Trend Micro Mobile Security + Anti-Virus For S60
Các phần mềm hỗ trợ quét vi r u s trên mobile dành cho dòng S60.
IFO :
1. About Mobile Security
Trend Micro Mobile Security for Symbian is a Trend Micro solution for
wireless mobile devices that use the Symbian operating system.
Through a simple interface, users can configure antivirus and
Anti-spam options. Mobile Security antivirus options include the
ability to perform a Manual Scan and Real-time Scan on all files and
folders, with the options to delete, quarantine and deny access to
detected files with viruses and other security risks. Anti-spam
options include the ability to allow or filter SMS and WAP-Push
messages from a configured list of phone numbers, and Bluestab
protection. A Bluestab Denial of Service (DoS) Attack occurs when a
Bluetooth device encounters certain invalid characters as part of a
Bluetooth nickname. Users can also view scan, Anti-spam, and task
logs.
2. What's New
Mobile Security version 2.0 includes these additional security
enhancements and features:
1. Quarantine and Deny access options for handling files detected
2. Protection from harmful WAP-Push messages
3. Scheduled update and Connection settings
4. Bluestab protection
2.1 Resolved Known Issues (from Previous Version)
2.1.1 Manual Scan
Previously, the user could not switch to another application when
Mobile Security is scanning a large compressed (SIS/ZIP) file.
This is now fixed.
2.1.2 Anti-spam
Previously, Mobile Security would occasionally fail to filter a spam
message that arrives immediately after the phone is turned on. This
is now resolved with this version.
3. Documentation Set
In addition to this readme.txt, the documentation set for this
product includes the following:
- User's Guide -- product overview, installation, configuration
instructions, and basic information intended to get you "up and
running."
- Online help -- Context-sensitive help screens that provide guidance
for performing a task.
- Knowledge Base -- A searchable database of known product issues,
including specific problem-solving and troubleshooting topics.
4. System Requirements
Mobile Security has the following minimum system requirements for
your device and a host PC:
4.1 Device
Interface - Series 60 version 2.0
Operating system - Symbian OS 8.1a, Symbian OS 8.0a, Symbian OS 7.0s
Storage space - 3MB minimum free in phone internal storage
Memory - 1.2MB minimum free memory, 2MB recommended
Phones supported in this release are:
* Nokia N70
* Nokia N90
* Nokia 6630
* Nokia 6680
* Nokia 6681
* Nokia 6682
* Nokia 3230
* Nokia 6260
* Nokia 6600
* Nokia 6620
* Nokia 6670
* Nokia 7610
* Panasonic X700
* Panasonic X800
5. Installation
Perform the following steps to install Mobile Security:
5.1 Using PC Suite software on the host PC
1. Copy the setup file, MobileSecurity.sis, to the host PC.
2. Connect your device to a host computer with PC Suite.
3. On the host computer, run the PC Suite software installation
application. A prompt appears on the host PC.
4. Select the setup file and start the installation. Wait for the
progress bar at the bottom of the screen to reach the end of the
bar.
5. Click "OK" on the displayed prompt.
6. Follow the instructions on the mobile device screen to finish
the installation.
7. Installation is complete. Mobile Security now appears in your
"Applications" menu.
5.2 Using Bluetooth
1. Copy the setup file, MobileSecurity.sis, to a Bluetooth-enabled
computer.
2. Transfer the setup file to your phone using Bluetooth. A message
prompt appears on your phone.
3. Select "Show". The Install software prompt appears.
4. Select "Yes". The "Options" menu is displayed.
5. Select "Continue". The license agreement is shown.
6. Carefully read the license agreement, and then click "OK" if you
want to continue installation. A prompt appears, informing you
that Mobile Security can only be installed in internal memory.
7. Select "OK". The installer extracts the SIS file. When
installation is complete, Mobile Security appears in your
"Applications" Menu.
6. Post-Installation Configuration
Anti-spam is disabled by default. Enable Anti-spam if you want to
filter unwanted SMS messages into a Spam folder. For detailed
instructions on enabling and configuring spam prevention, see your
User's Guide.
Note: Trend Micro recommends that you update your scan engine and
virus pattern files immediately after installing the product.
7. Known Issues
Here are the known issues in this release:
7.1 Real-time Scan
While the virus action is in "Deny access" mode, the message
application continues to display a warning sign when it tries to open
a multimedia message (MMS) with a virus attachment.
7.2 Anti-spam
Short message service (SMS)-type messages cannot be received while
Mobile Security is prompting the user whether or not to accept
WAP-Push messages.
7.3 Quarantine
Transferring files via Bluetooth fails when the default action is set
to "Deny access" and when a virus or security risk is restored at
"c:\system\temp\BTObex.tmp".
7.4 Online Help
Mobile Security Context-Sensitive Help does not work on Panasonic
X700/X800.
7.5 Installation
After Trend Micro Mobile Security displays the message "The previous
version has been removed successfully. Please run the installation
package again to install the latest version of Trend Micro Mobile
Security" and the Mobile Security icon is not shown, the user must
run the installation package again to completely install the latest
version of the application.
8. About Trend Micro
Trend Micro, Inc. Provides centrally controlled server-based virus
protection and content-filtering products and services. By protecting
information that flows through Internet gateways, email servers, and
file servers, Trend Micro allows companies worldwide to stop viruses
and other malicious code from a central point before they can reach
the desktop.
Copyright 2005, Trend Micro Incorporated. All rights reserved. Trend
Micro and the t-ball logo are trademarks of Trend Micro Incorporated
and are registered in some jurisdictions. All other marks are the
trademarks or registered trademarks of their respective companies
