Up & Down Firmware cho Nokia với JAF (No box)
nlphong75
ag cho mình hỏi luôn sao mình up cho con n85 mình lên phiên bản N85 (RM-333) 30.019 v5 (EURO) là có còn tiếng việt ko bạn?hay là còn tiếng anh thui.với lại sao mình up FW cái máy mình nó tắt luôn.ko chiu mở lên lại.mình rút cáp ra và mở máy lên thì mới đc
nlphong75
JAF version 1.98.62
Detected PKEY: 9000A919
Card life counter: 99.99%
USB Cable Driver version: 7.1.16.0
Changing mode...Done!
Searching for phone...Detected P-KEY: 9000A919
Init usb communication...
Found
MCU SW version: V ICPR72_08w44.1
10-11-08
RM-333
(c) Nokia
HW version: 1102
PCI version:
RFIC version:
DSP version:
APE SW Core version: 11.047
APE Variant version: 11.04711.047.013.111.047.53.1
APE Test version: rm333_ENO_x_2008wk41v0.030
Retu version: 15
Tahvo version: 22
APE HW version: 256
APE ADSP SW version: 256
APE BT version: HCI Version 12 (rev. 8192). LMP Version 12 (rev. 0). Manufacturer 12708.
Production serial number: CSD878736
Product code: 0561354
Module code:
Basic production code: 0555813
Flash code:
Order number:
Product specific data:
Long production SN: 0
ATO:
Default SN type:
IMEI plain: 356376023086089
IMEI spare to net: 3A 65 73 06 32 80 06 08
IMEI SV to net: 33 65 73 06 32 80 06 08 F3
LOCK STATUS:
CONFIG KEY: 2440700000000000
Provider: AT&T;U.S.A. (3650)
Key Code count: 0, FBUS Code count: 0
Block 1:
Lock 1: OPEN Lock 2: OPEN Lock 3: OPEN Lock 4: OPEN Lock 5: OPEN
Block 2:
Block 3:
Block 4:
Block 5:
Block 6:
Block 7:
Loading INI list...
Reading product code...
Product Code: 0561354
Checking path: C:\Program Files\Nokia\Phoenix\Products\RM-333\
Checking path: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-333\
Scanning ini files...
FILES SET FOR FLASHING:
MCU Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-333\RM-333_30.019_prd.core.fpsx
PPM Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-333\RM-333_30.019_001_prd.language.fpsx
CNT Flash file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-333\RM-333_30.019_53.1_prd.customer.fpsx
APE Variant file: C:\Program Files\Common Files\Nokia\DataPackage\Products\RM-333\RM-333_30.019_003_000_U001.uda.fpsx
Done!
Backing up CRT...
Reading IMEI...
C:\Program Files\ODEON\JAF\ProgData\356376023086089_CRT_backup_710127.pm
Done!
Backup CRT OK!
Searching for phone...Found
Reading SW version...ICPR72_08w44.1 11.047
Reading battery value...4127 mV
Init usb flashing...
Reading flashid...
CMT: 004000EC <=> SAMSUNG (SEC) -> KAT00F00RA
APE: 00000000 <=> Flash -> not detected
Verifing ADL communication... Status byte 7
Rebooting to flash mode...
Waiting for the phone to reboot...
Sending RAW loader...
Using 009.008.003
Elf2flash 09.18.000
CMT RAW loader...
Patching RAW boot step1...
Patching RAW boot step2...
Patching RAW boot step3...
Sending RAW Loader...
...................Error booting phone...
nè n85 của mình nó khởi động máy lên chữ nokia rồi tắt luôn.mình potay
binhseu
Posted via Mobile Device minh up e90 cua minh len fw v400.34.93, nhung lai ko cao tieng viet, ban nao giup minh voi
superman1983
Mình dùng JAF downgrade cho con Nokia E63 Red. Kết quả là " Simcard not invalid" . Híc máy bị lock rồi! Có ai chỉ mình cách unlock với! Thanks!
audir8
các bác cho tôi hỏi phiên bản JAF này có thể làm N96 RM-472 EMEA 12.043 v04.00 thành N96 RM-247 EMEA 20.050 v5.00 được kô các bác. Có bác nào làm được rồi thì chỉ giúp tôi với.
thanks
kien281089
Hôm nay e down fw v400 của con E51 xuống v300 để hack,dùng được 1 lúc,máy toàn tự rs là sao,ai biết bệnh này xin cho e lời giải đáp với :|
joelin5793
Các bác ơi, em xài Windows XP Professional x64 Edition, tới step 2, bấm go, rồi nó để error, củng là xp mà. Có ai biết giúp dùm em
Zenki
Error gì bạn? Cái phần quan trọng nhất thì không đưa lên sao anh em biết mà giúp?
joelin5793
Sau khi bấm go thì nó hiện 1 đống này đây:
Checking Windows version ...
Windows version: Microsoft Windows XP Professional x64 Edition
Searching for JAF install location ...
Saved winscard.dll to: C:\Program Files (x86)\ODEON\JAF\winscard.dll
ERROR: Not supported Windows version
Không biết phải tại win hay ko
nlphong75
sao minh up con 6630 cua mình nó chết luôn rồi lam sao giờ bạn.mình đem lại tiệm bạn chạy lại dùm mình đc ko
betty_boy82
Anh em giúp mình với! N96 của mình up firmwere bằng J.A.F lên V30.033 xong mình thấy xem ti vi chậm quá,mình hạ firmwere xuống v20.050,máy khởi động lên không được và báo ''phone start up failed ..."mình dùng mọi cách (format 4 phím,cài firmwere lại bằng J.A.F o chế độ die phone )kết quả điều thất bại.Có cao thủ nào giúp mình với...:((
135798642
các bạn thử update = NOKIA OVI SUITE 2.0 chưa, download max speed, up dễ dàng, nhanh chóng :) mình đánh liều up con n78 v21 mình ( lại trên win7 nữa ) , thành công rực rỡ, ko như cái NSU down 3kb/s :( ai rỗi lập topic về cái này đi..
spyhunter88
Cho mình hỏi với, hiện nay đang có 1 con N73 SoftBank, 1 con E61 Vodafone từ bên Nhật về, đã Unlock nhưng chạy cứ lung tung. Mình đang tính Up firmware lên cho hai con này, nhưng đang sợ là Up lên nó lại bị lock thì teo, thấy bảo con N73 SoftBank mà Unlock mất mấy trăm nghìn thì ai mà đỡ nổi nữa. Mình cũng định đổi Product Code cho nó, không biết sau khi đổi thì nó có đòi Unlock lại không nữa, vì trên trang down firmware mà chủ Topic đưa chắc gì đã hỗ trợ 2 cái Product Code của hai con kia.
N73:
 [URL="http://topnokia.ru/files/file1073.html"] RM-133 EMEA 4.0839.42.0.1 v22.0[/URL]
N73 ME:
[URL="http://topnokia.ru/files/file1076.html"]RM-133 ME EMEA 4.0839.42.2.1 v11.0[/URL]
E61:
[URL="http://topnokia.ru/files/file1180.html"]RM-89 3.0633.09.04[/URL]
Liệu đổi Product Code để up lên qua mấy cái firmware kia thì có bị lock không? Mà mấy cái trên là dùng Product Code nào? Ai biết chỉ mình với.
