Xin thông báo. Đã có rom mới.Đây là thông tin
HTCMAG_ROM_WWE_O5
ROMs for HTC Magician.
Release date: 19.12.2009 GMT+3 00:40
Alternate names: 3.06 WWE
Based on Generation 9.
ONLY FOR 64 MB DEVICES
Don't install on 128 devices.
Description:
*64RAM ONLY devices support
*Extra feature - "Start Style"
*BatClear application excluded. It's now obsolete.
*Chord keys support:
Enter + Calendar -> Calibration
Enter + Contacts -> WirelessMgr
Enter + Record -> DeviceSpeed
So you can execute this functions by two buttons. Very easy.
*Ability to turn off device fully.[*]
*Press and hold power key functionality:
softreset, screenshot or fulloff
Configured in registry, no UI for it in "Generaion 9".
*Different USB charge modes: none, slow-100ma and fast-500ma.
*USBtoPC unchecked box mode is working now.
*Unattended mode now working.
*BTDUN profile now working.
*AutoInstall application included. Allow you to setup your favorite settings/program from script file after hard reset.
*Equalizer application included. Bass and treble settings. AGC settings also moved in this application.
*AudioBooster application included. Default off. You need turn it in registry.
*Slightly improved touch sensitivity
*No camera in ROM. And no way to use camera at all.
*Speaker On button now working in cprog application.
*New Bluetooth.
*SDHighCapacity support (up to 8GB)
*SDIO expansion cards no longer supported.
*Something else
*Of course all features from previous roms - read info about it also!
Installation:
*You must have installed 1.12 or 3.00+ radio.If not, install it first, RADIO NOT INCLUDED INTO RAR!
*Download archive
*Extract files from it
*Enter bootloader mode on device (Press POWER + CAMERA + RESET, you will see Serial/USB at top and 1.0X at bottom)
*Connect via USB to PC
*Run Update.exe
*Follow instructions in Update program.
*At the end you should see at device screen: "100% Upgrade OS Image Complete".
*After flashing press reset.
*Don't touch device, wait while "welcome screen" appear.
*Press screen, do calibration and start using device.
NOTE: This is ONLY ONE right instruction how to flash your device with my rom.
otherwise your device can no longer boots, also you can get brick. be sure, before doing anything wrong!
Uninstallation
*Install ORIGINAL 1.12 or 1.13 ROM. No big storage etc. Install original one!!
[YOU *MUST* REPLACE ROMUpgradeUt.exe TO MaUpgradeUt_noID.exe]
*Now you can flash any other old custom roms.
NOTE: This is ONLY ONE right instruction how to uninstall my rom, otherwise you can have problems with new rom.
Misc Info
Hard reset - press and hold Contacts and Calendar button during boot, you will see message on screen.
Press Green key to confirm or press Red key to cancel.
Screenshots
Discussion threads
You can discuss my work at these forums:
XDA-DEVELOPERS.COM [WWE]
Download it
HTCMAG_ROM_WWE_O5 [45mb]
Please don't reupload files to other places.
LIST OF REGISTRY SETINGS FOR G9
You are flashing your device at your own risk.
I've tried all my ROMs on my own device and didn't find any problem.
I take no responsibility for any harm or damage to yourself, your device, computer or anything else.
Something works, something doesn't. Something is not supposed to work.
Something is supposed to work, but doesn't. Something should't work, but works.
Something should work, but doesn't;
Something should work from your point of view, but not from mine.
Something is not supposed to work, that's why it doesn't work.
By downloading and using this files, you agree with this statements.
This is private project, don't ask any details about development, also don't ask about future releases, I won't answer. Sorry.
Created by Cotulla.
Please don't rip anything from my roms, don't use any solutions from it, don't redistribute materials without my permission.
Respect my work and time!
