Thảo luận chia sẻ kinh nghiệm sử dụng N95 - N95 8G
police_cat_vn
N95 8g hang 2nd. Cửa hàng bán 3tr7. Ko phụ kiện.Hết bảo hành, theo các bạn có múc đựợc không?
police_cat_vn
máy này của 1 cô gáj Đj làm từ hồng kong về. Ko dùng nữa. Quán điện thoại cũng la chỗ tjn cậy. Nên mình ko lo bị luộc. Mình lo về cái trựợt của máy cơ. Hàng 2nd mà.mình sợ đứt cáp lắm. cho mình ý kiến xem có cũ lưu ý khi mua nhé. Thanks
khoa123
da co hang,xin mod thong cam vi may n95 v1.21 :( chua co tieng viet. Trong vong tuan toi em se up fw( mat dien 1 phat thi tieu :D) . Nhung ma sim viettel cua em da cai 3G test tot tren n82 ma vao day lai ko co,em nghi tai fw. Vi fw n82 em v31. Xin het
Va bay gio van ko biet the nho nam dau :((
xanoxa
Bạn tham khảo tư liệu này nhé, phần tiếng Anh cũng dễ hiểu, khỏi cần dịch nhé.
Variations in N95
N95 8GB (N95-2)The N95 8GBA revision of the N95, called N95 8GB (N95-2, internally known as RM-320), was announced on August 21, 2007, and put on market in October 2007.The changes compared to the regular version are:Improvements
1. 8 GB separate internal memory
2. Larger display ((up from 2.6 inches (66 mm) to 2.8").
3. 128 MB RAM (up from 64MB), 95MB available.
4. Demand paging (although the N95 supports this too, since firmware version 20.0.015)
5. 1200 mAh battery (BL-6F), up from 950 mAh
6. Cosmetic changes to media and front-panel buttons
7. New model of handsfree/remote control, AD-54 (as opposed to AD-43 for previous N95 versions)
8. New multimedia menu, with Nokia's Ovi content integration
9. Built-in Automatic Screen Rotation (ASR) in software versions v20.0.016 onwards for the N95 8GB version and from v30.0.015 for N95-1, respectively.
10. Black faceplate instead of the original silver.
N95 NAM (N95-3)The Nokia N95-3 is a revision of the N95, internally designated as RM-160, designed specifically for the North American market. It is also available in Australian and South American market.The following was changed from the original version:
1. 128 MB RAM, up from 64MB.
2. WCDMA (HSDPA) 850 and 1900 MHz , instead of 2100 MHz .
3. 1200 mAh battery, up from 950 mAh.
4. Talk time up to 190 min (WCDMA), up to 250 min (GSM).
5. Slider protecting camera lens removed to make room for the larger battery.
6. Camera flash moved to the vertical axis of the phone, so when the phone is used as a camera itsits to the side of the camera, instead of below as in the N95-1.
7. Cosmetic changes to media buttons.
8. Height: 2.05 cm, down from 2.10 cm.
9. Mass: 125 g, up from 120 g.
10. White keyboard light instead of blue for visibility improvement.
N95 8GB NAM (N95-4)The Nokia N95-4 (internally known as RM-421) is the North American 3G-compatible version of the N95-2. The main differences to the N95-2 are:
1. Camera lens is now more flush with the phone's face.
2. Multimedia keys are less glossy.
3. No ASR (Automatic Screen Rotation). Although a hardware accelerometer is present, third partysoftware is required to rotate the screen.
Both N95-3 and N95-4 have also some additional changes, such as the removal of the sliding lens cover for the camera, improved battery life, and doubling of runtime memory (RAM) from 64 to 128 MB.N95 CHINA (N95-5)Featuring the internal name RM-245, the N95-5 is targeted at the Chinese market. The main difference from the regular N95 is the lack of any 3G connectivity support, which has not been yet adopted in China , and the absence of WLAN connectivity, due to Chinese regulations.N95 8GB CHINA (N95-6)The N95-6, internally coded RM-321 is a Chinese market-targeted version of the N95-2, lacking 3G and WLAN support just like the N95-5.Versions comparisonThis table lists only the specifications that differ between versions of the N95 models. (Most details in this table are from.)
Feature N95(N95-1) N95 8 GB(N95-2) N95 NAM(N95-3) N95 8 GB NAM(N95-4) N95 CHINA(N95-5) N95 8 GB CHINA(N95-6)
Internal name RM-159 RM-320 RM-160 RM-421 RM-245 RM-321
Release date March 2007 August 2007 November 2007 January 2008 February 2008 February 2008
WCDMA frequencies 2100 MHz 2100 MHz 850/1900 MHz 850/1900 MHz none none
WLAN connectivity yes yes yes yes no no
Internal Dynamic Memory (RAM) 64 MB 128 MB 128 MB 128 MB 128 MB 128 MB
Internal Flash Memory 160 MB 8 GB 160 MB 8 GB 160 MB 8 GB
Memory card slot micro SD/SDHC none micro SD/SDHC none micro SD/SDHC none
Battery 950 mAh 1200 mAh 1200 mAh 1200 mAh 1200 mAh 1200 mAh
Talk time (GSM) 4 hr 5 hr 5 hr 5 hr 5 hr 5 hr
Standby time (GSM) 9.3 days 11.6 days 12 days 12 days 10.5 days 12 days
Screen diagonal 2.6" diagonal 2.8" diagonal 2.6" diagonal 2.8" diagonal 2.6" diagonal 2.8"
Dimensions 99x53x21 mm 99x53x21 mm 99x53x21 mm 99x53x21mm 99x53x21 mm 99x53x21 mm
Mass 120 g 128 g 124 g 128 g 124 g 128 g
Camera lens cover yes no no no no no
xanoxa
Mình sử dụng FontRouter LT và FontRouterMan V1.06 cài vào máy và sẽ thấy trong thư mục C:\data\fonts (xem bằng xplore 1.22). Bạn chép font TV việt vào thư mục này là xài OK.
xanoxa
Đây là cách thoái thác trách nhiệm khi xảy ra sự cố của họ thôi. Đúng là hên xui, cần phải xem lại lịch cúp điện khu vực đó khi giao máy cho họ à ??? hihi
hhkkll
Variations in N95
Bạn đang làm j ở đây Spam àh?
xanoxa
- Chào các bạn !!!
- Mình cái vào máy N95 8gb của mình một vài phần mềm test cho vui, nhưng đặc biệt mình cài cái callrecorder 1.03 bản việt hóa down trên pdaviet thì khi chạy xong mình cắm cáp vào chẳng khi nào máy tính nhận, nó cứ báo là bộ nhớ đang đc sử dụng. Minh đã test rất nhiều lần là mình phải xóa phần mềm ấy đi thì cắm cáp vào mới nhận, mà công việc của mình thi cần cái phần mềm ghi âm đó và mình cũng chỉ thực sự hài lòng với nó nên chẳng muốn đổi qua phần mềm khác.
- Nay mình xin hỏi các bạn là có cách nào vừa sài đc chương trình callrecorder đó mà vẫn dùng cáp nối đt và máy tính đc không? chứ n95 8gb mà ko kết nối đc với máy tính thì....buồn lắm.
Cám ơn mọi người đã đọc qua và mong sẽ nhận đc sự giúp đỡ của mọi người.
Được chứ bạn. Nếu chương trình Callrecorder ảnh hưởng đến việc kết nối (nếu bạn đã khẳng định chắc chắn) thì remove nó đi. Xài chương trình VoiceTrack rất OK. Mình dùng máy N95-4 RM-421 chạy đồng thời nhiều chương trình (VoiceTrack, FullscreenCaller, Voice Inbox..) mà vẫn kết nối PC vô tư mà.
xanoxa
Máy của bạn là loại N95-4 RM-421 xài cho thị trường Bắc Mỹ, có băng tần 850/900-1900Mhz. Còn ở VN mạng 3G dùng băng tần 2100Mhz nên hiện tại không dùng được (cả 3 mạng Viettel, Vina, Mobile). Nếu có đăng ký thì cũng chỉ hiện chữ 3G thôi, còn không thấy có cột sóng nào cả. Mình cũng như bạn và phải OFF dịch vụ 3G rồi, cho đỡ tốn tiền. Tạm xài GPRS cũng OK.
khoa123
dạ đúng là RM 421,nhưng anh ơi máy anh đang xài ngôn ngữ eng hay TV thế?? Em vừa up lên v31,thằng chủ tiệm nói ver này là mới nhất đối với RM 421 vẫn chưa có TV chán quá :(:)(:)((,có phải vậy ko anh???
hungdqk
code của máy em trả hiểu sao vẫn chưa có FW 35.x mà máy em ko có tiếng việt mà FW lại chưa có bản mới nhất chứ
hungdqk
Máy n95 8gb của em là hàng vodafone của Anh thì có dùng được 3g của việt nam ko các bác. Em dùng mạng mobifone
xelibri
Máy của e là N95 8G nhưng không hỉu sao e chơi game đuôi jar hay bị giật giật rất khó chịu. Có bác nào biết nguyên nhân và cách khắc phục không ạ?
Auto
Java mà nặng nặng là giật giật à bạn ơi. :D
(sao sis hem chơi mà chơi java ;;) )
tiephien1
N95 hỗ trợ java rất tốt mà bạn?
Bạn thử cài lại FW xem thế nào.
thân!
