[ROM][ICS] |Feb 20| Energy™ -.¸¸.·´¯ Sense 3.6 ROMs Themed ¯´·.¸¸. -
ntt2006
[ROM][ICS] | March 7| Energy™ -.¸¸.·´¯ Sense 3.6 ROMs Themed ¯´·.¸¸. -
ROM Features
  • Rosie 5x5 Layout and half transparency
  • Transparent and extended quick settings
  • Blue highlights instead of green
  • Deodexed, zipaligned, tweaked
  • Improved SD card read ahead
  • Busybox + runparts, TitaniumBackup
  • A few HTC Apps removed, like HTC Navigation
  • A lot of other bloat removed
  • Stock HTC Kernel
  • Screenshot by pressing Power and Home
  • Advanced Power Menu
  • Updated hosts file for ad removal
  • Fast... Stable.. and GREAT battery life !
  • Based on the latest OTA 3.32 release !
  • Tweaks!
Screenshots
Changelog
March 7th, 2012 (ICS)
FIRMWARE 3.32
  • Updated to 3.32 base (final)
  • Updated ROM graphics
  • Included Tweaks !
  • Beats included.
  • New volume sounds
  • New stuff all around.. check it out.
  • APM mod included.
March 6th, 2012 (ICS)
FIRMWARE 3.32
  • Included Tweaks !
  • Beats included.
  • New volume sounds
February 29th, 2012 (2.29.2012)(ICS)
FIRMWARE 3.30
  • Updated to 3.30 base (release candidate.. more stable)
  • Included Tweaks !
  • Autobrightness fixed.
  • Flash the 3.30 firmware for it
February 20th, 2012 (2.20.2012)(ICS) FIRMWARE 3.24
  • [*=center]Major stability update please upgrade
    [*=center]Fixed su issues with "nobody" asking for permissions
    [*=center]Sense FCs should be gone
    [*=center]Corrected an "out of memory" issue with bitmap rendering in htc resources
    [*=center]Made some graphics in the keyboard that were green... blue
    [*=center]Dialer graphics changes (thanks to vin for the graphics!)
    [*=center]Increased speaker volume a bit more
    [*=center]GoogleTTS replaced for less distortion in google nav (thanks to dfwcomputer)
    [*=center]Adjusted dalvik vm heapsize
    [*=center]build props cleanups
    [*=center]Added mudhi's modified music app for more effect options (beats, eq, srs, dolby)
    [*=center]Fixed sense battery widget, now text is black on white, also blue graphics...
    [*=center]Lots of framework graphics changes again
    [*=center]Sense 4.0 ringtones/alarms/notifications from the HTC Endevour
YÊU CẦU CÀI ĐẶT FIRMWARE PHÙ HỢP TRƯỚC KHI CÀI ĐẶT ROM
FIRMWARE 3.32
March 6th, 2012
(ICS)
FIRMWARE 3.32
February 29th, 2012
(2.29.2012)(ICS)
FIRMWARE 3.30
MD5 for 2/29 ROM > BE6DF4B8B18750F9D1475B2C0D51FAD4
February 20th, 2012
(2.20.2012)(ICS)
FIRMWARE 3.24
fantasies
sạc full ... dùng từ 6h sáng đến giờ còn 84% pin .... nghe gọi 6 cuộc ... wifi lướt 15p .... dùng 3G khoảng 20p .... và up app linh tinh ...
cảm nhận pin rất ok
giao diện đẹp
có thêm 1 số ứng dụng
rom không đơn điệu như những rom khác...
nói chung ok...
chưa thấy lỗi gì...
cảm thấy hài lòng khi đã up qua những rom khác .
Good.........................................................................
longntt105
cảm nhận pin rất ok
giao diện đẹp
nói chung ok...
chưa thấy lỗi gì...
chụp lại cái rề viu pin là bik liền à :d
ntt2006
cảm nhận pin rất ok
giao diện đẹp
nói chung ok...
chưa thấy lỗi gì...
Bạn test nhanh thế, sáng giờ bạn test nhiều bản quá. Mình chỉ mới test thôi, Rom OK.
LinhKu
box sensation có vẻ ngày càng nhộn nhịp :D hum nay lỡ up bản Elegania rùi nên ngại up lại quá :D
longntt105
cảm nhận pin rất ok
giao diện đẹp
nói chung ok...
chưa thấy lỗi gì...
ui. màng hình boot đẹp thật. nhìn mê lun. cài rom thì nhanh cực lun.đang test .
Increased speaker volume a bit more ==> call nghe to thật :D
ntt2006
Đúng vậy, điểm đầu tiên anh chấm bản Rom này là hiệu ứng boot quá đẹp làm mê mẫn luôn, Rom anh xài từ tối qua, vọc khá nhiều, lướt web, youtube, để đến sáng thì còn 47%.
tun82
bản này chỉ dow về rùi cài thôi đúng ko các bác ?
Ko cần up FW àh ?
longntt105
má ơi. nãy h em mới test nè. mở máy , kt ti tí từ đã đc tầm 1 h rồi mà em nó xuống chậm , em test với pin ko đầy nhé. :D nếu đc thì sài bản này lun
fantasies
sạc từ 6h sáng qua .... dùng đến giờ vẫn còn 51%.........
rom này ổn định về pin như vậy la ok lắm rồi....
nghe gọi wifi...3g .... tầm 40p..... nghe gọi gần chục cuộc khoảng 10p alo.... noi chung là rom này rất ok đấy :p
huybinh_dnpt
Rom này mình dùng sao không vào tickcheck vào ô Unknown sources trong phần Setting -> Applications -> check vào ô Unknown sources (cho phép cài đặt các ứng dụng không trong Market)
fantasies
mấy cái addon đi kèm có cần up hok bro ? thấy tác giả có đính kèm mấy cái addon
ferick
mình ko dùng đc trình duyệt boat brower và viber trên bản rom này, ko biết có phải do fw ko. mình đang sài fw 3.25
LinhKu
Ứng dụng viber chưa dùng được cho android 4.0 đâu bạn ơi,chịu khó quay về 2.3.x nhé ^^!
