[08/10/12] Android Revolution HD™ 6.8.0| ICS | High Quality & Performance | Sense 3.6
ntt2006
**ICS 4.0.4**[ROM]Android Revolution HD™ | Sense 3.6 | ICS & Wi-Fi calling | High Quality & Performance
Proudly presenting you the most popular ROM for HTC Sensation, Sensation 4G & Sensation XE...
Nguồn XDA
http://forum.xda-developers.com/showthread.php?t=1098849
System details:
    • Android 4.0.3 (Ice Cream Sandwich) - latest official HTC 3.33.401.153 (WWE) firmware with Beats Audio
    • Android 4.0.3 (Ice Cream Sandwich) - latest official HTC 3.33.401.53 (WWE) firmware
    • Android 4.0.3 (Ice Cream Sandwich) - latest official HTC 3.32.531.14 (U.S. T-Mobile) firmware
    • This ROM will turn your HTC Sensation into powerful HTC Sensation XE with Beats Audio technology and 1.5 GHz dual core!
    • This is improved version of stock ROM - no visual changes!
    • Very fast, clean & stable!
    • Full HTC Sense 3.6 Interface
    • Multi-language (WWE)
    • HTC Sensation 4G (US T-Mobile) support with Wi-Fi Calling
    • For HTC Sensation, HTC Sensation 4G & HTC Sensation XE
    • Thanks to HTC for the base firmware
ROM details:
    • Removed software (CPU) rendering - full Adreno220 (GPU) rendering
    • Fully optimized and tweaked
    • ROOT (su + SuperSu Permissions - Thanks to chainfire)
    • Unsecured boot.img
    • Newest BusyBox
    • RAM optimizations
    • System signatures check enabled for system security and safety
    • Improved Adreno220 configuration for better quality and performance!
    • Improved virtual memory management
    • Speed optimizations
    • Enabled GPU UI rendering
    • SD Card speed tweak
    • Data, cache and system partitions mounting tweaks
    • Bloatware applications removed
    • All /system applications updated to latest available
    • All /data applications updated to latest available
    • Improved camera performance
    • Improved CPU governors performance
    • Most optimal system scheduler
    • Disabled kernel debugging for better performance
    • ZRAM ready!
    • Advanced Power Menu and CRT Animation as extra add-ons
    • Zipaligned (Improved RAM management)
    • Zipalign on boot (for user applications on data partition)
    • Fully de-odexed
    • init.d scripts (BusyBox run-parts) support
    • Auto init.d permissions set on boot
    • sysro/sysrw commands support
    • Excellent battery life!
    • Improved EXT4 performance
    • You can replace HTC boot animation with any custom one (or use ICS default)
    • SD card EXT4 partition support
    • OpenVPN support
    • 4EXT Recovery (Thanks to madmaxx82)
    • Most up-to-date system files permissions
    • Adobe Flash Player support for Ice Cream Sandwich
    • Support almost 24h a day
    • ...and many more!
Changelog:
Android Revolution HD 6.8.0 (Firmware 3.33)
--- release date: 8 October 2012 ---
  • [*=left]Re-based using latest 3.33.401.53 & 3.33.401.153 HTC RUU
    [*=left]Faux kernel updated to latest 10b4
    [*=left]SebastianFM kernel updated to latest 1.5.2
    [*=left]SuperSu updated to latest 0.95
    [*=left]SuperSu binary updated to latest
    [*=left]Adobe Reader updated to latest 10.3.2
    [*=left]Adobe Flash Player updated to latest 11.1.115.17
    [*=left]Dropbox updated to latest 2.1.10
    [*=left]ES File Explorer updated to latest 1.6.2.1
    [*=left]Google Maps updated to latest 6.12.0
    [*=left]Google Plus updated to latest 3.1.1.32879387
    [*=left]Google Play updated to latest 3.8.17
    [*=left]Facebook updated to latest 1.9.10
    [*=left]YouTube updated to latest 4.1.23
    [*=left]Twitter updated to latest 3.4.0
    [*=left]Other minor changes and fixes
Hướng dẫn up rom:
1- Yêu cầu máy phải được :
- S-Off, Recovery, Root và supercid.
Tham khảo http://www.pdaviet.net/showthread.ph...-CHO-SENSATION
- Nên up 4EXT Recovery Touch.
Tham khảo http://forum.xda-developers.com/show...=4ext+recovery
2- Download các file cần thiết
- Firmware 3.32, Rom theo link đính kèm.
- File Super Wipe
- Các addon nếu có.
3- Sau khi download xong thì copy các file đó vào thẻ nhớ.
4- Đưa máy về chế độ recovery.
5- Chọn wipe/format trong recovery và tiến hành các trình tự wipe từ 1 đến 5 trên màn hình recovery
6- Chọn cài đặt từ thẻ nhớ.
7- Chọn cài đặt file super wipe để làm sạch cái file của rom cũ, máy sẽ tự reboot và vào lại recovery.
8- Chọn cài đặt file rom, trong quá trình cài đặt nếu có yêu cầu chế độ cài đặt full wipe thì khuyến khích theo yêu cầu này để rom hoạt động tốt.
9- Sau khi cài đặt rom hoàn thành thì bấm back ra màn hình chính của recovery và chọn mục power cuối cùng.
10- Chọn reboot đến bootloader, máy sẽ khởi động vào bootloader và chọn fastboot. máy sẽ load file FW và bấn nút volume up để tiến hành up FW.
11- Sau khi cài đặt xong thì chọn reboot máy.
12- Ở tiến trình cài đặt đầu tiên hơi lâu, khoảng 10 phút.
13- Khi đã cài đặt rom hoàn chỉnh thì xoá các file đã nêu trên khỏi thẻ nhớ.
DOWNLOAD
Firmware package
--- It's necessary to flash new firmware package before flashing this ROM ---
--- Firmware package contains newest radio for 6.7.x ROMs ---
--- MD5 Checksum: 5A45A0A9A7C90CEE3CF6B35715E71F31 ---
Android Revolution HD 6.8.0 XE with Beats Audio
--- MD5 Checksum: 069A03B755B1A65256141743F3EB6CF2 ---
Android Revolution HD 1.2.2 T-Mobile
--- MD5 Checksum: 98F030E6E11726813B36BA843E2BDAA4 ---
Super Wipe
--- This script will erase and format your data, system and cache partition ---
--- Your SD card will remain untouched FAT32 and it's recommended to leave it like that ---
Radio
--- With 6.7.x ROMs I strongly recommend flashing 11.76A.3504.00P_11.24A.3504.31_M radio ---
--- Don't flash RADIO from ClockworkMod recovery! Extract downloaded file and read the guide inside! ---
--- MD5 Checksum: F06C55BC45716180EB3D145047042F1B ---
--- Using a "non matched" radio could have a negative effect on performance, battery life & signal strength ---
--- You don't have to flash RIL files for recommended radio. It's already in the ROM ---
longntt105
chắc các bản ANdoid 4 ngốn pin hơn 2.3.x phải ko vậy ta?
- Cần up firmware và Radio phù hợp với ICS 4.0.3 trước khi up Rom.
hồi giờ em toàn up rom từ thẻ ko à. còn bây giờ cài firware và radio thì chọn ntn vậy ạ ?
LinhKu
xời đã sen 3.6 rồi,nhìn quả hình nền kết thế,up ngay khẩn cấp :O
LinhKu
bạn dow firware về rồi chép vào sdcard nhớ để ngoài nhé đừng cho vào thư mục,rồi vào bootloader nó sẽ tự up firware và radio cho bạn,chỉ cần ấn volume up là ok:p
longntt105
minh có backup bằng recovery cái rom 2.3.4 của mình. khi cần retores lại thôi chứ có up ngược firiware lại ko nhỉ ? tiện thể cho mình hỏi ở chế độ chờ ( tắt hết các kết nối,) máy các bạn nhiêu thụ bao nhiêu mA ? máy mình thì đến 190 mAh luôn. hix
BuuPhucCT
Xài các bản ROM Revolution HD nói chung là nhanh, mượt và ít lỗi nhưng bù lại là mức tiêu thụ pin thuộc vào hàng khủng khiếp. Khi ở chế độ chờ mức tiêu thụ thường trên 100 mah trong khi các bản ROM khác như InsertCoin thì mức tiêu thụ chỉ dao động trong khoảng từ 2 mah đến 20 mah chứ ít khi cao hơn. Để qua đêm trong khi thì ROM Revolution HD đốt từ 20-30% pin trong khi ROM InsertCoin nhiều khi không mất % nào.
Đã test thử 2 ROM và cuối cùng đành chọn InsertCoin dù nó kém mượt hơn ROM Revolution HD.
vinhhuynh1
Bản 6.1 xài ngon rồi. Mượt , nhẹ, tất cả các chức năng điều hoạt động tốt. Nhưng mình thích xài HD vì nó đẹp, ít pha chế , ít lỗi. Hao pin thì chịu rồi, cái gì ngon mà không mắt tiền đâu, xài 1 ngày là oki. Hôm nay 29 TẾT rồi mà k có rom ship 4. Năm nay ACE mình ăn TẾT = rom COOK rồi.
Chúc ACE diễn đàn NĂM MỚI NHIỀU SỨC KHÕE, THÀNH ĐẠT và HẠNH PHÚC.
lecuong_82
pac ơi cho em hỏi khi em flash Firmware package xong thì máy bị bootnoop ( cứ khởi động lại liên tục ở màn hình HTC , không boot vào home được vì vậy không xóa PG58IMG.zip, em phải bỏ thẻ nhớ ra > vào bootloader > vào Recovery, cắm thẻ vào > muont sdcard>rồi xoá ) chứ máy nó không boot vào home được
các pác flah bước này có bị thế không, cho em cách fix,
Mình đang dùng Rom Revolution HD 6.0.3 ICS 4.0.3 ko bít co soft nào để tắt máy,reset hoặc vào recovery nhanh ko các bạn.Lúc trc dùng reboot control wiget hay lắm nhưng nay ko hỗ trợ
ICS 4.0.3
LinhKu
mình cũng bị bước này đấy,đành phải làm thủ công phải tháo thẻ rồi vào recovery rồi lắp thẻ nhớ vào
bác nào thấy hao pin thì chuyển sang insertcoin nhé,rom này loại bỏ những ứng dụng không dùng,mình dùng cũng ko thấy hao pin lắm
longntt105
anh em ơi. help với ! mình có cài InsertCoin_ICS_RC1_4.4.0 với FW đi kèm nó. bây giờ mình muốn về lại 2.3.4 thì làm sao ? mình ko tài nao cài đc bất cứ bản nào cả ngoài bản 4.4.0 kia ( chắc lào k tương thích FW)
Vây xin giúp mình trở về FW cũng như bản 2.3.4 lại với.
ntt2006
Em phải up lại firmware của 3.12 hoặc thấp hơn rồi up lại rom 2.3.4
longntt105
hix. em chờ anh nãy giờ lun nè..tưởng tết này tiêu rồi....hix !
FW 3.12 ở đâu thế ? em ko tìm ra lun. trong trường hợp mình backup cái rom bây giờ lấy ra đập lại đc ko ạ ?ngồi từ sáng giờ lang thang 1 mớ trang xda...
lecuong_82
Đây chính là trình tự từ ICS 4.0 muốn về lại Gingerbread 2.3.x phải không pác ( Sensation XE cùng dùng luôn rom trong này ạ http://forum.xda-developers.com/show....php?t=1412618 )
- còn cái Superwipe tác dụng là để wipe cho sạch sẽ đúng không pac, em sử dụng nó đê wipe trong mọi loại rom cũng được đúng không pac ( đều có tác dụng như đang sử dụng Android_Revolution_HD-Sensation mà muốn up rom khác )
- Có pac nào sử dụng 4EXT Recovery Touch v1.0.0.3 RC 1 ( sử dụng Recovery bằng cảm ứng thì phải ) hướng dẫn các cài luôn, em vào XDA đọc không hiểu lắm
ntt2006
- Super Wipe dùng cho tất cả các Rom luôn em.
- 4Ext thì bạn down file apk về cài đặt bình thường thôi, sau đó chạy nó là ok.
Đang dùng Rom 6.0.3 xe nay mình muốn up lên 6.1.0 or 6.1.1 thí có cần phải super wipe ko nhỉ.Mà hình như FW bản 6.0x khác 6.1x thí phải
longntt105
mấy bản này có hao pin ko ? đang tìm 1 bản có dòng chờ thấp mà ko có lu..hix
hydayat
Hi all . Mình up lên đến HD 6.1.1 rồi , mọi thứ ok ngoại trừ lỗi shutdown lúc nào ko hay . Không biết do CPU hay Pin nữa ?
