Root cho Incredible S và Droid Incredible 2 - Đã TEST thành công
trinhha
Bước 1
* download AlphaRevX ở đây
http://alpharev.nl/x/beta/ và nhớ lấy key trên trang web
sau đó trên HTC
1. Settings->Power->Uncheck Fastboot
2. Run latest version of HTC Sync on your PC and connect phone in HTC Sync mode and sync all your files.Remove HTC Sync and not the drivers .. (có thể bỏ qua bước này)
3. Reboot phone.
4. Settings->Applications->Development->Check USB Debugging
5. Run AlphaRevX and connect phone to PC in Charge Only mode
6. AlphaRevX should recognise your phone and show your Device Serial number, typically it should be something like HTXXETDXXXXX
7. Now type this out in the AlphaRevX page, the Key Generator appears only after you click the 'Download for Windows' link
8. Type out the key in the AlphaRevX software, keeping in mind the upper and lower case letters and press enter
9. AlphaRevX should start doing its thing and I got S-OFF at my first attempt in under 90 seconds
10. If it takes longer, just wait for the 15 minutes mark, if nothing, then reboot phone and retry. Some members got S-OFF after multiple tries
Bước 2 sau khi đã có S-
To install Clockworkmod after AlpharevX
1. Get fastboot and adb tool for windows here: http://forum.xda-developers.com/attachment.php?attachmentid=630611&stc=1&d=1308537076
2. Obtain clockworkmod recovery:
* HTC Incredible S (VIVO) recovery here: http://forum.xda-developers.com/attachment.php?attachmentid=623722&d=1307942287
* HTC Incredible 2 (VIVOW) recovery here: http://forum.xda-developers.com/attachment.php?attachmentid=631606&stc=1&d=1308628834
3. Remove recovery.img from the archive and put it with fastboot.
4.fastboot flash recovery <recovery.img> (from a command line - use root for Linux)
Bước 3 Root
To root:
1. Copy su-2.3.6.1-ef-signed.zip to your sdcard root http://api.viglink.com/api/click?format=go&drKey=1359&loc=http%3A%2F%2Fforum.xda-developers.com%2Fshowthread.php%3Fp%3D14693680&v=1&libid=1308657002363&out=http%3A%2F%2Fbit.ly%2Fsu2361ef&ref=http%3A%2F%2Fforum.xda-developers.com%2Fshowthread.php%3Ft%3D1130346&title=%5BInfo%5D%20After%20AlpharevX%3A%20install%20Clockworkmod%2C%20root%20%26%20more%20-%20xda-developers&txt=su-2.3.6.1-ef-signed.zip
2. Start clockworkmod recovery (instructions below)
3. Select "install zip from sdcard"
4. Then select "Choose zip from sdcard"
5. Then select "su-2.3.6.1-ef-signed.zip"
6. Then select "Yes - install su-2.3.6.1-ef-signed.zip" to confirm
7. Then go back
8. Then reboot.
9. You're rooted!
trinhha
bài viết hơi dài mình sẽ sửa lại sau cho dễ hiểu. vội quá up chiếm chỗ đã. hehe chúc anh em thành công nhé! đang đi công tác nên hơi bận!
quyeno2
bạn có thể huớng dẫn cụ thể hơn được không, bước 1 thì mình làm được rồi chỉ có bước 2 để install Clockworkmod là mình chưa làm được ah
quyeno2
Bạn click vào chữ Download rồi nó sẽ hiện ra cái bảng, sau đó bạn nhập serial key và chọn loại máy, hệ điều hành của PC, Hboot version, sau đó click vào Generate key là được mà
seeo2
Bác nên coi lại vì ,em thử htc incredible 2 , nó báo not support ( mà lúc chọn Hboot cũng ko có cái Hboot incredible 2 (0.97 hay 0.99 gì đó))
Hình như chỉ hỗ trợ con incredible S thôi
haianhhp
e tìm bên xda chi thấy hỗ trợ mấy dòng này thôi
HTC Desire Recovery
HTC Desire CDMA recovery
HTC Liberty Recovery
HTC Wildfire Recovery
em vẫn chưa làm được bước thứ 2
haianhhp
đã làm được bước thứ 2
bước 2:
1. down hết mấy cái như bác trinhha đã đưa ra
2. copy tool vào ổ C
3. giải nén recovery của Incredible S rồi coy recovery.img vào thư mục chứa tool vừa copy vào ổ C
4. mở cửa sổ lệnh: nhấn tổ hợp phím r+biểu tượng window
5.gõ lệnh cmd
6. gõ lệnh cd\ để thoát ra ngoài ổ C
7.gõ lệnh cd C:\tên thư mục chứa tool đã copy vào ổ C
8.gõ lệnh fastboot flash recovery recovery.img: cửa sổ sẽ hiện waiting for device
9.tắt máy đt, rút usb,
10. giữ tổ hợp phím volumne down + power
11. vào fastboot bằng cách nhấn nút power
12.đợi máy vào rồi nhận thẻ nhớ
13. làm lại fastboot 1 lần nữa rồi cắm usb vào sẽ thấy cửa sổ lệnh windown báo thành công
14. tắt máy vào lại hboot để vào mục recovery để root máy
các bác biết tiếng anh xem thêm tại
http://forum.xda-developers.com/showthread.php?p=14693680
em vừa root máy xong đang nghịch ngợm
quyeno2
Heheheh đã có cách để thực hiện bước 2 vô cùng đơn giản là các bạn vô đây http://forum.xda-developers.com/showthread.php?t=1122694 down clockworkmod recovery của dòng máy mình về rồi đổi tên file zip thành PG32IMG.zip,sau đó copy vào thẻ nhớ cuối cùng các bạn Hboot lại máy, khi vào chế độ boot thì máy sẽ tự update file PG32IMG, cuối cùng restart lại máy các bạn vào thẻ nhớ và xóa file PG32IMG đi là hoàn tất quá trình cài đặt clockworkmod recovery. Từ bây giờ các bạn có thể tùy ý cài các bản Rom ưa thích trên IS của mình rồi
Phoenix
Bác nào làm một bài hướng dẫn cụ thể xem nào, làm mãi mà không được...
Phoenix
Bực thật, làm mãi S-OFF mà không được, chạy alpharev nó cứ acquiring root mãi mà không thành công...
Son_Do
Bạn khởi động lại máy và khi đang ở màn hình khởi động HTC thì thực hiện S-OFF. Chúc bạn thành công.
Phoenix
Mình vẫn không thể S-Off được, hay là do mình đã up lên 2.3.3 bằng OTA nên không chạy alpharev được. Thấy trên xda bảo phải downgrade mới chạy được.
AquaSta
Hôm nay vừa đọc cái gì đó liên quan đến fastboot cho con LG GT540 cùi, giờ đọc cái này thì hiểu =)) chứ mấy bữa trước mà cố thì tàu hoả nhập ma
longpvan
Cảm ơn mọi người chỉ dẫn.
Đã root chú nhỏ IS 2.3.3 được rồi.
Cảm ơn!
thomastn
Mình đã up lên 2.3.3 bằng Gold Card, bây giở root theo cách này được ko các bạn?
longpvan
S-OFF bình thường như cách đã hướng dẫn ở đầu Topic này bạn à! Root cũng ok, mình không gặp vấn đề gì cả.
Chỉ lưu ý:
Khi chạy AlphaRevX để S-OFF thì có máy đợi hơn 15 phút nên có thể phải khởi động lại phone và làm lại từ đầu.
Còn mình đợi 15 phút không xong. Mình Restart lại IS, khi đến màn hình trắng (chữ xanh) mình chạy lại AlphaRevX theo cách ở trên. Kết quả OK, khoảng chưa đầy 1 phút.
Chúc may mắn!
