Carbide.ui S60 Theme Edition 3.1
NguyenDucDung
Đây là một chương trình tạo theme – miễn phí của Nokia cho tất cả các dòng máy S60 kể cả 3rd Edition
Phầm mểm này thực ra là free nhưng nó bắt bạn đăng kí sau khi dùng đc 14 ngày - lúc đó bạn hãy chọn Help => Register Now... làm từng bước và bạn đăng kí ở đây là hoàn toàn miễn phí, ko hiểu bọn này nó làm như thế này là có ý gì :D
Xem thêm thông tin - english
Carbide.ui S60 Theme Edition for Symbian OS is a tool that enables the creation of packages to customize the appearance of the user interface on S60 devices. These packages can then be used by any device user to alter the look and feel of their S60 device.
Carbide.ui has been designed with the creative professional in mind. It allows the S60 UI to be customized with full WYSIWYG layout, without the need for layout defi nition coding or specialized mobile design experience. In addition, Carbide.ui can be integrated with a wide range of creative graphic and audio packages, allowing designers to work with their favorite tools.
Carbide.ui S60 Theme Edition for Symbian OS creates S60 themes that alter the appearance of the S60 UI and S60 Music Player. Themes can be created, edited, and viewed easily. Full WYSIWYG features allow the appearance of wallpaper, application icons, color schemes, or any other UI component to be evaluated accurately. Once a theme has been created, the tool will package it into a Symbian OS installation fi le and prepare it for Open Mobile Alliance (OMA) Digital Rights Management (DRM) protection, if required, after which it will be ready for deployment to devices.
The latest version adds support for S60 3rd Edition Feature Pack 1 and its new theme capabilities, including new screensaver files support, enhanced ringtone file-support, Arabic and Hebrew UI support and new MIDP Color group. These new platform features provide developers and creative professionals with new opportunities to create innovative and compelling experiences for the end user.
Supported S60 Platform versions:
S60 2nd Ed
S60 2nd Ed FP1
S60 2nd Ed FP2
S60 2nd Ed FP3
S60 3rd Ed
S60 3rd Ed FP1
Download
http://www.forum.nokia.com/info/sw.nokia.com/id/bb173537-4e67-496f-9967-50917d5cfc47/S60_Theme_Studio_for_Symbian_OS.html
để download đc thì bạn phải là user ở đó, vì vậy mình đã đăng kí một cái nickname ở đó cho tất cả sài chung
Username: pdaviet
Password: 123456
Cách download như sau:
Sau khi vào đc cái link trên mình đưa, thì bạn hãy nhìn xuống phía dưới một chút bên tay phải, sẽ thấy có chữ DOWNLOAD bạn hãy click vào nó (chọn download method là “Standard browser download”) sau đó lúc này nó sẽ đòi hỏi username và pass, bây giờ bạn type thông tin trên kia vào là sẽ down đc thôi...
Mọi thông tin đã có hết ở trên trang web đó vì vậy mình cũng ko cần nói thêm gì nhiều, chỉ nói qua một chút về đòi của chương trình đối với PC
Microsoft Windows XP Professional SP2 or Microsoft Windows XP Home SP2
512 MB RAM (recommended 2 GB)
430 MB disk space
1.5 GHz or faster processor (recommended 2.8 GHz)
Display supporting 24-bit color at 1280x1024
nếu bạn có ý định làm cho dòng máy với OS 9.x thì nên tham khảo qua Release Note for Carbide.ui S60 Theme Edition 3.1 for Symbian OS và cả Installation Guide for Carbide.ui S60 Theme Edition 3.1 for Symbian OS
Mình cũng chưa down đc, thấy có vẻ rất hay khi nào có sẽ cho một vài hình minh hoạ nên
Vì vậy mong Mod. đừng del. nhé :D thanks
NguyenDucDung
Hình ảnh khi start
Đây là sau khi đã chọn create – như bạn thấy, phía bên tay phải bap gồm đa số các tool cần thiễt để chỉnh sửa theme cho phù hợp....
Nói thêm một chút về vấn đề̉ đăng kí software
Bạn chọn đăng kí OFFLINE nhé
Bạn hãy vào link NÀY sau đó dùng username và password mình ̣đã đưa trên để đăng nhập vào, tiếp đến bạn phải copy cái số dạng như ID của phần mềm, pase vào chỗ yêu cầu và bạn sẽ có SN, đã có SN rồi, bạn hãy quay về để đăng kí thôi....
Nếu máy bạn nào yếu thì đừng sài cái này nhé, nó quả là đòi hỏi rắt "ác" đấy :D
Edit: nếu có ai đã đăng kí bởi nick mình đã đưa ra trên thì có thể liên hệ mình để lấy số đăng kí nhé (nếu bạn quên) sau mỗi lần đăng kí thì mình lại nhận đc mail với số đăng kí không, cho nên... :D
nguyenphuocho
CARBIDE UI S60 THEME ED 3.1.1Series 60 Theme Studio Edition 3.1.1
CHƯƠNG TRÌNH TỰ LÀM THEMES CHO MOBILE S60 TRÊN PC.
CÁC BẠN CÓ THỂ TỰ DESIGN CHO MÌNH NHỮNG THEME ĐỘC KHÔNG ĐỤNG HÀNG CỦA RIÊNG MÌNH.
Phiên bản mới có thêm khả năng làm themes động cho dòng 3rd
ALL IN HERE
This image has been resized. Click this bar to view the full image. The original image is sized 1059x1368.
This image has been resized. Click this bar to view the full image. The original image is sized 1074x1201.
What's new in 3.1.1?
- 320x240 landscape resolution for E61/E62/E61i
- Square (208x208) resolution for Nokia 5500
- Export/Import support
- Search support
- Problem with bitmap icons in 2nd Edition Feature Pack 2 resolved
- Resolved problems in SVG to SVGT conversion (arc and named colors for some
vector graphic editors)
- Animated GIF can be used as screensaver.
- Arabic & Hebrew landscape indicators
- Java Wait Bar Increment and Idle graphics.
- Resolved problems with pasting bitmaps and mask handling.
- Sis package optimization for S60 3rd Edition Feature Pack 1 devices.
- Packaging of 3rd party icons for S60 3rd Edition and previous devices
- Defect when switching to Nine piece mode for highlights has been resolved
- Tab and Volume indicator skinning for s60 2nd Edition Feature Pack 3
- Popup preview color group
- Several new features, at beta level, are included:
a)Editing SVG colors
b)Component store for single element and group of elements
c)Multiple selection functionality
d)Reproducing animation in WYSIWYG editor
CẤU HÌNH HỆ THỐNG CÀI ĐẶT - CÁCH CÀI ĐẶT - CÁCH NÂNG CẤP LÊN VERSION 3.11 NẾU ĐÃ CÀI VERSION 3.1 - CÁCH ĐĂNG KÝ ĐỂ SỬ DỤNG BẢN FULL - CÁCH GỠ BỎ -
2 - Installation prerequisites :
To install Carbide.ui to your computer, you need the following hardware:
- Minimum:
• Microsoft Windows® XP Professional SP2 or Microsoft Windows® XP Home SP2
• 512 MB RAM
• 430 MB disc space
• 1.5 GHz or faster processor
• Display supporting 16-bit color at 1280x1024
- Recommended:
• 1 GB RAM
• 430 MB disc space
• 2.8 GHz or faster processor
• Display supporting 24-bit color at 1280x1024
• Sound card
3 - Installing Carbide.ui :
To install Carbide.ui:
- 1. Save the “Carbide_ui_Theme_3_1_1_Setup.exe” installation package to your computer.
- 2. Double-click “Carbide_ui_Theme_3_1_1_Setup.exe”.
- 3. If the version 3.1 is already installed, installation will follow update procedure.
- 4. In the Install Shield Wizard’s Introduction page, click Next Next.
- 5. In the Software Agreement page, after reading the license agreement, select the I accept the
terms of the agreement radio button and click Next Next.
- 6. In the Choose Installation Folder page, determine the folder to which you want to install
Carbide.ui and click Next Next.
- 7. In the Select Program Folder page, define the Programs folder (in the Microsoft Windows Start
menu) to which the Carbide.ui icons are added and click Next Next.
- 8. In the Ready for Installation page, click Install Install.
The wizard installs Carbide.ui to the computer.
---> Note: The installation may take a few minutes.
- 9. When the InstallShield Wizard window informs you that the installation is complete, click Finish Finish.
For more information about the product release, read the Release Notes.
After the installation, start Carbide.ui by clicking the tool icon in the Start menu’s Program folder or in
the Desktop.
3.1 - Updating already installed 3.1 version :
4. Installation detects that previous version is installed. It asks a question, first to remove existing
installation and to install new one. Press Yes to uninstall version 3.1 and update it to 3.1.1. Press
No to quit.
5. Installer will uninstall 3.1 packages. User data and workspace will not be removed. This step will
be done with no progress bar, should last 10 – 20 seconds.
6. Installer will present Introduction page and start 3.1.1 installation from beginning, like in
Installing Carbide.ui.
4 - Registration :
You can run Carbide.ui for a fixed period (14 days) before you need to register it with a serial number.
If you do not register Carbide.ui, you are not able to use it after the trial time elapses. Registration is
free. Just follow the directions in the registration wizard that appears when your trial period is over.
You can also register the tool before the trial time elapses by choosing
Help -> Register Now… > in the tool menu.
5 Uninstalling Carbide.ui
To uninstall Carbide.ui:
1. Double-click “Carbide_ui_Theme_31_Setup.exe”.
2. In the InstallShield Wizard window, select Remove and click Next Next.
3. In the confirmation window, click Yes Yes.
The wizard uninstalls Carbide.ui from the computer.
4. When the InstallShield Wizard window informs you that the uninstallation is complete, click
Finish Finish.
Carbide.ui S60 Theme Edition 3.2 for Symbian OS
For: Sym 6 S60/Sym 7 S60/Sym 8 S60
* S60 2nd Ed
* S60 2nd Ed FP1
* S60 2nd Ed FP2
* S60 2nd Ed FP3
* S60 3rd Ed
* S60 3rd Ed FP1
Compatible OS:
· Symbian 6 Series 60
· Symbian 6 Series 60 1.0
· Symbian 6 Series 60 1.2
· Symbian 7 Series 60 2.0
· Symbian 7 Series 60 2.1
· Symbian 8 Series 60 2.6
· Symbian 8 Series 60 2.8
· Symbian 9 Series 60 3.
SAU ĐÂY LÀ HƯỚNG DẪN LÀM CHÍNH XÁC VÀ HOÀN HẢO TỪ NOKIA FORUM
- CÁCH NÀY CỦA ADMIN NOKIA FORUM TẶNG VÀ HƯỚNG DẪN BẰNG FILE FLASH PLAYER - GIỐNG NHƯ VIDEO - CÁC BẠN CHỈ CẦN MỞ LÊN XEM VÀ LÀM THEO LÀ ĐƯỢC
KHUYẾN CÁO CÁC BẠN NÊN LÀM THEO CÁCH NÀY VÌ NÓ ĐƯỢC HƯỚNG DẪN RẤT CHI TIẾT VÀ ĐẦY ĐỦ CHÍNH THỨC TỪ NOKIA
Độ phân giải màn hình các máy Nokia S60 v3rd:
176x208 pixels: N91, N91-8GB, N3250, N3250 ME
208x208 pixels: độc chiêu N5500
240x320 pixels: N95, N95-8GB, N6290, N71, N73, N73 ME, N75, N76, N92, N93, N93i, N6110 navigator, N5700 Xpress Music, N6120 classic, N6121 classic, N81-MicroSD, N81-8GB, N95, N95-8GB, E50, E65, E90 (màn hình ngoài)
320x240 pixels: N77, E61, E61i, E62
352x416 pixels: N80, E60, E70
This image has been resized. Click this bar to view the full image. The original image is sized 1008x1001.
This image has been resized. Click this bar to view the full image. The original image is sized 700x548.
DOWNLOAD ALL VIDEO GUIDES HERE :
Getting started with Carbide.ui S60 Theme Edition
Editing themes with Carbide.ui S60 Theme Edition
Creating Screen Savers for S60 3rd Edition Feature Pack 1 Devices
softvnn.com
mrtien169
Cho mình hỏi là làm sao để đăng ký dc, cách trên mình làm ko dc ...
MinhThang
Phải nói cái pm này rất hay nhưng để làm đuợc cũng không đơn giản tí nào mình đã mò qua đau cả đầu hơn nửa tháng trời cuối cùng đành remove.anh em nào làm đuợc thì sharad nha.
Kojiro
:D Tối qua làm thử 1 cái đơn giản nè, chưa đẹp lắm nên chỉ giới thiệu hình thôi.
MinhThang
Làm hoàn chỉnh một cái úp lên anh em coi thử nha nhớ là đầy đủ menu icon tất tần tật luôn.
Kojiro
Đang tìm icon mà quên cái trang mất tiêu rồi, đang search! Tất nhiên là làm hoàn chỉnh sẽ khoe a e liền :p
Mai mình up cái hướng dẫn làm theme kèm hình ảnh, hướng dẫn bằng tiếng Anh cho các bạn tham khảo nha.
Kojiro
Như đã hứa, hôm nay mới up bài hướng dẫn làm theme kèm hình ảnh cho các bạn.
Tất cả đều là tiếng Anh nên anh em nào khá tiếng Anh tí thì ok.
Step1 Create new theme ,select basic graphic then click Preferences for select Programs that U want to edit Bitmap in step2
Kojiro
Step2 .I choose paint program [no.1] and I choose vector editor with Adobe illustrator v 10[no.2]
Kojiro
Step3 click gallery [no.1] and click no.2 for select the image U want to illustrate [more image more spend time to open the program]
Kojiro
Step 4. Started the image by drag & drop the Active background and Idle Background with correct size.and MUST be the same images[both]
