các pro ơi! cho e hỏi cái này chút!
sao e dùng JAF de flash fw cho máy N81 8G nhưng khi flash thì chỉ hiện ra như thế này!
JAF version 1.98.62
Detected PKEY: 90009699
Card life counter: 99.82%
USB Cable Driver version: 7.0.2.0
Changing mode...Done!
Searching for phone...Detected P-KEY: 90009699
Init usb communication...
Found
MCU SW version: V 06wk41v47.2
23-11-07
RM-179
(c) Nokia
HW version: 0503
PCI version:
RFIC version: 17141715
DSP version: bruce_ICPR62_07w46v2
APE SW Core version: 11.0.045
APE Variant version: 11.0.04511.0.045_16.01
APE Test version: rm179_ENO_x_2007wk24v0.070
Retu version: 15
Tahvo version: 22
APE HW version: 256
APE ADSP SW version: 256
APE BT version: HCI Version 8 (rev. 0). LMP Version 32 (rev. 4127). Manufacturer 13064.
Production serial number: CMF304760
Product code: 0545902
Module code: 0203286
Basic production code: 0544170
Flash code:
Order number:
Product specific data:
Long production SN: 0
ATO:
Default SN type:
IMEI plain: 356995010910017
IMEI spare to net: 3A 65 99 05 01 19 00 01
IMEI SV to net: 33 65 99 05 01 19 00 11 F2
LOCK STATUS:
CONFIG KEY: 2440700000000000
Provider: AT&T;U.S.A. (3650)
Key Code count: 0, FBUS Code count: 0
Block 1:
Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Loading INI list...
Reading product code...
Product Code: 0545902
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-179\
Checking path: \Products\RM-179\
Scanning ini files...
FILES SET FOR FLASHING:
MCU Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-179\RM179_20.0.056_prd.C00
PPM Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-179\RM179_20.0.056_prd_0101.V01
CNT Flash file: C:\Program Files\Nokia\Phoenix\Products\RM-179\RM179_20.0.056_002_erase_uda.fpsx
APE Variant file: C:\Program Files\Nokia\Phoenix\Products\RM-179\RM179_erase_E.fpsx
Languages in ppm: English,French,German,Italian,Spanish,Portuguese
Done!
Backing up CRT...
Reading IMEI...
C:\Program Files\ODEON\JAF\ProgData\356995010910017_CRT_backup_858196.pm
Done!
Backup CRT OK!
Searching for phone...Found
Reading SW version...06wk41v47.2 11.0.045
Reading battery value...3885 mV
Init usb flashing...
Reading flashid...
CMT: 003000EC <=> SAMSUNG (SEC) -> K5W1G13ACB
APE: 00000000 <=> Flash -> not detected
Verifing ADL communication... Status byte 7
Rebooting to flash mode...
Waiting for the phone to reboot...
Phone rebooted but not in flash mode...
sau đó máy khởi động lại và chẳng có jì thay đổi ở cái máy của e cả.
có ai biết như vậy là bị jì k chỉ cho e với!hichic....đã flash nhiều lần rồi nhưg vẫn thế!
