Nó nằm dưới cái tên khác trong cái link bạn down về áh. Mình hồi đó có thử wa nhưng thấy cái Effect bạn nói chỉ đặc biệt ở chỗ con trỏ được highlight bằng ánh sáng jống năng lượng thôi nên k thèm chú ý lắm! Mấy cái Effect đẹp là Flux, Kilabot, Glide, SlideSpin, Fresh, Rotation, Trapezium, Mashup, Android & Ìninity.
Bạn tham kháo fần text này để mix nó lại v nhau hén!
***These are the kml;s to do with swiping the widgets to and from the homescreen, the only ones you
actually have to edit or use though are ActiveIdleViewSwitch and ActiveIdleViewSwitchRight
ActiveIdleViewSwitch_default
ActiveIdleViewSwitchRight_default
ActiveIdleViewSwitchShowHide_default
***IdleBackground_default - for particles on the homescreen, that fly behind the widgets
IdleItem_default - for particles on the homescreen, that fly infront of the widgets
***CallSwipeAnswer - self explanitory i think
***TouchDialerOpen_default - for opening the dialer
TouchDialerClose_default - for closing the dialer
***AppStart_default - starting an app from the homescreen,includes code for app loader
AppStartRect_default - starting an app from the menu, also includes code for app loader
AppStartSwitch_default - swapping to an open app from the task manager
AppStartSwitchRect_default - swapping to an open app from the menu
AppExit_default - exiting from an app
***AppActivate_default - for when you press the menu button
AppShellFolderOpen_default - opening a sub folder in the menu
AppShellFolderClose_default - closing a sub folder in the menu
AppShellExit_default - exiting the menu
AppShellActivate_default - honestly i have no idea haha
***ChangeView - for when changing from grid to list view in the menu
***GridAppShellBackground_default - this is for particles in the menu
GridAppShellItem_default - this is for the selection box in grid view on the menu, for bouncing icons and such
***ListAppShellBackground_default - for the gallery and music/video and tv apps, the first pages are actually
sub folders in the menu, this is the kml that holds the code for particles in these menus.
***ListAppShellItem_default - also for the gallery and music/video and tv apps
***ListCommonBackground_default - this is where the code for the particles in the selection box is in
contacts, task swapper, well almost everything really.
***ListCommonItem_default - also for the selection boxes
***OptionsmenuBackground_default - if you want particles in the selection boxes in options popups,
put the code in here
***OptionsmenuItem_default - if you want particles in the options popups put them in here
***these are rotation effects in the camera
you only need to edit or change LayoutSwitch_camera
LayoutSwitchStart_camera
LayoutSwitch_camera
LayoutSwitchExit_camera
***these are the main rotation effects, again you only need to edit or change LayoutSwitch_default,
the others are for when changing from the options menu
LayoutSwitchStart_default
LayoutSwitchExit_default
***CompTaskSwapper_default - for the task manager effect eg. fade in.
***these are all to do with the popups for anew message or to warn you etc
CompConfirmationNote_default
CompErrorNote_default
CompInformationNote_default
CompPopupDefault_default
CompQuery_default
CompSystemNotify_battery_default
CompWarningNote_default
CompWaitNote_default
CompSystemNotify_default
***these are the kmls to have different effects in the options menu, like fading in or flashing up
CompOptionsMenuMain_default
CompOptionsMenuCascade_default
***themeloader - for the fade effects when applying a new theme
themeloader2 - for the image when applying a new theme
***StartupExit_default - for start of homescreen and exit to white nokia screen ( i think)
***these are for the transition between photos in the photo app, they do nothing on the n97 but i believe they
work on the 5800xm
PreviousImage
NextImage
***Screensaver_default - i believe its for the screensaver haha since n97 has no screensaver i have no way of knowing
***these are for the little toolbar at the top of the homescreen
CompToolbar_default
CompTouchToolbar_default
***CompMediaBar_default - i think this is for the 5800 media bar
***and these im not too sure about these
CompContextMenu_default
CompNumberEntry_default
CompSequence_first_default
CompSequence_last_default
CompSequence_mid_default
