Kojiro
GhostS60 V1.0
Backup các file đăng ký, config trước khi format. Sau đó có thể phục hồi lại để không mất công đang ký.
Ứng dụng chạy trên nền python.
File config, đăng ký của các phần mềm:
* Default apps:Adobe Reader:
***/Private/20001bb9/20001bb9.ini (configuration file);
* Quicksheet:
***/Private/200002c2/quicksheet.ini (configuration file);
* Zip manager:
***/Private/2000023d/zipmanager.ini (configuration file);
* VideoEditor:
***/Private/10208a29/ManualVideoEditor.ini (configuration file);
* ImageEditor:
***/Private/101ffa91/ImageEditor.ini (set. file);
***/Private/101ffa91/PluginStorage.ini (configuration of plugins);
* Radio:
***/Data/radiostations.db (set. file of the stations);
***/private/101ff976/visualradio.ini (configuration file);
* browser:
***/Private/101F8530/Coocies.dat (kookies);
***/Private/100012a5/DBS_101FD685_BrowserSavges.db (File of the saving pages);
***/Private/100012a5/DBS_101FD685_BrowserBookmarks.db(book-marks, before copying kill a process *FavouritesSrv.exe*, maybethe phone will hang up);
* Calendar:
***/Private/10003a5b/Calendar (set. file );
Notes:
***/Private/100012a5/DBS_101F8878_Notepad.dat (file of the notes);
* Apps from Lonely Cat Games:For registration in all of applications answers:
с:/Private/100012a5/DBS_100065ff_Contacts.cdb ( before copying kill a process *CNTSrv.exe*)
* LCG Jukebox:
!:/private/a0000bcc/MusicPlayer/config.txt (configuration file);
* ProfiMail:
!:/System/Data/ProfiMail/config.txt (configuration file);
!:/System/Data/ProfiMail/accounts.bin (This file is responsible for the setup of your account - your mail servers);
!:/System/Data/ProfiMail/mail/ (folder with the m*es*** headers of m*es from the accounts)
!:/system/data/profimail/m*es.bin (responsible for incoming*** outgoing m*es);
* X-plore:
!:/private/a0000bcd/Explorer/config.txt (configuration file);
!:/private/a0000bcd/Explorer/QuickDirs.bin (file is responsible for the labels);
!:/private/a0000bcd/Explorer/Assoc.bin (file is responsible for the association);
* Slick:
!:/System/data/Slick/accounts.bin (account`s configuration);
* SmartMovie v4.x
!:/private/a000b868/SmartMovie/config.txt
!:/Private/a000b868/xl_config.kls (configuration file);
Apps from Epocware:
* It is intended for the licensed possessors of these applicationsHandy Calculator:
***/private/2000cec6/HandyCalculator.ini (file of registration);
* Handy Calendar:
***/private/20004ec1/HandyCalendar.ini (file of registration*** of configuration);
* Handy Clock:
***/private/200013A4/HandyClock.ini (file of registration);
***/Epocware/HandyClock/Settings.ini (configuration file);
* HandyConverter:
***/private/20007fab/HandyConverter.ini (file of registration);
* HandyProfiles:
***/private/2000A4B2/HandyProfilesServer.ini (configuration file*** file switching profile);
***/private/2000A4B1/HandyProfiles.ini (file of registration);
* HandyShell:
***/private/20013B7B/HandyShell.ini (file of registration*** configuration *apps*** contacts*);
***/private/20013B78/HandyShellServer.ini (configuration file);
* HandyTaskman:
***/private/20004EBB/HandyTaskman.ini (file of registration*** configuration);
* Handy Weather:
***/private/2000139F/HandyWeather.ini (file of registration);
***/private/2000139D/DownloadServer.ini (file of registration IMEI on a server);
***/Epocware/HandyWeather/Settings.ini (configuration file of cities);
* Apps from SmartphoneWare:BestBlacklist:
!:/data/BBlacklist/BestBlacklist.db (file of registration);
!:/data/BBlacklist/BestBlackList.ini (configuration file);
* BestTimer:
!:/private/20012550/Timer_reg.reg (file of registration);
!:/private/20012550/Timers (file of timers);
* BestProfiles:
!:/Private/200095E7/BestProfiles.reg (file of registration);
!:/Data/SmartphoneWare/BestProfiles/settings.dat (Schedule profile switching);
* FSCaller:
!:/private/2000FE63/FSCaller.reg (file of registration);
!:/private/2000FE63/FSCaller.dat (configuration file);
* Best private conversation:
!:/Smartphoneware/BPC/Rules.dat (configuration file);
* System :ActiveFile:
!/:system/data/ActiveFile/Settings/general.ini (configuration file);
* N82smart:
***/Data/N82smart/n82smart.ini (configuration file);
* Smart Settings:
***/private/2000e18c/SmartSettingsSettings.ini (file of registration*** configuration);
* SlideHelper:
***/private/ebe74ca5/SlideHelper.ini (configuration file);
* FreeCallSprite
***/private/e3527aab/FreeCallSprite.ini
***/Data/FreeCallSprite/FreeCallSprite.dic
***/Data/FreeCallSprite/FreeCallSprite.cfg (configuration file );
* Vibrate call:
!:/private/200143DA/regfile.txt (file of registration);
!:/private/200143DA/VibrateCall.ini (configuration file);
* Killme:
!:/ private/EAFE014C/ (folder with a list of programs: protected , removable, unusual, reserved );
* JbakTaskMan:
!:/System/data/JbakTaskMan.ini (all config. of app);
* TaskSpy:
***/private/2000713a/taskspy.ini (configuration file);
* Тracker:
!:/Private/200095EB/Tracker_reg.reg (file of registration);
!:/Private/200095EB/note.txt (notes);
!:/Private/200095EB/options.dat (configuration file);
!:/Private/200095EB/recent.dat (hot keys);
* PowerBoot:
с:/Private/20008A14/PowerBoot.cfg (list of the programs for an autostart);
* Switch off:
***/Private/2001b52e/SOServerSettings.ini (configuration file);
* Kaspersky Mobile Security v7.x
***/private/200112C4/Settings.kls (configuration file);
***/private/200112С4/b.dat (bases of ***s);
* Kaspersky Mobile Security v8.x
***/private/2001CFC6/settings.kls (configuration file);
***/private/2001CFC6/b.dat (bases of ***s);
