Thông tin mới về fw v60 cho Nokia 5800XM
jackpham
Có 1 mem bên DM đã đưa thông tin về fw v60 cho 5800XM và cả v31 cho N97
O M G... I never thought this was possible... I tried a lot to hack into the Nokia Computers through their link protocall fooling a Nokia priority Dealer system server... I found that Nokia keeps all firmware editing softwares and new un-releases firmware files in some kind of reserved file storage systems behind four firewalls..
Well trying to break their code for more than 5 months.. I finally succeeded!!!
It was not because of my super talent but because of a flaw in their security systems
I downloaded the v60.2.005 from their servers for Nokia 5800 and flashed my phone with it. It is a super awsome firmware..
It fixed the RDS bug
the homescreen is N97's
scrolling like music player in contacts
CPU over clocked to 580Mhz
Some minor improvements in sound quality
the menu is modded, it's somewhat like S^3
But sad that it is the last update for 5800. I found this in one of their Firmware release documents: firm_type_data.pdf
also found there:
N97 is getting an update: v31
The core editor they use is some kinda: Metasource Mobile Systems Firmware Opener
I don't know ... it was the name of the exe in their Firmware labs.. I tried to download it but failed...
but I will try again tomorrow... hope the police dosen't catch me..
--// Post Modified//--- Usta
--Thanks for the link, v60 is working for me but do not post link to warez sites, upload it to a different website//
mathanh
báo bài viết không tồn tại. nếu jackpham tải về rùi thì up lên media cho mình đi
tritran18518
....But sad that it is the last update for 5800. I found this in one of their Firmware release documents: firm_type_data.pdf...
chà, mình thấy tin này mà đúng thì còn động trời hơn cái bản firmware 60 này ^^!
cuongvt112
Bác tritran tinh mắt quá :((, nhưng không sao các pro của PDAViet lại cho ra nhiều bản CFW hay mà, khi đó biết đâu Nokia lại ra FW mới:-?
Anther1991
Hok hiểu sao e hay bị banned nick bên DM hoài. Hu hu, tính đến nay đã bị 4 nick tương đương đổi 4 trình duyệt web rồi :((
ngyntom
đây là một thông tin tốt và chắc cũng hot như những fw trước,rất đang mong đợi,hy vọng lần này ks menu sẽ mượt và hỗ trợ app hiển thị tn,cg như N97
Anther1991
E vào chỉ xem và tải ko hà, có khi thanks người chủ topic. Ko post 1 bài nữa thì làm gì có chuyện spam :(
ngyntom
hihi có khi nào do pò k replay hay thanks mà chỉ download nen mới vậy,chắc nó nghĩ pò chỉ biết hưởng mà k chứ j
minhtri9798
chú ý v60.2.005 => RM-428 mà theo thông thường thì Rm-365 có trước nên thông tin có thể giả
phucthinh
Theo như em cập nhật thông tin từ trang chủ http://nokia.com thì nó ghi là Latest software release for Nokia 5800 Xpress Music is 50.0.005 . Vậy Fw 6 thực sự tồn tại không?
tungtt
Chú ý: 60.0.005 chứ không phải 60.2.005 tức là RM-356 chứ không phải RM-428. :D Không tin search trên google thì sẻ rỏ. Cái nâng cấp này mới đáng giá nhất nè!!! Hy vọng sẻ sớm có cho ae nhờ....waiting................................................................................................
tritran18518
bác ko thấy nó viết là:
có nghĩa là nó đột nhập vào hệ thống của nokia để xem chứ nó có check trực tiếp trên trang nokia đâu ^^!
galabuon
cái này là do down mà ko thx nè :))
bên DM ban nick theo ip, xài ultra surf đi
minhtri9798
google thì bữa trc mình có search rùi, nó kêu là hi vọng nếu có thì sẽ có những thay đổi này thôi
Thanks for the link, v60 is working for me chứng tỏ có V60 :D.Nó ko cho post link trên MD, mong rằng thằng đó up lên MF. Cho anh mathanh up thử nghiệm tiếp đi ;)) chắc ko ra v70 đâu
