XDA ATOM/ATOM PURE - PDAVIET ROM WM6.1 (Core 20757)
Sonblack
PDAVIET ROM WM6.1
CE OS 5.2.20757 Build 20757.1.4.0 PV
=== Only for XDA ATOM / ATOM PURE ===
Lời cám ơn - Thanks:
Manager PhamQuang
Admin Kawaguchi
ROM Dev Dvha79_ddt
Mod Lamson, TranMinhMan, Hoangdat_vista
Trial Mod PhamNhatThanh, khacduy1978
VIP Medkid, nhocbanme, nhattoai
herg62123, poorlyduck, A_C and greatbal from xda-developers
Thông tin - ROM Information:
- CE OS 5.2.20757 Build 20757.1.4.0 PV
- Pagepool: 6M
- Rom date: November 6, 2008
- ROM Version: 20081106D1WWE
- Transcriber included.
- Manilla 2D with Black Skin also included.
- Remove all help files.
- XIP & SYS from latest original ROM of Touch HD
Hình minh hoạ - Illustrative Images:
Các chức năng - Main functions:
- AudioManager v2.0.1819.2129 (HTC Opal)
- JBlend Java (HTC Opal)
- Outlook Enhancement (HTC Opal)
- Picture Enhancement (HTC Opal)
- Comm Manager v2.7.1.8 (HTC Opal)
- Manila2D v1.00.1819.2926 (HTC Opal)
ArcsoftMMS v5.0.31.50 (HTC Opal)
- S2U2 v1.33 by A_C
- S2P v0.55 by A_C
- HTC Sim Manager for Pocket PC v6.58
- Enlarge Start Menu
- Enlarge TitleBar
- .NET Compact Framework 3.5.7283.0
- Office Mobile 6.1
- Office Note
- Google Maps (automatically run)
- Opera Browser (automatically run)
- Windows Media Player 10.3 Build 20757
- Advanced Configuration Tool v3.3 by Schap
- SIPChange (automatically run)
- PHM Registry Editor v0.70 for Pocket PC by Philippe Majerus
- Pocket RAR v3.80 by Alexander Roshal
- ClearTemp v1.1 by Vicott Wong
- PIM Backup v2.8.0.0 by FdcSoft
- Pocket Screen v1.3 by JJM. Roseboom
- Synchro Time v0.95 by Dennis Grachov
- WM5torage v1.8 by V. Bozhko
- Total Commander CE v2.51 by Christian Ghisler
- WKTask v1.1.7.3 (open/close applications fastly)
- Network Wizard for PocketPC v1.0 (Build 29982.1.0.1.7) (support Mobifone, Vinaphone, Viettel for setting GPRS configuration)
Hướng dẫn - Guides: Vui lòng đọc kỹ - Please read carefully
Chỉ cần tải file .exe chứa ROM, chạy file .exe trên PC và làm theo các bước chương trình yêu cầu cho đến khi hoàn tất. PPC của bạn sẽ tự hard reset khi mọi thứ hoàn thành.
The only thing you have to do is download the .exe file including ROM and perform a double click on it (off course, on PC), then follow the guide step by step that the program requires until it finishes. At the end, your Atom will automatically perform a hard reset.
Link đã có sẵn - The link is available now
Link nằm trong file đính kèm ở cuối bài - Link is put under attached file at the end of this post
UP ROM VỚI TÙY CHỌN "OS+ExtendedROM".
FLASH THE ROM WITH OPTION "
OS+ExtendedROM".
Note - Lưu ý:
Để tải ROM, các thành viên sử dụng Username và Password chung là PDAVIET
To download the ROM, use both Username and Password PDAVIET
Chúc vui!
Enjoy it!
Sonblack
Atomo2
Chưa nhìn thấy giao diện ra sao nhỉ? Mất chương trình PDF roi. (phải tự cài roi)Hy vọng tốt hơn bản trước 20924. Pm PHM traylaunch rat hay sao lai bỏ nhỉ?. Tối qua up bản 20924 nhưng lổi camera và giao diện và chương trình ko hay, ko tiện lắm nên sáng nay mới up lai bản 20755. Ai dè bây giờ chuẩn bị có bản mới roi. Hy vọng nhiều-Thanx!
AnhPheCT
Ôi lại 1 đêm ko ngủ nữa rồi!!! Thế mới là đam mê!!! Thế mới ghiền Rom chớ!!! Nhưng tiếc mình ko có thời gian học cách Build Rom....! Chỉ biết test thôi!!! Hy vọng có thời gian nhờ mấy ROM Dev chỉ giáo!!! Cảm ơn!!!
takaru
nhanh vậy sao , huhuhuhu . mới tối hôm qua còn ....Màu đen pro đã trở lại
KiD2034
Vọc Rom Vọc Rom pà kon, sướng wóa ,Rom 20924 vọc bấy nhầy rùi mà chưa tìm ra cách bỏ Reset trong soft key (cái đó nó nằm trong Manila2D cài Advanced Configuration và M2D cũng pó tay kô sửa đc):((.Định tìm soft khác mà kô ngờ có Rom mới òi, khỏi kiếm chi cho mịt :p Bây giờ là 7h nữa còn 120 min nữa 9h = tương đương với 120 lần F5 Refresh he he he >:) (Kô wên cảm ơn bác Sơn 1 fát)
KiD2034
Cái Clock bự wóa kô bik có để hình bx làm hình nền đc kô nhỉ:-?? KÔ để là bx óanh chít :(( . Hy vọng sẽ để đc hình bx giống Manila 2D :D Còn 100 min nữa tới giờ linh rùi F5 thêm 100 lần nữa.
KiD2034
Tình hình là 8h rùi , theo như thông tin thì trc 9h sẽ có, hồi hộp wóa , còn 60 lần F5 nữa (vô CF vài ván) :D
P/S : Bác Sơn cứ từ từ thong thả mà up , kô có gì đâu , đợi đc mà, càng trễ Rom càng HOT :p
Caohieu88
Hồi hộp chờ đợi, lại một đêm mất ngủ. Trở về tông màu truyền thống của anh Sơn rùi ^ ^
Trùi đất ơi lâu quá đi mất bác sơn ơi
toàn thể anh em đang chờ bác đấy!
nóng ruột bỏng mất thôi !
ôi !!! nghĩ tới lúc có ROM mới vọc thì đã quá!
giá như bác sơn có thể cho thằng Tuoch 2D đó lướt web bằng IE thì tốt quá không phải cài OP 9.5 làm gì nặng quá! mỗi khi mở đều phải khởi động lại Tuoch chán ghê!
kain87
Theo mình cái Google Map không nên tích hợp vào Rom, vì nó chiếm dung lượng khá lớn, để tự cài là hay nhất.
AnhPheCT
Chiêm ngưỡng đỡ đi!!! Manilla 2D Black!!!
Hình méo quá!!! Clock to che khuất hình mất !!! Ha ha Nhưng thú vị... Còn 1 phút nữa!!!!
Sonblack
Khi up rom xong bạn sẽ thấy là nó cài đặt hay nhét hẵn vào rom nhé! =)) Tốt nhất là đừng nói gì khi chưa biết thực hư thế nào! Chú có làm ra nó đâu?
@All: Nếu spam thì mình chỉ có thời gian del bài chứ không chỉnh được rom. Chọn cái nào? :D
KiD2034
Vậy sao để hình bx làm hình nền đc chài,hix hix,phen này up ROM anh Sơn xong là no đòn với bx chắc luôn.:(( Nhưng kô vì thế mà kô UP Rom đc.
Mấy cái Cabs nếu ai kô thích cài thì bỏ SDAutorun.txt là xong thui,mún cài cái nào thì cài cái đóa càng nhìu cabs thì càng tốt chứ sao.Tha hồ cho bạn lựa chọn.
P/S : Lệnh của đại ka Sơn : Cấm spam dưới mọi hình thức :D
