XDA ATOM/ATOM PURE - PDAVIET ROM WM6.1 (Core 19212)
Sonblack
PDAVIET ROM WM6.1
CE OS 5.2.19212 Build 19212.1.0.3 PV
=== Only for XDA ATOM/XDA ATOM PURE ===
Lời cám ơn - Thanks: Special thanks to
Man PhamQuang (everything)
Admin Kawaguchi (ROM flashing tool)
Trial Mod PhamNhatThanh (others)
VIP TranMinhMan (welcome screen, calculator skin, others)
VIP nhocbanme (IrDA and Bluetooth)
Thông tin - ROM Information:
Pagepool: 6M
IrDA and Bluetooth: no bugs, please don't complain
This ROM is built based on XIP & SYS 19212 from Kaiser Original ROM WM6.1
Hình minh hoạ - Illustrative Images:
Các chức năng - Main functions:
- CE OS 5.2.19212 Build 19212.1.0.3 PV
- .NET Compact Framework 2.0.7045.0
- Office Mobile 6.1
- Office Note
- Windows Media Player 10.3 Build 19212
- Windows Live for Windows Mobile v10.6.0034.0800
- Adobe Reader LE 2.0
- Advanced Configuration Tool v2.02.0.1.0 by Schap
- ClearTemp v1.0 by Vicott Wong
- Task Manager v3.0 by FdcSoft
- Contacts Manager extension v1.6 by FdcSoft (support copying many contacts from Phone to SIM)
- PIM Backup v2.8.0.0 by FdcSoft
- HTC Sim Manager for Pocket PC v6.47
- Synchro Time v0.95 by Dennis Grachov
- WM5torage v1.8 by V. Bozhko
- Esmertec Java Build ID: 20080222.3.1
- Total Commander CE v2.5 by Christian Ghisler
- Mode SMS (change message display on PPC)
- PCM Keyboard v0.14 (support Vietnamese keyboard)
- X-Button for PocketPC v1.51 (Build 30744)
- Network Wizard for PocketPC v1.0 (Build 29982.1.0.1.7) (support Mobifone, Vinaphone, Viettel for setting GPRS configuration)
- Now, support SuperSIM
- and more ...
- Change icon inside program folder and other application icons.
Hướng dẫn - Guides:
Máy tính của bạn phải được cài đặt Microsoft .NET Compact Framework 2.0.
Tải file nén chứa ROM, giải nén với pass: PDAVIET, chép 2 file bên trong vào bất kỳ thư mục nào trước khi up rom (trừ thư mục C:\Windows\Temp). Kết nối PC và PPC bằng ActiveSync, chạy file exe.
Your PC has to be installed Microsoft .NET Compact Framework 2.0.
Download RAR file included ROM, uncompress by pass PDAVIET, copy 2 files inside into any folder before flashing the ROM (except folder C:\Windows\Temp). Connect PC and PPC by ActiveSync, run exe file.
Link download đã có sẵn.
The link will be availabie now.
Note - Lưu ý:
Để tải ROM, các thành viên sử dụng Username và Password chung là PDAVIET
To download ROM, the members use both Username and Password are PDAVIET
Chúc vui.
Enjoy it.
Sonblack
TranMinhMan
Wow, so hot! Black Diamond Atom ROM!?:-?
Chúc mừng anh Sơn ra ROM "bờ lách" nha!!!
kamikazee2004
anh Sonblack ơi link không down được roài.anh dùng link khác đi.em nhìn là thích rom của anh rồi!
Sonblack
Link download không vấn đề gì đâu bạn
Mình xin lưu ý tất cả các bạn nhé:
- Link không vấn đề gì cả.
- Nếu không down được thì có nhiều nguyên nhân:
+ Do trình duyệt.
+ Do trình hỗ trợ download
Tốt nhất các bạn nên dùng FlashGet hoặc IDM để tải ROM, và lưu ý phải nhập User và Password là PDAVIET và PDAVIET để tải file về.
icecreamvn
Wow phải down về thử mới được. Nhìn đẹp quá .......... Thanks anh Son Đã liên tục update rom mới cho dòng Atom. Lần này cách Up cũng được cải tiến, không phải bắt buộc chép vào trong thư mục C:\windows\temp
icecreamvn
Anh SOn oi giúp em với, em up không được. em click vào file ễ no cứ báo "The application failed to initialize properly (0xc0000135). Click on OK to terminate the application. :(( . Làm sao giờ đây anh Son Uiiiiiiiiiii !!!!!!!!!!!!!!
Sonblack
Download ROM lại lần nữa và thử xem. Có thể file ROM bị lỗi trong quá trình download.
Các thành viên khác có gặp tình trạng khi up rom này tương tự như icecreamvn không?
hien1982
mới down về nhưng quả thật là Rom bị lỗi rồi, mình ko up được, anh Sơn xem lại dùm anh em nha anh Sơn
JohnDeer
Sao mình cài bản Kumura gì đó thì ok, nhưng mà cài mấy bản của bác thì con Atom của mình toàn ngỏm ở Stage 1, 100%. Sau khi Hard Reset lại vẫn dùng được nhưng ko biểu có ổn đinh ko nữa???
icecreamvn
Hix em làm dịch vụ nên thử o nhiều máy lắm. máy em cài winXP, em đã thử download lại nhưng vẫn bị như vậy. chạy thử bản củ 19213 của anh thì vẫn ok anh ạ. Anh thử nén up lại nữa xem anh, co thể quá trình nén bị lỗi. Hoặc anh download thử cái file đó và chạy thử xem anh. Cũng có thể máyn em thiếu thư viện dll. Nhưng không biết file nào để bổ sung, thì cũng đành bó tay :(( , nếu có thể anh edit lại tool upgrade room như bản 19213 được không anh.
Sonblack
Đang test và kiểm tra lại mọi thứ và nhận thấy rất bình thường, không có bất kỳ lỗi gì!
Các bạn lưu ý điều này, bên trong có 2 file như bên dưới:
- PDAVIET_ROM_WM61_OS19212_ATOM_Diamond.exe
- PV_Sign.dat
Phải giải nén bằng WinRAR với Password là PDAVIET.
Giải nén xong, 2 file này có dung lượng lần lượt là: 89.089.172 bytes và 214 bytes
Chép chúng vào cùng 1 thư mục gốc hoặc thư mục bất kỳ của bất kỳ ổ đĩa nào và chạy file
Mọi thứ rất bình thường mà!
JohnDeer
Download bình thường, chạy bình thường ko báo lỗi, chỉ mỗi tội con Atom của mình vẫn stuck ở Stage 1 - 100%. Bó tay luôn!!! Nhưng phải công nhận là mấy bản của bác này nhìn rất đẹp, nhiều soft hay và hữu dụng nữa. Dù sao cũng thank bác rất nhiều!
icecreamvn
Cuối cùng em đã hiểu ra vấn đề :D . Máy em thiếu Net Frame Work 2.0, nên không thể chạy ứng dụng đó được giờ em đã chạy được rồi Thanks anh Son nha. Để em cài thử bản Rom mới của anh. ;;)
Hình như đã chỉ qua Yahoo hồi sáng rồi mà ta! (Sonblack)
hien1982
cuối cùng cũng ko up rom được,up bản rom cũ thì ko vấn đề gì, còn làm như anh Sơn máy báo lỗi createfilec:\windows temp fail, dù máy tính đã cài Net Frame Work 2.0
gianghuutai
- PV_Sign.dat
Bạn cho mình hỏi là sau khi mình download cái rom nay về và uprom thi lai không phải là bản WM 6.1build 19212 như trong hình vẽ mà bản của tôi lại là Rom: 6.1 build 19209.1.0.0. Tôi đã up đến 2 lần mà vẫn là bản build 19209. Xin bạn giúp mình với
TranMinhMan
Bạn vào thư mục C:\Windows\Temp xóa hết các file cũ, rùi chạy ctr up ROM lại nha!
Chúc thành công!
:D
TranMinhMan
Bạn xem lại đường dẫn mặc định của thư mục Temp do Windows set trên máy bạn. Có thể ko còn là C:\Windows\Temp nữa mà là Documents and Settings\User đang sử dụng\Local Settings\Temp, set lại đường dẫn cho đúng là bạn up ROM được thui.
Chúc thành công!
:D
minhdakai
Chúc thành công!
:D
cám ơn MinhMan nhieu
Để khắc phục điểm này các bạn có thể chỉnh registry hoặc có thể làm như sau:
1. Làm như Sonblack, chạy file *.exe, xong nó báo creatfile C:\Windows\temp fail
2. Bạn nhấn ok, xong dung task manager tắt file *.exe đi
3. vào thư mục C:\Documents and Settings\User đang sử dụng\Local Settings\Temp chép hết mấy cái file dùng up rom cho vào thư muc C:\Windows\temp (gom các file nova_pda_033105.mot, diskimage_Ver.nb0, ExtendedRom, EBOOT.nb0, vl1d_pda_Ver.mot, PDAVIET_ROM_WM61_OS19212_ATOM_Diamond)
4. chạy file PDAVIET_ROM_WM61_OS19212_ATOM_Diamond trong thư mục C:\Windows\temp và up như bình thường
regards,
