~~~CFW C6/N97 for 5530-5800-523x-X6: phiên bản "trâu" cày~~~
TwinStephy
JAF version 1.98.62
Detected PKEY: 90007BF6
Card life counter: 99.99%
USB Cable Driver version: 7.1.78.0
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Detected P-KEY: 90007BF6
Init usb communication...
Phone Type:
MCU Flash file: C:\Users\ALIENWARE\Desktop\RM-588 V51.6.002 New Core by Binh24\RM-588\RM-588_51.6.002_prd.core.C00.c0r
Phone Type:
PPM Flash file: C:\Users\ALIENWARE\Desktop\RM-588 V51.6.002 New Core by Binh24\RM-588\X6.V20
PRESS POWER ON NOW!
Searching for phone...Found
Sending RAW loader...
Using …X012.005
Elf2flash 09.11.000
CMT RAW loader...
Patching RAW boot step1...
Patching RAW boot step2...
Patching RAW boot step3...
Sending RAW Loader...
....................Loader Sent!
Stage 2 starting............PUBKEYS already sent...
........Phone prepared OK!
Waiting for the phone to boot...
Status byte: 8000
Selecting CMT flash...
Result: 0000
Phone is in flash mode...
CMT blocks: 614, APE blocks: 0
Erasing cmt...
Processing C:\Users\ALIENWARE\Desktop\RM-588 V51.6.002 New Core by Binh24\RM-588\RM-588_51.6.002_prd.core.C00.c0r...
Erasing cmt zone 00040000 - 00082FFF ... Erase result: 0000
Erasing cmt zone 00083400 - 003FFFFF ... Erase result: 0000
Erasing cmt zone 00400000 - 007FFFFF ... Erase result: 0000
Erasing cmt zone 00800000 - 00D5FFFF ... Erase result: 0000
Erasing cmt zone 00D60000 - 09E5FFFF ... Erase result: 0000
Partition result: 0014
Processing C:\Users\ALIENWARE\Desktop\RM-588 V51.6.002 New Core by Binh24\RM-588\X6.V20...
Erasing cmt zone 02EC0000 - 0B61FFFF ... Erase result: 0000
Send CMT CFG...
Writing cmt...
Sending CMT HASH for ADA
Sending CMT HASH for KEYS
Sending CMT HASH for PRIMAPP
Sending CMT HASH for RAP3NAND
Sending CMT HASH for PASUBTOC
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending...
cmt->PAPUB keys already sent...
Sending CMT HASH for SOS*UPDAPP
Sending CMT HASH for SOS*ENO
Sending CMT HASH for SOS*DSP0
Sending CMT HASH for SOS*ISASW
Sending CMT HASH for SOS+CORE
Sending CMT HASH for SOS+ROFS1
Sending CMT HASH for SOS+ROFS2
Write result 27: 1701
Rebooting...
Finishing CMT session...
Restarting CMT...
Pooling phone...
Phone not found...
Second try...
MCUSW: (null)
APESW: (null)
VariantSW: (null)
Prodcode:
Setting test mode...
Failed! Aborting!
Done!
tôi dùng x6, nó hiện lên dc màn hình chào nokia rồi sọc sọc tắt màn hình luôn. helpppp!!!
leejiah
JAF version 1.98.66 beta5
Detected PKEY: 9000B430
MCU Flash file: E:\Mod s60v5\RM-504_40.0.003_prd.core.C00
PPM Flash file: E:\Mod s60v5\RM-504_40.0.003_prd.rofs2.V05
Detected P-KEY: 9000B430
PRESS POWER ON NOW!
Using 009.012.005
Elf2flash 09.11.000
CMT RAW loader...
Stage 2 starting..........PUBKEYS already sent...
Status byte: 8000
Result: 0000
CMT blocks: 629, APE blocks: 0
Erasing cmt...
Processing E:\Mod s60v5\RM-504_40.0.003_prd.core.C00...
Processing E:\Mod s60v5\RM-504_40.0.003_prd.rofs2.V05...
Erasing cmt zone 02961400 - 09E5FFFF ... Erase result: 0000
Send CMT CFG...
Writing cmt...
Rebooting...
Restarting CMT...
Pooling phone...
MCUSW: (null)
APESW: (null)
VariantSW: (null)
Prodcode:
Failed! Aborting!
Done!
Các bác giúp em vs em 5530 cài RM-504_40.0.003_prd.core.C00 và RM-504_40.0.003_prd.rofs2.V05
Radium
radium ơi cho minh hỏi:cài pc suite để làm gì và tải ở đâu??mong ban chỉ mình với,mình xài 5800 fw 60.0.003 flash:core với rofs trên được không???
PC suite cài vào để máy tính nhận driver của điện thoại nha bạn. bạn lên trang chủ của nokia có đó
yeudesong87
X6 lâu lâu mất sóng và báo ko nhận sim, đòi restart!!!
Tháo ra nghịch giờ lắp vào đút trong túi quần lâu lâu thấy mất sóng rồi báo sim ko nhận đòi restart máy!!! Mình ko biết là nó bị chạm ở đâu! Vì có 4 cáp mình lắp khá chuẩn rồi ai biết chỉ dùm với hjx:mad:)
wanbeytuananh
PRESS POWER ON NOW!
Using 009.012.005
Elf2flash 09.11.000
CMT RAW loader...
Status byte: 8000
Result: 0000
Erasing cmt...
Send CMT CFG...
Writing cmt...
Rebooting...
Restarting CMT...
Pooling phone...
MCUSW: (null)
APESW: (null)
VariantSW: (null)
Prodcode:
Failed! Aborting!
Done!
thế này là thành công rồi mà :))
wanbeytuananh
bản này k tích hợp sẵn belle top bar nhỉ, cho e hỏi mod nó luôn vào rofs2 thì phải àm thế nào
iamstven
ganang cho hỏi t bỏ mod belle và thay file ngôn ngữ bằng file khác được như thế này
nhưng menu vs danh bạ nó vẫn là ký tự belle b giúp mình được không?
leejiah
:| Thưa pro, em đi làm đi làm lại vài lần CFW đều vậy, tra trên google các pro bảo tháo pin rs máy,cũng có nhiều bác bị như em. rs máy rồi chỉ vào dc man hính ko len menu đc.
Em đành cài lại fw ban đầu cho 5530, cài xong cũng hiện lỗi như trên nhưng tháo pin bật lại là ok.
==> kết:
-CFW hiện lỗi => ko xài đc phải cài lại fw ban đầu thôi ( hoặc bác nào bít tại sao chỉ em vs).
-cài lại FW ban đầu mà bị lỗi tháo pin ra ok.
Cuối cùng sau 1 time nghiên cứu máy vần hoàn máy:(:)(:)(:)((
Radium
==> kết:
sao lỗi được bạn. Bạn flash đầy đủ các file xem sao.
cái tên thì nằm trong file ngôn ngữ của soft thì phải
phamanhrin
==> kết:
cái này đơn giản thôi bạn./bạn lên tải bàn full về cài lại fw gốc rùi sau đó jaf lại là thành công
phamanhrin
bạn radium sài pin lâu k ban.máy mình nt 1 buôi tôi là hết pin.bt thì 1 ngày là hêt pin/
iamstven
file ngôn ngữ của menu vs danh bạ nằm ở đâu vậy?mình thay mãi không được chữ như bình thường @ganang1234 :((
