Hướng Dẫn, Giải Đáp Thắc Mắc Về FW và CFW.
ThanhTungHT
JAF version 1.98.66 beta5
Detected PKEY: 9000AAC9
USB Cable Driver version: 7.1.48.0
Changing mode...Done!
FILES SET FOR FLASHING:
MCU Flash file: NONE
PPM Flash file: NONE
CNT Flash file: NONE
APE Variant file: NONE
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-588\
Checking path: \Products\RM-588\
Scanning ini files...
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-588\RM-588_51.0.002_prd.core.C00
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-588\RM-588_51.0.002_prd.rofs2.V20
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-588\RM-588_51.0.002_C02_prd.rofs3.fpsx
APE Variant file: C:\Program Files\Nokia\Phoenix\Products\RM-588\RM-588_51.0.002_000_001_U001.uda.fpsx
Languages in ppm: English,Vietnamese,Tagalog,Chinese Simpl,Chinese Trad
Detected P-KEY: 9000AAC9
Init usb communication...
PRESS POWER ON NOW!
Searching for phone...Found
Sending RAW loader...
Using 009.012.005
    Elf2flash 09.11.000
    CMT RAW loader...
Patching RAW boot step1...
Patching RAW boot step2...
Patching RAW boot step3...
Sending RAW Loader...
....................Loader Sent!
Stage 2 starting............PUBKEYS already sent...
........Phone prepared OK!
Waiting for the phone to boot...
Status byte: 8000
Selecting CMT flash...
Result: 0000
Phone is in flash mode...
CMT blocks: 1010, APE blocks: 0
Erasing cmt...
Processing C:\Program Files\Nokia\Phoenix\Products\RM-588\RM-588_51.0.002_prd.core.C00...
Erasing cmt zone 00040000 - 00082FFF ... Erase result: 0000
Erasing cmt zone 00083400 - 003FFFFF ... Erase result: 0000
Erasing cmt zone 00400000 - 007FFFFF ... Erase result: 0000
Erasing cmt zone 00800000 - 00D5FFFF ... Erase result: 0000
Erasing cmt zone 00D60000 - 09E5FFFF ... Erase result: 0000
Partition result: 0014
Processing C:\Program Files\Nokia\Phoenix\Products\RM-588\RM-588_51.0.002_prd.rofs2.V20...
Erasing cmt zone 02EA0000 - 09D5FFFF ... Erase result: 0000
Processing C:\Program Files\Nokia\Phoenix\Products\RM-588\RM-588_51.0.002_C02_prd.rofs3.fpsx...
Erasing cmt zone 09160000 - 09E5FFFF ... Erase result: 0000
Processing C:\Program Files\Nokia\Phoenix\Products\RM-588\RM-588_51.0.002_000_001_U001.uda.fpsx...
Erasing cmt zone 09E60000 - 0F47FFFF ... Erase result: 0000
Send CMT CFG...
Writing cmt...
Sending CMT HASH for ADA
Sending CMT HASH for KEYS
Sending CMT HASH for PRIMAPP
Sending CMT HASH for RAP3NAND
Sending CMT HASH for PASUBTOC
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected
cmt->PAPUB_CERTIFICATE_DATA_BB5 block detected, sending...
cmt->PAPUB keys already sent...
Sending CMT HASH for SOS*UPDAPP
Sending CMT HASH for SOS*ENO
Sending CMT HASH for SOS*DSP0
Sending CMT HASH for SOS*ISASW
Sending CMT HASH for SOS+CORE
Sending CMT HASH for SOS+ROFS1
Sending CMT HASH for SOS+ROFS2
Write result 27: 1701
Sending CMT HASH for SOS+ROFS3
Rebooting...
Finishing CMT session...
Restarting CMT...
Pooling phone...
MCUSW: (null)
APESW: (null)
VariantSW: (null)
Prodcode:
Setting test mode...
Failed! Aborting!
Done!
đó :(
Ok.Bây giờ Tháo Pin ra rồi lắp lại máy.Dí nút nguồn xem có lên không nhé :))
ThanhTungHT
thì không lên :( dead rồi à
đây là Ver mới nhất cho 5230 rồi còn gì,dead sao đc :))
Ko biết bạn đã đổi tên Rofs2 thành thế này chưa?
Khi flash nhớ tích vào 4 ô : Manual Flash , Dead Usb , Factory Set , Normal Model.
Bỏ tích ở CRT 308.
ThanhTungHT
vẫn bị
Phone failed to boot in flash mode CMT...
bạn à
Tháo Pin rồi lắp lại và Flash thao tác lại đúng chuẩn xem? :-?
Lúc nhấp nguồn thì nhấp nhấp 3 cái rồi dừng lên. Tớ chỉ nhấp đúng 1 "phát " là đc mà :))
m4l4ng
LOG mới đến test mode đứng
PRESS POWER ON NOW!
Searching for phone...Not found!!!
PRESS POWER ON NOW!
PRESS POWER ON NOW!
PRESS POWER ON NOW!
PRESS POWER ON NOW!
Using 009.012.005
    Elf2flash 09.11.000
    CMT RAW loader...
PRESS POWER ON NOW!
Using 009.012.005
    Elf2flash 09.11.000
    CMT RAW loader...
Status byte: 8000
Result: 0000
CMT blocks: 1004, APE blocks: 0
Erasing cmt...
Send CMT CFG...
Writing cmt...
Rebooting...
Restarting CMT...
Pooling phone...
MCUSW: V ICPR72_11w16.1
28-07-11
RM-588
(c) Nokia
APESW: V 51.0.002
VariantSW: V 51.0.002
Prodcode: 0589730
Setting FULL FACTORY...
Done!
hedwig1993
cách mapping ký tự trong font nhanh ??? help
tình hình là đang fix lại font pure để dùng với CFW vietnamese-04+ mod belle của nhockfc
mình dùng font pure 10mb có full kí tự rồi nhưng chưa mapping nên vào các trang ký tự đặc biệt thì koo hiện
cho mình hỏi làm thế nào để chuyển các kí tự đặc biệt từ font theo rom sang font mình tự làm mà mapping nhanh dc ko, mình dùn fontcreator 5.6
thank mod chuyển dùm bài !!
các cao thủ chỉ bảo với !!
m4l4ng
đc rồi nhưng = phoenix
nhưng sao xài firmware của bạn thanhtung không đc nhỉ nó báo lỗi
CRC Checksum....
thanhluan_phuyen
Cho mình hỏi là bản fw gốc của C6-00 khi mình edit rofs2, mình xóa một số ứng dụng như office, adobe, ovimap...... thì khi đóng gói và jà thì nó vẫn còn những icon đó mà kích vào thì không hoạt động được, mình nghĩ là do trong core nó vẫn còn sót những phần mềm này, vậy cho mình hỏi là mình có thể bung core ra để xóa trong core có được không? và trong core thì được và không được edit những gì vậy?
Luu_Tan_Vu
bạn cứ edit core thoải mái chả cần sợ gì, vì core k thể bung ra. Cái bạn bung ra là rofs nhưng được gộp với core. Core là quy định cấu hình phân vùng ổ đĩa cũg như nhiều thứ khác và cái này k bung ra được. Tất cả cáccfw đều là những bản edit lại chứ k ai đủ khả năng tạo fw mới trừ nokia. Việc core cfw chỉ có vài chục mb thì đó mới là core thật sự, còn rofs được phân vùng lại để dễ cook vì k có rofs của binh24 cũng xài cfw được. Bình chỉ phân vùng dữ liệu chứ k phải ngừơi tạo ra core và rofs.
thanhluan_phuyen
Mình thấy có mấy bản hướng dẫn edit core mà bạn, nếu chỉ edit rofs2 thì sẽ bị hiện tượng như mình nói đó, nó sẽ không mất icon dược,tuy vẫn hiện nhưng không dùng được
