BT Voice Bluetooth walkie
Phần mềm gọi điện thoại bằng BlueTooth.
Thích hợp với những ai làm việc văn phòng trong phạm vi gần hoặc những cặp đôi teen đang "Falling in love"
Test good trên N82 và E51
BT Voice Bluetooth walkie-talkie Foe S60v3
This application allows user to make a half-duplex calls via Bluetooth - Application should be run on at least 2 devices (see list of supported devices in above section) - Bluetooth should be 'On' on the device (usually from "Main menu"-"Connectivity"-"Bluetooth") - To activate the service, run application and make sure that it displays "Active" - To display list of available devices - use "Options"-"Refresh" menu item - To check if remote device supports BT walkie-talkie service - select CSK-"Discover services" - If remote revice supports BT walkie-talkie service, you'll be able to make an outgoing calls by pressing "Green" key, CSK, or "Option"-"Call" menu - Once the call is established, you'll be able to send voice message by pressing and holding the "Green" key.
