Bloove is web-based mobile phone management service. Edit yourcontacts, make calls and work with SMS using your favorite browser.Bloove is like PC Suite for the web. It allows you to manage your phonevia web browser without cables or Bluetooth. Only data connection isneeded.
Contacts
With Bloove it is easy to create, edit and delete contacts on yourphone. Our goal is to provide as much abilities as possible on thephone itself. So Bloove supports changing contact attributes, customlabels, multiple field instances, setting of default values, contactpictures.
Contacts on SIM
You can edit SIM contacts the same way as usual. Plus you can copy contacts from SIM to phone memory and vice versa.
Contact archive
If you have a large contact list, not all contacts are needed all thetime. You can move rarely used contacts to the Archive and get morefree space on the phone. Once you need these contacts you can alwaysmove them back.
Message folders
Bloove provides access to messages in your Inbox, Sent and otherfolders. User folders can be created, renamed or deleted. You can movemessages between folders.
Message archive
If you delete a message on the phone, its archived copy will be storedon the server. You can archive any messages and folders using our webinterface - archived items are deleted from the phone and kept on theserver. Use archive function to unclutter your phone and free somespace. You can search and browse through your entire message listregardless if a message is archived or not. You can always restorearchived messages to the phone in case you need them. Delete forevercommand deletes messages both on the phone and on the server completelyand can't be undone.
Send message/Initiate call
You can send a message either by entering number manually or choosingit from your contact list. Bloove supports sending messages to multiplerecipients. If you are sending a long message, it is usually dividedinto smaller parts. Bloove automatically calculates the number of partsto be send. There is an option to send a Flash SMS, which immediatelyappears on a recipient phone screen.
You can initiate your call remotely on the phone either by enteringnumber manually or choosing it from your contact list. Bloove doesn'troute voice channel to your computer, it just dials the number. You canspeak as usual with your phone or headset.
Browser bookmarks
You can add, edit and delete browser bookmarks and bookmark folders on your phone.
Phone logs
Bloove provides access to logs of your incoming, dialed and missedcalls - with call time and duration and links to the correspondingcontact. Data usage logs (connection time, bytes sent and received) arealso available. All logs from the phone are archived on the serverwithout any specific command from the user. If you delete log record,it will be deleted both from the server and the phone and it can't beundone.
Speed dials
Bloove allows checking and editing your speed dial settings. Speed Dialcan be assigned from contact edit form, or all speed dials can beedited in one list.
Screenshots
Bloove makes phone screenshot and displays it on the phone Propertiespage. You can just right-click on it and save it to the file.
SMS via POP3
You can export all your messages into any Mail client supporting POP3protocol (GMail, Outlook, Yahoo Mail and many others). Use this featureif you want to have all your email and sms communication in one place.
Multiple phones per account
You can copy contacts, messages and bookmarks from one phone toanother. You can use this feature to have your data on both your phones(if you are a lucky user of 2) or to restore data from a lost orreformatted phone.
After downloading and installing agent go to
www.bloove.comwith using your desktop browser, sign up for an account (only user nameand password or OpenID is required) and connect your phone to theaccount by entering ID displayed by agent.
