nguyennam0625
Các bạn cho hỏi mình dùng sensation 4g t-mobile thì có thể dùng bản rom XE để có beat audio ko? Thanks.
Chỉ cần Wipe Cache & Dalvik Cache, sau đó flash ROM bình thường thì đâu có mất dữ liệu đâu bạn!
Flash 6.5.4 XE, vẫn dính cái lỗi "wifi randomly turning ON".
Đây hình như là lỗi của Sense 3.6, đang dùng Sense 4.0 không gặp tình trạng này. Lỗi này Insertcoin 5.1.7 cũng bị.
Sao mình cài bản mới 6.5.4 lại mất thanh status nhỉ , bác nào chỉ giúp với
Kernel faux123 và kernel sebastianFM, cái nào chạy ngon + tốt hơn nhỉ?
First: I'm running 1.30.4 (1.728Ghz version, no control app, just letting kernel work with OnDemand Governor). Battery life is actually better than ever for me.
Now the differences between Faux and Sebastian:
Sebastian's is basically a stock kernel, with CPU and GPU clocks modified. There are fixes for Touch screen, there are optimizations, you may run Zram compression if you're so inclined. The experience is basically stock but much smoother, faster and very stable. Excellent work, clean and thoughtful, resulting in a reliable transparent kernel.
Faux takes a different approach. He deconstructs, rethinks and puts together mad genius art. His kernels are very power efficient (it seems that's his main focus). They are far from stock and as such, occasionally behave in less than predictable ways. The latest for ICS works beautifully. It gets rid of MPdecision allowing both cores to interact more powerfully. The result is excellent battery, excellent speed but it runs a bit warmer than you'd expect. If you love to experiment and reap rewards, Faux's kernels are amazing. If you're a whiner and want commercial-grade product, look elsewhere.
I can't believe how lucky we are to have such brilliant, hard-working developers working on this platform (OK show-p, you too!!).
Cái này tùy bạn cài và tùy bạn cảm nhận thôi, tôi trích lại phần giải thích trên xda cho bạn:
Best Regards
Cho e hỏi Wipe Cache & davik có ý nghĩa gì vậy? E đang cài nhìu game và ko muốn mất nhưng data cũng như file save tren đó.Cái này là tùy mỗi máy, máy mình flash xong dùng bình thường không bị nóng. Trong quá trình Flash thì:
1. Vào Recovery, Wipe Cache & davik
2. Flash Rom:
2.1 Chọn Bravia Engine
2.2 HTC Sen 4g không chọn
2.3 Lựa chọn SebastianFM kernel
3. Sau khi máy boot xong, dùng Titanium remove hết mấy cái ứng dụng linh tinh đi.
4. Flash 2 mod là HQ Camera và Leedroids Tweaks 3.0
5. Cài thêm JuiceDefender Ultimate
---> Máy chạy ngon, không hiện tượng gì. Mike sắp ra bản 6.5.5 XE rồi)
Regards
Dalvik cache is a place where the Android OS re-compiles the executable programs the first time to optimize them. It only needs to do it once which explains the "cache" part -- unless you make a major change like replace the kernel. If you do that, you want to manually clear the Dalvik cache to force Android to recompile the apps for the the new kernel.
The main data Cache is used by the Android OS at runtime to write temporary files for specific reasons. You want to clear this out when you try a new ROM so it doesn't re-used that cached data.
Manually clearning both caches out allows the new ROM to be installed in a "cleaner" environment.
Android Revolution HD 6.5.5 --- release date: 29 March 2012 ---
Faux's kernel updated to 002
Restored original systemui.apk
Switched to deadline scheduler
Google Maps updated to latest 6.5.0
- No need to Super Wipe if you have 6.5.x already!!
- 3.32.401.x firmware is required!
- 4EXT Touch Recovery is required!
- HTC Sensation 4G (U.S. T-Mobile PG5810000 | T-MOB010) users can flash this for better signal and data speeds!
For people having boot loops when selecting faux's kernel when flashing ARHD 6.5.5 do the following to fix and give you faux kernel:
- download faux latest release kernel (link below)
- flash ARHD 6.5.5 choose stock or sebs kernel
- before first boot immediatly flash faux kernel
