cần thiết phải hạ hboot, bác vẫn có thể dùng android 2.3 như thường, mình đang dùng 2.3 vì không hài lòng với một số thứ của ICS 4.0.3
ntt2006
Update v4.2.0. Khắc phục lổi reboot. Kernel stock.
Có firmware và Rom riêng cho Sen thường + 4G và XE, cần down đúng bản cho máy. Yêu cầu full wipe.
TranMinhMan
cái file .md5 dùng như thế nào vậy a T?
MD5 (Message-Digest algorithm 5) là một thuật toán mã hoá, các chương trình mã hoá MD5 thường được gọi là MD5Sum.
Nó được dùng để tạo ra một chuỗi 128 bit duy nhất từ một chuỗi dữ liệu nhập bất kỳ, và vì thế thường được dùng để kiểm tra tính toàn vẹn dữ liệu của một tập tin.
Các tác giả đưa MD5 của tập tin lên nhằm tránh trường hợp quá trình download đã bị lỗi khiến tập tin tải về không đủ, hoặc tập tin đã bị sửa đổi (chèn trojan, virus, ..v.v..) so với bản nguyên thủy có MD5 đã đưa lên .
Nếu tập mà bạn tải ở nơi khác có mã MD5 khác với ở trên, bạn nên cẩn thận xem rõ phiên bản ở nơi giới thiệu và quét bằng các chương trình AntiVirus trước khi sử dụng.
Bạn có thể download công cụ nhỏ gọn, không cần cài đặt sẽ giúp bạn thực hiện việc kiểm tra mã MD5 rất đơn giản.
MD5 Check 2.1
