XDA ATOM/ATOM PURE - PDAVIET ROM WM6.1 (Core 20270)
Sonblack
PDAVIET ROM WM6.1
CE OS 5.2.20270 Build 20270.1.3.1 PV
=== Only for XDA ATOM/XDA ATOM PURE ===
Lời cám ơn - Thanks:
Manager PhamQuang
Admin Kawaguchi
Mod Medkid
Mod Hoangdat_vista
Trial Mod Lamson
Trial Mod PhamNhatThanh
Trial Mod TranMinhMan
Trial Mod nhocbanme
Trial Mod khacduy1978
Thông tin - ROM Information:
- CE OS 5.2.20270 Build 20270.1.3.1 PV
- Pagepool: 6M
- ROM Version: 20080722C1WWE
Hình minh hoạ - Illustrative Images:
Các chức năng - Main functions:
- .NET Compact Framework 2.0.7045.0
- Office Mobile 6.1
- Office Note
- ArcsoftMMS v5.0.31.11
- Windows Media Player 10.3 Build 20270
- Windows Live for Windows Mobile v10.6.0034.0800
- Adobe Reader LE 2.0
- Adobe Flash Lite v2.1
- Advanced Configuration Tool v2.02.0.1.0 by Schap
- ClearTemp v1.0.2 by Vicott Wong
- Task Manager v3.1 by FdcSoft
- PIM Backup v2.8.0.0 by FdcSoft
- HTC Sim Manager for Pocket PC v6.49
- Synchro Time v0.94 by Dennis Grachov
- WM5torage v1.8 by V. Bozhko
- Esmertec Java Build ID: 20080428.2.1
- EnlargeStartMenu v1.2.34070.1
- LargeTitleBar v2.35.0.0
- Total Commander CE v2.5 by Christian Ghisler
- SMS Display Mode by Sonblack (change message display on PPC)
- WKTask v1.1.7.3 (open/close applications fastly)
- PocketRAR v3.71 by Alexander Roshal
- Network Wizard for PocketPC v1.0 (Build 29982.1.0.1.7) (support Mobifone, Vinaphone, Viettel for setting GPRS configuration)
- BatteryStatus Today Plugin v0.05.126 Build 0309 by Chi-Tai Dang
- PHM TrayLaunch
- Pocket Screen v1.3 by JJM. Roseboom
Hướng dẫn - Guides:
Tải file .exe về máy. Chạy nó. Giải nén vào thư mục C:\Windows\Temp. Chạy file Device Software Update Utility.exe từ thư mục này để up rom.
Download the .exe file to PC. Execute it. Uncompress to folder
C:\Windows\Temp. Run file Device Software Update Utility.exe from this folder for flashing rom.
Link đã có sẵn.
The link is available now.
ATOM ROM 20270 - PDAVIET
PASSWORD for uncompress: SONBLACK
Note - Lưu ý:
Để tải ROM, các thành viên sử dụng Username và Password chung là PDAVIET
To download the ROM, use both Username and Password PDAVIET
Up cả EXtendedROM để có được giao diện màu đen của Wireless Manager.
Flashing with option "Update Item" is "OS+EXtendedROM" for having black skin of
Wireless Manager.
Chúc vui.
Enjoy it.
Sonblack
VOKE
bóc tem trước nhé ! canh me mấy hôm nay vì biết thế nào tuần này pác ý cũng ra Rom mới :)) ... thanks pác Sơn đen .... nhanh nhanh lên pác ôi .... :((
phamcongli
Hix hix , trễ rồi , ngủ quên nên không được khui hàng dầu tiên . Thôi đành tụt lại vị trí số 2 thoai . hehe . Cảm ơn anh Son nhiều , down về test thử coi sao .
Sever đang bị lỗi down không được ...hixhix . Ah tiện đây anh Son có thể post phần mềm Light và mấy phần mềm do anh Sơn viết lên PV được không ạ . Em thấy mấy phần mềm đó hay quá mà đôi khi dổi về mấy cỏe cũ lại không có pm này thì tiếc quá . Mong anh Sơn có thể post lên cho anh em . Thanks anh Son .
Sonblack
Lại có cả SMS Display Mode do Mod Sonback viết nữa, " Cây nhà lá hàng xóm " đây rôi, lại phải chôm về cho Prophet thôi :))
Kho ROM của Mod bị lộ rùi , gay to :D
Chôm thoải mái anh Minh ơi. Chôm còn cám ơn nữa chứ :)):)):)):))
VOKE
Hehe nếu bạn nào down không được thì làm theo cách của mình là down được nè : Các bạn vào link này : http://kc9.info/pdaviet/rom/Sonblack/Atom/ sẽ thấy các bản rom cho Atom của anh Sơn ... sau đó click vào bản rom cần tải về là ok thôi . Chúc thành công .
Phamcongli cũng chậm chân rồi , mình đã tải khi anh Sơn vừa mới úp lên . :p
Do mai thi nên chưa upgrade lên được , bạn nào up lên xài thử có gì hay reply nhé ...
takaru
Anh Sơn ơi . e cũng không biết nói gì hơn . Bất ngờ . bất ngờ và bất ngờ .Em up ngay đây. Sẽ có ý kiến vào sáng sơm mai . Thanks anh Sơn
johnson9931
Not Found
The requested URL /pdaviet/rom/Sonblack/PDAVIET_ROM_WM61_OS20270_ATOM_Sonblack.exe was not found on this server.
Additionally, a 404 Not Found error was encountered while trying to use an ErrorDocument to handle the request.
Apache/2.2.9 (Unix) mod_ssl/2.2.9 OpenSSL/0.9.8g DAV/2 mod_auth_passthrough/2.1 mod_bwlimited/1.4 FrontPage/5.0.2.2635 Server at kc9.info Port 80
why can't i download this ROM ?
VOKE
Not Found
Rom's Link here :
http://kc9.info/pdaviet/rom/Sonblack/Atom/PDAVIET_ROM_WM61_OS20270_ATOM_Sonblack.exe
johnson9931
THS very much,my friend! it's really difficult for me to understand Vietnamese language. but finally i got the download link from you.THS again!
kanzuyos
HI bác Sơn, em theo bác từ HIMALAYA qua tới đây nè.. dũng giống như bác, HIMALAYA đã ra đi.. hì hì :((
Bác cho em hỏi cái này, hình như bác Sơn ko thay đổi gì về RADIO của ROM ATOM. em hỏi vậy vì thấy sóng DT hơi yếu, cứ tắt máy 1 lúc rồi mở lên là nó lại báo "no service" rồi lại phải dò lại mạng.. cái này có phải do RADIO ko bác.(em còn xài bản ROM 05 cũ), đang download bản 6.1 của bác up xem sao.
Với lại, em có đọc thấy bác nói là khi đang nghe FM mà rút tai nghe ra thì toi cái loa trong,loa nghe DT, máy em mua lại nên ko biết có bị vậy ko vì lúc thử vẫn dt tốt. hiện giờ 80% ko thể sử dụng loa trong( loa ở trên) để nghe dt, lúc được lúc ko, toàn phải hold nút call để nghe loa ngoài. >>> vậy bây giờ khắc phục thế nào hả bác?ROM mới có giải quyết dc ko ạ?
XIN LỖi nếu làm loãng chủ đề của bác.
Sonblack
Build ROM thôi, không phá radio, có thể do phần cứng, lỏng tiếp xúc anten với board mạch, chứ bản Radio gốc của Atom là good rồi.
Còn nếu bạn đọc kỹ các bài đã viết trong box này, bạn sẽ thấy cách khắc phục là mang ra cửa hàng mà thôi :))
vbclg
Bác Sơn biết chỗ tiếp xúc anten với board chỗ nào không? chỉ cho em với, của em cũng chập chờn (không mất, nhưng cũng chập chờn - lúc mạnh lúc yếu dù ngồi một chỗ thôi).
thanks
takaru
thanks
Các bạn bàn về rom này đi , phần cứng thì mình nên ra quán cho an tâm ( nếu mình không biết rõ về nó ).
Mình thấy bản rom này chạy mượt , giao diện tuyệt đẹp. Hi vọng anh Sơn tiếp tục tích hợp thêm những chương trình mà anh viết vào những bản rom sau .
E đang đợi 1 bản rom mang tính đột phá của anh
