Đã có bản [BUILD][07.08.2010][FroyoStone Series - V1][Kernel: manusfreedom 2.6.32.9 #74]
Whats new:
- Two different builds based on the same Official FroYo 2.2 Update for HTC Desire. One build does not use HTC Sense (just has HTC Skin) apart from some applications. The other has complete HTC Sense.
- Both builds have the same functionality, just different interfaces. The speed of both builds are very fast, DO NOT BE BIASED!
- Camcorder is now working with HTC Camera, though 720p capture is still yet to be implemented. WVGA video capture works fine.
- Speed optimizations have been done to ensure a nice speed boost. Try out NeoCore and Quadrant after running Advanced Task Killer. The results should be similar to the Nexus One and HTC Desire.
- Flashlight app now works, the app is included in both builds. Light only works at brightest setting so far.
- Data.img has been increased to 512mb.
- Memory has been increased to 384mb.
- GPS is working.
- Bluetooth is working. (I have not tested HID devices or BT Headsets)
- All apps will now function and install correctly. If you have an issue installing an app from the Android Market or another source, then go through the following steps:
- Go to Settings > SD & phone storage > Unmount SD card
- Now install your app, it will now install correctly and function fine
- Go to Settings > SD & phone storage > Mount SD card
A proper solution will be worked on.
Known problems:
- 3G Data connection MAY BE slow or not working properly due to incomplete data driver in kernel
- Compass is inaccurate, this is known.
- Green LED blinks, THIS IS NOT AN ISSUE. This is a diagnostic feature to see if the phone has crashed or not.
- Keypad backlight does not function correctly (stays on all the time or stays off all the time). This is being worked on.
- all other things should work ok
Tham khảo tại
http://forum.xda-developers.com/showthread.php?t=747492
Tải tại
http://www.multiupload.com/OFQCVS1ZXR
