![Mad :mad: :mad:](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
[size=+3]Now available version FROM dioxda2-
1a (original) and[/size]
[size=+4]
1b RELEASED[/size]
[size=+3]
dioxda2's Asian region selectable
+force_device_Off_Bug_Fixed
+UC compatible +PowerPoint deleted
+HTC_Home_removed
+ a bit larger storage memory version ........
unzip password = dioxda2[/size]
[THANKS TO ROM MASTER: PhamNhatThanh ^_^]
Tips for better performance
1. disable X-button,
2. use WkTask1.1.7.3c for running task handling,
3. reg tweak to the registry (CLSD) for less than 2 seconds input-panel pop-up. ^_^
[size=+3] HARDSPL IS NOT NEEDED FOR FLASHING THIS ROM...
^_^ [/size]
[size=+2]ONE STEP DIRECT UDGRADE / FLASH [/size]
very very very fast rom~~~ (sorry Korand, this one faster.... on my G3 ^_^, may vary on other Prophet)
HTC Home - [not in Advanced Version (1b)]
HTC_Connection_Setup,
HTC Diamond MP3 Trimmer,
Comm_Manager_Diamond skin,
Dialer_NikiBlack style,
OEM_AdvancedConfig_v2_0_1
PIM_Backup_2_8
RAR_3_71
Utilities - SMS Backup
NET Compact Framework 3.5.7283.0
Office Mobile 6.1 [PowerPoint not in Advanced version (1b)]
HTC Sim Manager for Pocket PC v6.47
RC Mod (thanks chỉnh sửa giao diện)
SynchroTime
regedit
PCM Keyboard v0.14 (support Vietnamese keyboard)
....... more
YOU JUST NEED TO DO THE FOLLOWING .....
[size=+4]1b RELEASED[/size][SIZE=+3] 4SHARED MIRROR[/SIZE]
- Advanced dioxda2 Asian +force_device_Off_Bug_Fixed +UC compatible +PowerPoint deleted + HTC_Home_removed + a bit larger storage memoryVersion (uploading) unzip password = dioxda2
1a -
Original download this ORIGINAL VERSION unzip password = dioxda2
Mirror for 1a 4SHARED Download
Mirror for 1a Rapidshare Download
2. UNZIP,
3. Activesync your prophet,
4. double click the upgrade.cmd,
5. some more looks... some more clicks, (with instructions on PC screen )
6. DONE
[size=+2](P.S. always use a reset software to make soft-resets....)[/size]
YOU can DIRECT from WM5 or WM6 or WM6.1 ...... (please report if any broken links here)
SHOTS.........................
SCREEN SHOTS A....(I like l3v5y's big digit phone dialpad, push here... ^_^ (not in tis rom) ~~^_^~~
SCREEN SHOTS B....
