Sonblack
PDAVIET ROM WM6.1
CE OS 5.2.19972 Build 19972.1.2.7 PV
=== Only for XDA ATOM / ATOM PURE ===
Lời cám ơn - Thanks:
Manager PhamQuang
Admin Kawaguchi
ROM Dev Dvha79_ddt
Mod Lamson, TranMinhMan, Hoangdat_vista
Trial Mod PhamNhatThanh, khacduy1978
VIP Medkid, nhocbanme, nhattoai
herg62123, poorlyduck from xda-developers
Thông tin - ROM Information:
- CE OS 5.2.19972 Build 19972.1.2.7 PV
- Pagepool: 6M
- Rom date: November 20, 2008
- ROM Version: 20081120D4WWE
- Transcriber included.
- Manilla 2D with Black Skin also included.
- Remove all help files.
- XIP & SYS from latest original rom of HTC Elfin
Manager PhamQuang
Admin Kawaguchi
ROM Dev Dvha79_ddt
- Pagepool: 6M
Hình minh hoạ - Illustrative Images:
- AudioManager v2.0 Build 1820.1321 (Elfin)
- JBlend Java v3.3.5 Build 20081015.1.1 (Jade)
- Outlook Enhancement (Elfin)
- Picture Enhancement (Elfin)
- Comm Manager v2.7.2.8
- ArcsoftMMS v5.0.31.63 (Elfin)
- Acrobat PDF LE 2.5 (Elfin)
- Enlarge Start Menu (Mod from Elfin)
- Enlarge TitleBar (Elfin)
- YouTube (Elfin)
- Manila2D v1.00.1819.2926
- HTC Sim Manager for Pocket PC v6.58
- .NET Compact Framework 3.5.7283.0
- Office Mobile 6.1
- Office Note
- HTC Album (automatically run)
- Google Maps (automatically run)
- Opera Browser (automatically run)
- SIPChange (automatically run)
- Windows Media Player 10.3 Build 19972
- Advanced Configuration Tool v3.3 by Schap
- Pocket RAR v3.80 by Alexander Roshal
- ClearTemp v1.1 by Vicott Wong
- PIM Backup v2.8.0.0 by FdcSoft
- Pocket Screen v1.3 by JJM. Roseboom
- Synchro Time v0.95 by Dennis Grachov
- WM5torage v1.8 by V. Bozhko
- Total Commander CE v2.51 by Christian Ghisler
- WKTask v1.1.7.3 (open/close applications fastly)
- Network Wizard for PocketPC v1.0 (Build 29982.1.0.1.7) (support Mobifone, Vinaphone, Viettel for setting GPRS configuration)
Hướng dẫn - Guides: Vui lòng đọc kỹ - Please read carefully
Chỉ cần tải file .exe chứa ROM, chạy file .exe trên PC và làm theo các bước chương trình yêu cầu cho đến khi hoàn tất. PPC của bạn sẽ tự hard reset khi mọi thứ hoàn thành.
The only thing you have to do is download the .exe file including ROM and perform a double click on it (off course, on PC), then follow the guide step by step that the program requires until it finishes. At the end, your Atom will automatically perform a hard reset.
Link đã có sẵn - The link is available now
Link nằm trong file đính kèm ở cuối bài - Link put under attached file at the end of this post
UP ROM VỚI TÙY CHỌN "OS+ExtendedROM".
FLASH THE ROM WITH OPTION "OS+ExtendedROM".
Note - Lưu ý:Link nằm trong file đính kèm ở cuối bài - Link put under attached file at the end of this post
Để tải ROM, các thành viên sử dụng Username và Password chung là PDAVIET
To download the ROM, use both Username and Password PDAVIET
Cuối tuần vui vẻ!
Have a good weekend!
Sonblack
