Step 6 Select color as shown in preview[some color will show in some application eg. Quickoffice,Y-browser].In the color mode , Do it from Navipane ,active and passive items with the same method
Step 7 In the main area item of the color mode there are some pitfall of carbide3.1.I found as shown NB. main area color is synchronized with Text message as shown
Step 10 Color for SoftKey text is very easy not illustrated Step 11 Color Primary items see as preview….note “column separate line” is the line of STANDBY mode at the Idle background
Step 22 List Highlight: we can edit the highlight by:
a]add the prepared images as shown[upper]
b]edit the default image changing only the color as shown[lower]
