DucLong
Thông tin chính về rom v8.0:
-- WM6.1 Core + OS (Build 19591)
-- WkTask 1.1.7.3c (by waku) Task manager
-- Patched and Enhanced OEM Drivers and DirectShow filters
-- Memory Manager / Auto hibernate
-- Advanced Config tool (by Schap) with custom config
-- System Tray (delete link from startup if you don't like)
-- 6-button CommManager
-- Gray themed Calculator
-- BT & IRDA support
-- DF's Task Manager / Registry Editor 3.1
-- SD/SDHC driver switch-over tool (thanx OllieD for coding support)
-- TCPMP 0.72 (with FLV support)
-- Camera Application (Build 25626)
-- TodayAgenda 1.10 today plugin
-- Total Commander 2.5
-- Adobe Reader LE 2.5
-- Performance/overclocking applet (default 624 MHz)
-- DF's PIM Backup 2.8 (for contact, sms/mms etc. backup)
-- SynchroTime (by Grachov) for Internet time sync
-- PocketRAR 3.71 (with .zip/.rar association)
-- File-Dialog changer (for file browser enhancement)
-- Voice notification & ringtones
-- NetCF 3.5 and SQLCE 3.5
-- Fastest Phone response
-- STK srvice and all the common utilities
-- Almost all the Today item set to hidden (Unhide from Today settings, if needed)
-- Exe's & Dll's transformed to module (wherever possile)
-- Some performance tweaks
-- Dùng chung cho G3/G4
-- 12.5 MB Flashdisk (for G3/G4 both devices)
-- PagePool - 6 MB
-- 128 MB RAM Support (may need to set PP => 0)
*Cab on Flashdisk (need to be installed manually, if required):
-- Windows Live (not tested)
-- Transcriber
[xóa file cab trong flashdisk nếu bạn thấy không cần thiết).
Build v8.0:
http://vidmes.com/xda/Uni/ROMs/Tomal/TML_v80_WM61_19591_19591_1_1_7.exe
Empty ExtROM (optional):
http://vidmes.com/xda/Uni/ROMs/Tomal/Tomal_ExtROM.rar
-- PagePool - 6 MB
-- Transcriber
Build v8.0:
