TẠO VÀ NẠP RINGTONE CHO iPHONE
hehehe1102
các pro ơi cho em hỏi với sao em an vao "send ringtone to iphone" thi no hien ra cai bang la "no iphone connection found,please make sure your iphone is docked" là sao vậy ạ
nana_boo3189
cái này chỉ xài free đc 5 ngày thui hử bạn? có cách nào xài hoài mà k cần phải mua k? hì hì
pitmanfox
Still buy expensive music or ringtone online as your iPhone ringtone?
Now Aiseesoft iPhone Ringtone Maker and Aiseesoft iPhone Ringtone Maker for Mac is exactly designed for iPhone users, with these powerful iPhone Ringtone Maker program, no matter you are Mac or Windows user, make your own unique iPhone Ringtone is so easy!
iPhone Ringtone Maker turns your dream of making your own iPhone ringtone with loved music into reality in the way of converting almost all mainstream video/audio format to M4R iPhone ringtone.
iPhone Ringtone Maker transfers the converted M4R ringtone to iPhone directly after conversion according to your own need. Clipping any music segment you like as ringtone and pre-listening the music enables you to create unique iPhone ringtone. Thus you can hear the featured ringtone when your friends call you.
Key function of these two program:
1. Convert music or audio files of any format to iPhone ringtoneAlmost all audio formats are supported including MP3, WMA, AAC, WAV, OGG, M4A, RA etc. You can easily make your own ringtone for iPhone.
2. Convert videos to iPhone ringtoneIt helps extract music from videos to M4R ringtone. The video formats supported include AVI, MPEG, WMV, MP4, FLV, MKV, H.264/MPEG-4, MOV, RM, M4V, VOB, ASF, 3GP, QT, MPV, etc.
3. Trim input file to get a clip to convertYou can customize iPhone ringtones and set some funny audio clip as your ringtone.
4.Transfer ringtone to iPhone directly without iTunesThere is no need to launch iTunes, just check Export to iPhone and it will automatically transfer the converted files to iPhone after the converting.
5. A built-in player to preview ringtoneIt allows you to pre-listen your created ringtone to make sure that it is the exact one and exact part you need.
6. Edit your RingtoneWith this professional tool you can remove your ringtone from your iPhone as you like. Besides you can also rename your Ringtone at your favor.
longgiang81
Chọn đoạn nhạc chuông đã cắt sẵn tầm 30s, kéo và thả vào iTunes, right-click -> Creat AAC version.
bonblue
Có cái nhạc chuông thôi sao mà khổ thế nhỉ ! Dùng Itunes làm cũng đc mà.
Cách làm bằng iTunes như sau :
Chọn bài Nhạc Click chuột phải Chọn Get InFo => Option => Click vào Start Time và STop Time ( Lấy sao cho đoạn nhạc đó tầm khoảng 40s cũng đc ). Sau đó Nhấn Ok !
Tiếp đến : Create AAC Version chờ chút xíu sẽ có đoạn nhạc ( như mình chọn khoảng thời gian trên ) mình vừa chuyển đổi sau đó bạn Click chuột phải chọn ( cái mình vừa chuyển đc nha ) Show in Windows Explorer sẽ thấy cái File nhạc đó. Copy ra ngoài hoặc đem nó để 1 nơi khác sau này cần dùng tiếp.
TIếp đến lấy cái iFun Box copy vào thư mục ringtones thì sẽ thấy cái đuôi của File nhac là xxx.m4a thì các bạn nhấn F2 lên bài nhạc đổi cái đuôi nhạc xxx.m4a thành xxx.m4r là xong.
TraiNgheoHn
Hướng dẫn tạo nhạc chuông SMS
Không biết bài này có chưa nhưng mình cứ post lên cho mọi người tham khảo. Đã test trên FW 3.0
SMS của iPhone có 7 file nằm trong đường dẫn /System/Library/Audio/UISounds, lần lượt là:
- sms-received.caf tương ứng với Silent
- sms-received1.caf tương ứng với Tri-tone
- sms-received2.caf tương ứng với Chime
- sms-received3.caf tương ứng với Glass
- sms-received4.caf tương ứng với Horn
- sms-received5.caf tương ứng với Bell
- sms-received6.caf tương ứng với Electronic
Để đổi âm báo tin nhắn, bạn tạo 1 hoặc cả 6 file âm báo khác để thay thế. Cách làm như sau:
- Chuẩn bị file nhạc muốn dùng làm âm báo (ngắn thôi nhé!)
- Dùng Switch Sound File Converter hoặc GoldWave để chuyển file nhạc sang định dạng AIFF. Ở đây mình dùng GoldWave
- Đổi định dạng .aiff sang định dạng .caf & đổi tên file thành tên mặc định của âm báo (vd: file nhạc của bạn sau khi đã convert có tên là xxx.aiff, bạn muốn dùng file này để thay thế âm báo Horn thì rename thành sms-received4.caf).
- Dùng iPhone Tunnel copy file gốc của iPhone lưu lại, chép file âm báo vừa tạo lên iPhone để thay thế.
- Vào Settings của iPhone chọn âm báo là Horn, thì bây giờ âm báo tin nhắn sẽ là file âm thanh của bạn.
longgiang81
Đề nghị VIP TraiNgheoHN seach trước khi lập Thread nhé, rất hoan hô tinh thần đóng góp của đồng chí.
LEDU
Em chủ trương là dùng càng ít soft can thiệp vào IP, thế nên theo cách của bác thì em chưa hiểu cái iFun Box này ở đâu vậy bác???
TraiNgheoHn
Tạo nhạc chuông cho iphone(m4r)
Lang thang bên tinhte thấy bài này cũng khá hay post cho anh em tham khảo thêm:
Giới thiệu với mọi người 1 trang chuyển đổi nhạc chuông cho iphone
Mời bạn vào đây và nhấn Upload hoặc enter an URL(nguồn trên mạng)
Tìm đến file cần chuyển đổi
Tải file đó lên
Bạn có thể chỉnh dài hay ngắn sau đó nhấn Create ringtone
Ở đây bạn có thể thay đổi tiêu đề theo ý muốn,khi đã sẵn sàng thì nhấn tiếp Done
Vậy là đã hoàn thành,viêc cuối cùng là lấy xuống dùng thôi
Chúc mọi người có được những ringtone ưng ý nhất
Nguyen_Minh
Em mới dùng iphone nên chưa bik nhìu. Nếu sai chỗ nào các bác sửa cho em nhé. Làm nhạc chuông ch iP thì mở 1 bài hát ra bằng iTunes, nghe xem thích đoạn nào thì án chuột phải vào bài hát, chon get info, mark vào start time với end time, diền tgian bắt đầu và kết thúc vào đó nhưng chỉ trong 30 giây. Ok rồi ấn chuột phải vào baì hát đó 1 lần nữa. Chọn get acc version. Copy cái mới có kia ra ngoài, đổi đuôi thành m4r. Copy vào mục ringtone, sync với iP. Thế là đc
D
duongvuvu123
Guest
còn đây là cách của mình
Bước 1: các bạn dùng phần mềm format factory để chuyển đinh dạng nhạc sang m4r
Bước 2: tìm bài nhạc mà bạn muốn làm nhạc chuông (, ở đây mình lấy bài mỗi ngày tôi chọn một niềm vui làm ví dụ
Bước 3: convert bài hát đó và ngồi thư giãn chờ convert xong
Bước 4: các bạn sử dụng phần mềm winscp, iphonebrower,..... đây là các phần mềm dùng để chuyển file sang iphone.
bên khung bên trái các bạn chọn đường dẫn bài hát mà mình vừa làm xong. bên khung bên trái các bạn chọn theo đường dẫn private/var/stash/ringtones. trong mục ringtones bạn chỉ cần lôi bài nhạc mà mình vừa làm xong qua mục ringtones thôi. Vậy là bạn đã có nhạc chuông cho iphone rồi đấy.
noobnhat
Chương Trình cũa bạn chũ Topic rất GOOD nhưng mới chuyễn được có 3 bài là bị Block hic hic:(:(:(:(
dauphong
Mình tạo được file m4r rồi, sync rồi nhưng sao vào setting/general/rington nhưng vẫn không thấy nhạc chuông mới đâu?????
gaupretty
Cách làm nhạc chuông ngay trên iPhone không cần máy tính!!!
*Vào Cydia tìm cài đặt PhoneZap (phần mềm hoàn toàn Free)
Ưu điểm :
- Không cần tìm kiếm nhạc chuông,download trên mạng.
- Không xin xỏ bạn bè
- Chọn bất cứ đoạn nào trong những bài hát mình thích trong phần iPod.
- Không cần tìm kiếm phần mềm để chuyển đổi.
- Không cần máy tính.
- Tạo nhạc chuông mọi lúc mọi nơi.
Nếu PhoneZap đòi pass (Cho lần đầu):
Chuyển sang phần New user
Gõ tên đang nhập và mật khẩu muốn cài đặt(User + password)
Gõ nơi ở (Cty), quốc gia(Country)
Gõ tên (Name), địa chỉ email(Email) và 1 vài điều về bạn (About -cái này không cần thiết lắm)
Có thể chọn ảnh cho acc của mình ở phần Profile Picture
Cuối cùng chọn Save.
[youtube]NjH-eAHVMRg[/youtube]
Zenki
Tạo Ringtones Miễn Phí FULL trực tiếp trên iTunes
1- Mở iTunes lên
2- Chọn bài nhạc mà bạn muốn làm Ringtones
3- Click chuột phải vào và chọn "Get Info"
4- Vào Tab "Options" đánh dấu Tick vào 2 mục "Start Time" và "Stop Time" - Lưu ý không thay đổi gì ở 2 mục này
5- Xong nhấn Ok và trở lại bài hát, click chuột phải và tiếp tục chọn "Create AAC Version"
6- Sau khi Convert xong sẽ hiện file nằm ngay dưới file gốc
7- Vào thư mục chứa nhạc của iTunes, bài hát bạn vừa Convert sẽ có dạng "m4a" đổi lại dạng "m4r"
8- Sau đó SSH vào thư mục "/Library/Ringtones" bằng iPhoneBrowser hoặc các PM quản lý khác.
Bây giờ vào iPhone chọn bài nhạc vừa Convert xong làm nhạc chuông. Lưu ý cách này sẽ giúp bạn làm nhạc chuông FULL chứ không phải 30 giây như các cách trên.
Chúc vui.
namthanh13
Bác giangho08 ơi cho mình hỏi. Trong iTune chỗ nào để converter thế. Vậy đuôi .mp3 có thể chuyển sang m4r được không. chỉ cho mình với.
