iPhoneToday_Giao diện Iphone giống nhất!
AnhPheCT
iPhoneToday 1.5.1 cập nhật!
[B]iPhoneToday v1.5.1 (Apr 3, 2010)[/B]
[LIST=1]
[*]Using registry notifications instead of polling for  updating notifications (bubbles, date, time, etc.). Notifications (and  reloadIcon) should now appear immediately. Battery foot print should  also be smaller.
[*]Icon, text, circles, offset sizes, etc. are scaled automatically if  the application is launched in a different resolution than the one in  settings.xml (LastConfiguredAt).
[*]Bubbles are alpha blended.
[*]Position, size, text, etc. of bubbles are configurable.
[*]Added background image support for static bars (bottom bar and top  bar). Gradient background can now be used even when a wallpaper is set.  The background (gradient or image) of static bars can be alpha blended  to the wallpaper.
[*]ShrinkToFit option of static bars now shrinks the text height in  addition to the icon width.
[*]Added font settings dialog.
[*]Renamed "GPRS State" icon to "Cell Network State".
[*]Added "Missed Calls & Signal Strength & Operator Name" icon.
[*]Added "Unplayed Voice Mails" icon.
[*]Added "Irda State" icon.
[*]Added "Phone Profile" icon.
[*]No sound or vibration on launch if current profile is silent.
[*]When battery is charging a dot is shown before the battery  percentage to indicate charging.
[*]If operator name is empty show NA for signal.
[*]Changed the field "type" in the icon settings dialog from dropdown  to droplist.
[*]Fonts in the fonts subdirectory are automatically added/removed.
[*]Load strExec and strParameters (in addition to nScreen, nIcon,  strName, and strImage) from HKLM\Software\iPhoneToday\Icon...\ when  HKLM\Software\iPhoneToday\reloadIcon is set.
[*]Added a separate text quality option for text inside icons.
[*]Added new pressed icons.
[*]Added minimize OnLaunchIcon option (you have to manually edit  settings.xml).
[*]Added UpdateWhenInactive option (you have to manually edit  settings.xml) to always update notifications even when window is  inactive. The default value is 0 to save battery.
[/LIST]
AnhPheCT
iPhoneToday v1.5.2 Cập nhật!
[B]iPhoneToday v1.5.2 (Apr 15, 2010)[/B]
[LIST=1]
[*]Improved scrolling performance. It should be really fast  when there is no wallpaper or there is a gradient or image background  for the mainscreen pages. Under these conditions you could even enable  alpha blend on background without any performance loss.
[*]Improved animation performance.
[*]Added new animation effects. The available ones are: "None", "Expand  rectangle from center", "Zoom out from center", "Zoom in to center",  "Expand rectangle from clicked area", "Zoom out from clicked area", and  "Zoom in to clicked area".
[*]Added "animation" tab in options where you can select the animation  effect, the animation duration, and whether to launch the application  before the animation.
[*]The "out of screen" tab got more options. You can now configure to  stop scrolling when there are no more icons in a given direction.
[*]Added an option to tile the background images.
[*]Included a couple of tileable textures.
[*]Included an iPhone background for the BottomBar.
[*]Included some nicer looking bubbles.
[*]When adding a new icon, it is now by default inserted at the end of  the list not at the beginning.
[*]Whenever edit boxes receive the keyboard focus all the text in them  is selected and the keyboard is shown.
[*]For PNDs added a "KB" button next to the "OK" and "X" buttons.
[*]icons.xml and settings.xml are now always saved with DOS new lines.
[*]Center button of D-pad jumps to first page.
[*]Added --goto:right and --goto:left (similar to the --goto:next and  --goto:previous).
[*]Added a "Cradle State" icon.
[*]Fixed non updating "Calendar & Appointments", "Unplayed Voice  Mails" and "Irda State" icons.
[*]Fixed exec alt of "Missed Calls & Signal Strength & Operator  Name" icon.
[*]Fixed an issue when text's color is black.
[*]Other minor fixes and improvements...
[/LIST]
quangthanh1508
Thử qua cũng hay quá chừng, hơi lạ mắt. Nhưng HD2 mà cái today IP chắc là hơi mất đẳng cấp nhỉ. Yêu HTC.
duyphat17
Cảm ơn tất cả các Pro! Mình cài vào SSi900 của mình tuyệt lắm, mình biết thêm photoshop nửa thì tùy chỉnh icon theo ý mình nữa, rất tuyệt! Các bác lưu ý nếu dùng icon độ phân giải càng cao (256*256) thì hình hiễn thị sẽ đẹp hơn nhiều lắm!
xuandung11a2
Vẫn chưa hết lỗi đen màn hình khi chọn 1 số icon,đành phải tắt chức năng rung đi vậy.Ngoài ra các icon vẫn chưa tối ưu độ mịn,dễ vỡ hình ,răng cưa hoặc nhuốm khoảng đen.
0935539195
IPHONE TODAY 1.5.3 - Giao diện Iphone today bản update cực kỳ pro
Giao diện Iphone Today phiên bản mới 1.5.3 ra ngày 26/6/2010 dành cho Windows mobile.
Các bạn cài vào Device nhé.
Video bản 1.5.2
[video=youtube;gIeS4fMfCwg]http://www.youtube.com/watch?v=gIeS4fMfCwg&feature=player_embedded#![/video]
Tải tại đây: http://iphonetoday.googlecode.com/files/iPhoneToday-1.5.3-wm.cab
Và cuối cùng đừng quên thank nhé các bạn
letuan2007
Khi cài xong nếu bạn muốn hiển thị trên Today thì vào sitting/personal/today/chọn iphonetoday.
Nếu bạn muốn chạy chương trình thì vào program/iphonetoday. Thì lúc này máy của bạn sẽ trở thành iphone.
Em đã cài xong, nhưng iphonetoday không thể hiện ở đây, chỉ có trong program thôi,
namlh
Bác cho xin giao diện trên với được không ? Đẹp quá. Thanks
Bao giờ IP có cái skin na ná thế này thì bác so sánh luôn nhé.:D
Hoặc cố gắng đạt đến như thế này :))
Bó tay bác này!Đem so sánh 1 CÁ NHÂN với cả 1 TẬP ĐOÀN.
kuteo860
em thuộc loại gà. cho em hỏi em muốn sài mà máy em cần cài đặc gì thêm không ? nếu có thì anh nào chỉ rỏ dùm em với
