XDA ATOM/ATOM PURE - PDAVIET ROM WM6.1 (Core 21014)
Sonblack
PDAVIET ROM WM6.1
CE OS 5.2.21014 Build 21014.1.6.0 PV
=== Only for XDA ATOM / ATOM PURE ===
Lời cám ơn - Thanks:
Super Mod PhamQuang
Super Mod BatKid
Admin Kawaguchi
Adv. Mod Dvha79_ddt
Mod Lamson, TranMinhMan, Hoangdat_vista
Trial Mod PhamNhatThanh, khacduy1978, nhattoai
VIP Medkid, nhocbanme
herg62123, poorlyduck from xda-developers
Thông tin - ROM Information:
- CE OS 5.2.21014 Build 21014.1.6.0 PV
- Pagepool: 6M
- Rom date: January 14, 2009
- ROM Version: 20090114E0WWE
- ExtendedROM Version: EX0901
- Well supported A2DP
- Transcriber included.
- Manilla 2D with Blue Skin also included.
- Remove all help files.
- XIP & SYS from xbeta.cn
Hình minh hoạ - Illustrative Images:
Chức năng chính - Main functions:
- Internet Explorer 6 for Windows Mobile
- AudioManager v2.0 Build 1820.1321 (Elfin)
- JBlend Java v3.3.5 Build 20081015.1.1 (Jade)
- Outlook Enhancement (Elfin)
- Picture Enhancement (Elfin)
- Comm Manager v2.7.2.8
- ArcsoftMMS v5.0.31.63 (Elfin)
- Enlarge Start Menu (Moderate from Elfin)
- Enlarge TitleBar (Elfin)
- Manila2D from Elfin (Moderate)
- HTC Sim Manager for Pocket PC v6.58
- .NET Compact Framework 3.5.7283.0
- Windows Media Player 10.3 Build 21014
- Office Mobile 6.1
- Office Note
- HTC Album (Moderate from Elfin)
- SIPChange (automatically run)
- Advanced Configuration Tool v3.3 by Schap
- Pocket RAR v3.80 by Alexander Roshal
- ClearTemp v1.1 by Vicott Wong
- PIM Backup v2.8.0.0 by FdcSoft
- Pocket Screen v1.3 by JJM. Roseboom
- Synchro Time v0.95 by Dennis Grachov
- WM5torage v1.8 by V. Bozhko
- Total Commander CE v2.51 by Christian Ghisler
- WKTask v1.2.0.0 (open/close applications fastly)
- Network Wizard for PocketPC v1.0 (Build 29982.1.0.1.7) (support Mobifone, Vinaphone, Viettel for setting GPRS configuration)
Hướng dẫn - Guides: Vui lòng đọc kỹ - Please read carefully
Chỉ cần tải file .exe chứa ROM, chạy file .exe trên PC và làm theo các bước chương trình yêu cầu cho đến khi hoàn tất. PPC của bạn sẽ tự hard reset khi mọi thứ hoàn thành.
The only thing you have to do is download the .exe file including ROM and perform a double click on it (off course, on PC), then follow the guide step by step that the program requires until it finishes. At the end, your Atom will automatically perform a hard reset.
Link đã có sẵn - The link is available now
Link nằm trong file đính kèm ở cuối bài - Link put under attached file at the end of this post
UP ROM VỚI TÙY CHỌN "OS+ExtendedROM".
FLASH THE ROM WITH OPTION "OS+ExtendedROM".
Note - Lưu ý:
Để tải ROM, các thành viên sử dụng Username và Password chung là PDAVIET
To download the ROM, use both Username and Password PDAVIET
Chúc vui vẻ!
Enjoy it!
Sonblack
AnhPheCT
Tối nay lại thức nữa rồi!! Có Rom mới vọc rồi!!! Cảm ơn Anh Sơn nhiều lắm!! Năm mới tết đến Anh Sơn cũng dành nhiều thời gian cho A-E quá!!! Biết nói gì đây....! Chúc Anh Sơn cùng Gia Đình năm mới hạnh phúc và thành đạt!!!
pal2000
Tối nay lại canh giờ down Rom mới rồi, cảm ơn bác Sơn đen nhiều. Chúc bác năm mới an khang thịnh vượng. :D:D:D
Chuẩn bị ông Công ông Táo rồi mà bác vẫn có thời gian up rom cho anh em. Bái phục bái phục
Sonblack
Link đã có sẵn, chỉ thay đổi core và build mới mà thôi!
Chúc cuối tuần vui vẻ!
The link is available now, only upgrade core and build for ROM.
Have a good weekend!
Caohieu88
Anh Sơn đổi phong cách mới post bài buổi chiều thế này tối đỡ phải thức khuya :D . Mà anh đang ở chỗ Offline UIQ ạ??
duclinh84bk
lúc trước thấy có bản core 21109 thì core của nó mới hơn bản 21014 này sao? Sao bác sơn ko cùng cái core đó nhỉ?
Sonblack
Nguồn gốc và chất lượng build mới quan trọng.
Không hẳn là chỉ số nhỏ hơn là cũ đâu nhé! Chịu khó tham khảo đi!
Stone_ll
Hi,Sonblack。I know you can understand my words。 =D>
问题是:
不知道为什么,我刷了你每次发布的E
文rom然后安装中文语言包(例如宋体or雅黑)后,都会对系统造成effects.比如速度减慢,容易死机等请。not'经常', but'容易死机'
不知道你能否查查是什么原因呢?
我现在用的中文rom还不错。但是我更 like英文rom。希望你能查查。谢谢。
附:我使用的两种字体:
雅黑6.0 提取码:f8c25329
http://61.dc.ftn.qq.com/ftn_handler...f54533523326b0f5b084b78606b715016531c56525039
宋体 提取码:e29a3c8b
http://51.dc.ftn.qq.com/ftn_handler...e02337238300c515218600a5511105c0f2c1d00590065
sen68
Có ai bị lỗi khi chụp hình thì màn hình liên tục nhấp nháy không?Bản Rom trước của a Sơn mình không bị,nhưng khi up lên bản này thì lại bị.thanks
KiD2034
Cái vấn đề Camare nhấp nhái này nói hem bik bao nhiêu lần rồi bạn ơi,chỉ cần Soft Reset lại vài lần cho đến khi nào hết bị thì thôi:-?.Camare mình thì bình thường.:|
johnson9931
问题是:
不知道为什么,我刷了你每次发布的E
不知道你能否查查是什么原因呢?
附:我使用的两种字体:
雅黑6.0 提取码:f8c25329
宋体 提取码:e29a3c8b
yes,Mr. Sonblack's ROM is wonderful! but there are some unknown problems for my device(and maybe someone else who installed Chinese language Plus):the device hang up and halt occasionally when the other programms are running with no reasons!it might not happened to those who use clean English ROM,but for those who installed Chinese language Plus,it's really a trouble!(i have try lots of plus but the problem still exist!)
AnhPheCT
Từ Bản v21XXX trở lại đây. Vấn đề Camerra cho dù Reset lại cũng hên xuôi hà!! Cho dù Storage còn hơn 20M Programs còn hơn 15M cũng ko thể khởi động được Camera nhé!! lúc được lúc ko!! khỏi bàn nhé!!! Camera ko có lỗi chỉ Nó chiếm bộ nhớ nhiều thôi!!! Có khi tắt TouchFlo cũng ko khởi động dc!!! Vì chụp hình Atom xấu quá mình cũng chẳn quan tâm.... ha ha!!! Good luck!!!!
maxupload
Dear sonblack,
Thanx a lot for new ROM.....
Here I am again requesting you to add RemoteTracker or similar application to save our atom from thieves with hardreset safety....
Thanx in advance..
advshadab
Dear sonblack,
Thanx in advance..
You'll have to do that yourself under extended rom, because hard reset will delete your personal info.
hieu247
Hi! Chào mọi người! mình xin đóng góp ý kiến thế này!Anh Sơn build rom tích hợp Manila 2D đã qua mấy phiên bản rùi. Hiện nay Iphone đã quá phổ biến, kô biết mọi người có nghĩ đến chuyện thay giao diện Manila thành Iphone kô? mình đã từng cài các soft để cho máy có giao diện Iphone nhưng dùng thấy kô ổn định lắm. bây giờ anh Sơn ra tay thì tuyệt..
Sonblack
Có lẻ, mình sẽ không làm giao diện này vì chưa có giao diện loại này hoàn hảo, cho vào ROM sẽ phát sinh nhiều thứ khác cần giải quyết, trong khi mình không có nhiều thời gian cũng như các ứng dụng cần thiết.
